Old 01-13-2014, 04:42 PM   #197
shaunsweeney
shaunsweeney's Avatar
Drives: 2014 FR-S MT Asphalt Grey
Any plans on a vented hood to deal with the underhood temps?
shaunsweeney is offline   Reply With Quote
Old 01-13-2014, 04:50 PM   #198
mrk1
Drives: Sterling BRZ Ltd
I'll cross that bridge when it happens. I'd rather open the fenders grills and let air out that way. But I'm not opposed to a tastefully vented hood.
The Build Thread
GT28RS - eBoost2 - 3.91 Final Drive - Supra LSD
mrk1 is offline   Reply With Quote
Old 01-13-2014, 05:00 PM   #199
shaunsweeney
That's the tricky part for people like us. We want tasteful design, light weight, and great fitment. That gets a bit expensive.
Old 01-13-2014, 05:07 PM   #200
mrk1
Yeah I haven't seen any hoods that I like. I did just order some spal fans and along with the koyo radiator I don't foresee any problems with this car and daily usage.
The Build Thread
Old 01-13-2014, 05:13 PM   #201
shaunsweeney
Sounds like you've thought this through. I imagine with your fab skills you will be making your own fan shroud as well. I'm interested to see how your car handles heat, because it is the biggest concern for me with front mounted turbos on this platform. I'm really leaning towards the D3PE location to help keep everything up front cool.
Old 01-13-2014, 05:23 PM   #202
mrk1
Yeah a shroud is pretty straight forward. I'm sure I will have some heat hurdles if I drive it hard but I think its better to address them as they come so I can see what actually works.
On a lot of race cars I have worked on, one of the two radiator fans is wired to always be running. It was kinda annoying to listen to but it definitely helped the whole system out. I could also wire a fan to a manual switch.
The Build Thread
Old 01-13-2014, 05:29 PM   #203
shaunsweeney
What do you think of the high rear offset position?
Old 01-13-2014, 05:36 PM   #204
mrk1
I definitely like that it doesn't need an oil pump, huge plus. However I don't think its going to be that much of an improvement in engine bay heat. Thats the classic subi location and they still heat up. The only improvement would be that the source of the heat is farther away from the radiator.
I think an intercooler layout like the MAP kit would go awesome on that D3 kit,
The Build Thread
Old 01-13-2014, 05:40 PM   #205
mrk1
I'd take that D3 over mine if I was stuck in 495 summer traffic.
The Build Thread
Old 01-13-2014, 07:26 PM   #206
shaunsweeney
Let me know when you want to try building something similar to that. To me the benefits are:
Further from radiator/limits heat soak
No oil pump like AVO location
Easy to access
Retains factory header or any aftermarket header
Old 01-13-2014, 09:10 PM   #207
Fleischwagen
Drives: 2013 BRZ, 1979 Scirocco 16v
I'm beyond jealous of your fab skills. As someone who somewhat recently learned how to weld (if you even wanna call what I can do, welding…) everything you've churned out, looks absolutely incredible.
As for IC cooling, what about mocking up some sort of temperature controlled IC water sprayer? Or water/meth for that matter?
Hmmm, maybe even some NACA ducts under the bumper/front splitter? Or even utilizing the fog light sections of the front bumper?
PS, you could even fab up some sort of heat shields for the alternator and A/C compressor and belt assembly.
Fleischwagen is offline   Reply With Quote
Old 01-13-2014, 09:21 PM   #208
mrk1
Just keep welding. The only difference between and good welder and great welder is 1,000ft of wire.
Water sprayer and water/meth has more to do with intake and power, not engine bay temps.
The Build Thread
The Following User Says Thank You to mrk1 For This Useful Post:
bama_brz (02-23-2014)
Old 01-13-2014, 09:23 PM   #209
mrk1
Easy to access
Let me think over some ideas!
The Build Thread
shaunsweeney (01-13-2014)
Old 01-13-2014, 09:31 PM   #210
Fleischwagen
Amen! hah I got lost reading the thread, I thought everyone was discussing IC temps… but the use of some sort of ducting from the bottom could be used no? Nearly all the VW's now-a-days have some sort of ducting built into the under engine panels.
Something like this:
AMR Performance: How to remove the factory bumper (walk-through images inside) AMR Engine, Exhaust, Transmission 9 04-10-2013 08:45 PM
86 Modelista walk around and GT Limited SoCal_86 Scion FR-S / Toyota 86 GT86 General Forum 3 04-24-2012 12:53 PM
