Old 01-09-2014, 04:16 PM   #1
SirBrass
Trust me, I'm the Doctor
SirBrass's Avatar
FINALLY, a steering wheel remote kit we can use that isn't DIY
Now this looks cool! Has anyone looked into this to see how well it works?
http://www.sonicelectronix.com/item_...ASWCSTALK.html
I had an Axxess swr adapter in my STI that let me use my SWC with my Appradio 2 and it worked really well, so my impression with Axxess in general is very positive.
^GT5 Replay Photo Mode^
Old 01-09-2014, 05:27 PM   #2
oldpueblo
oldpueblo's Avatar
Drives: Scion FR-S 10 #853
Heh, that shows everything except what the actual product would look like installed. :P
oldpueblo is offline   Reply With Quote
Old 01-09-2014, 05:45 PM   #3
SirBrass
SirBrass's Avatar
Agreed. Slightly annoyed at that. I think it'd look alot like another stalk in addition to your cruise control stalk. I'd probably mount it above and behind the cruise control stalk, since that is on the wheel itself, and I get the feeling that this one goes on the column, not the wheel to avoid having to pass through the clock spring.
Old 01-10-2014, 03:13 AM   #4
laguayo
laguayo's Avatar
Drives: BRZ Limited DGM Automatic
I am surprised other threads didn't mention Axxess but I think they only work with aftermarket HU, not sure your how this would work with OEM HU's.
laguayo is offline   Reply With Quote
Old 01-10-2014, 10:31 AM   #5
nocturne1
nocturne1's Avatar
Drives: 2013 BRZ Limited WRB
They also make one that attaches to the steering wheel rim as well, but it looks like it'd be annoying to have something wrapping around it. Their support site also says that they don't know if it works with our car....
nocturne1 is offline   Reply With Quote
Old 01-10-2014, 11:06 AM   #6
modena
modena's Avatar
Drives: BRZ Limited WRB MT
A mini jack needs to be hooked up to the OEM radio,we know that you can hookup steering wheel controls from other Subaru's, maybe the guy can help us out here if the Axxess can be used instead of the "Home-Brew" buttons?
KartBoy SS | BlackVue DR550GW | Valentine1
GrimmSpeed MC Brace | GrimmSpeed Hood Struts
OEM Armrest | OEM STI Badges | 20% Tint
Rydeen duo | Halo's as DRL
Rexpeed Wide Mirrors
modena is offline   Reply With Quote
Old 01-10-2014, 12:53 PM   #7
SirBrass
SirBrass's Avatar
I think the kit has the parts for that
Old 01-10-2014, 01:40 PM   #8
mid_life_crisis
Drives: FR-S 10 #103 AT
You need to verify that it will work with a three wire resistor based system. The description calls for an aftermarket H/U, most of which use a different system, which is not the same as the factory system.
Old 01-10-2014, 01:44 PM   #9
TIE Pilot
TIE Pilot's Avatar
Drives: TIE interceptor; BRZ13
Metra online has a list of different options for this if you look up by our cars:
ASWCSTALK
Universal SWC stalk add-on <<<< FOR AFTERMAKET HU
OESWC-STALK
Addon SWC stalk <<<< FOR OEM HU
RFASWC
Universal RF SWC add-on <<<< FOR AFTERMAKET HU
OESWC-RF
RF SWC add-on <<<< FOR OEM HU
"Speed has never killed anyone. Suddenly becoming stationary, that's what gets you." Jeremy Clarkson
TIE Pilot is offline   Reply With Quote
Old 01-10-2014, 02:19 PM   #10
SirBrass
SirBrass's Avatar
Yeah, it looks like it will interface fine. It fits quite a few toyotas, so even if it hasn't been tested with the twins, it should still work: http://axxessinterfaces.com/index.ph...roducts_id=113
Old 01-10-2014, 02:39 PM   #11
mid_life_crisis
It looks like the same five functions as the other Scions. Vol +/-, Seek Up/Down, Source.
The rf unit that attaches with a strap looks to have phone buttons, although the phone controls work pretty well, so that might not be necessary anyway.
Old 01-10-2014, 02:48 PM   #12
mid_life_crisis
Harness is wrong. The twins use a 28 pin connector. Other Toyotas and older Scions have a 20 pin connector. You'd need to find a car that uses the same 28 pin connector and either get lucky and have the pattern be the same or be prepared to re-pin it. Or ignore the adapter harness altogether and do some splicing. Actually, it wouldn't really be splicing, because there are no wires to cut. You'd have to find some female wire ends and put them in the 28 pin connector.
If anyone is serious about trying this and wants some help, let me know. I've spent a lot of time working on this subject. I'm waiting for parts to come in to install my own in the center console.
Old 01-10-2014, 03:19 PM   #13
modena
modena's Avatar
I don't mind purchasing said adapter, installing it, ext.
However I do not have the skills nor a way to test or figure out the 28 pin connecter by the radio.
If you would like to try, I can buy one and ship it to you
If it works, good, if not, 100$ loss...
Let me know if you would like to try this out...
Old 01-10-2014, 03:49 PM   #14
SirBrass
SirBrass's Avatar
I'm going to get an aftermarket HU anyway, so the universal kit will work just fine without issue.
WTB: Stock steering wheel (wheel not airbag) mobybrz Interior Parts (Incl. Lighting) 2 09-11-2014 02:23 PM
Electric power steering assist to remote control SeanBlader BRZ First-Gen (2012+) — General Topics 6 01-07-2014 10:16 AM
scion frs steering wheel air bag and steering wheel Jhon19lopez Interior Parts (Incl. Lighting) 7 01-04-2014 06:04 PM
Swapping steering wheels with a new tC steering wheel. jonathan9573 Cosmetic Modification (Interior/Exterior/Lighting) 4 12-20-2013 11:45 PM
BRZ STI Steering wheel??? tacoss23 Cosmetic Modification (Interior/Exterior/Lighting) 9 08-26-2013 07:30 PM
