Old 01-03-2014, 02:26 PM   #729
kayoh
kayoh's Avatar
Drives: 2014 SWP Limited BRZ
Originally Posted by shiv@vishnu View Post
No plans on writing flexfuel code anytime soon. Still a lot more that we need to add first (enhanced logging, FL learning matrix, more diagnostic options, etc).
Our e85 maps are designed to be flexible between e60 and e90 but if you are looking to be flexible between e10 and e90, they won't do what you need them to.
Perhaps I'm understanding this wrong or perhaps asking the wrong questions(I'm a virgin when it comes to tuning). But my intent is to determine if there are maps that support a mixture of both e85 and 91 octane gas, as to avoid having to drain the gas tank before switching between the 2.
Thanks!
kayoh is offline   Reply With Quote
Old 01-03-2014, 02:32 PM   #730
Shiv@Openflash
Shiv@Openflash's Avatar
Drives: 2013 FRS
Thanks!
Regular gasoline is E10 (approx). And when you mix equal parts of E85, you get E47 ((85-10)/2). Which is a beyond the range that the E85 maps can handle. So yes, you can mix gasoline and E85 and let the ECU adjust fuel trims. But I wouldn't go below E60. Which means you'll need to run your tank reasonably low before changing fuel types. Not empty but reasonably low.
Shiv
Shiv@Openflash is offline   Reply With Quote
Old 01-10-2014, 02:18 PM   #731
TIE Pilot
TIE Pilot's Avatar
Drives: TIE interceptor; BRZ13
Can the wallpaper/background be customize? e.g. pain black.
"Speed has never killed anyone. Suddenly becoming stationary, that's what gets you." Jeremy Clarkson
TIE Pilot is offline   Reply With Quote
Old 01-10-2014, 02:24 PM   #732
nelsmar
Thanks!
If you are wantin to pump whatever you want whenever you want no it doesn't support this. Shivs map use fuel trims to compensate e85 consistency. But it doesn't do timing adjustments between. You wokld need something like ecutek for full flex fuel. It's actually not horribly difficult to add compensation maps for flex sensors in ecutek either.
My flickr - Canibeat
Local magazine scout
Old 01-10-2014, 02:25 PM   #733
Shiv@Openflash
Drives: 2013 FRS
We can customize it when the units are being configured for sale. But currently the user has no option of customizing in the field. I could release a template file for those who want a black background. But I haven't received any other requests like that.
Old 01-11-2014, 01:21 AM   #734
Luckrider
My Other Ride's a Jeep
Luckrider's Avatar
Drives: 2013 BRZ Limited
The real question is, how do we modify the .SLT files so we can make our own buttons and backgrounds ourselves?
Luckrider is offline   Reply With Quote
Old 01-13-2014, 11:28 AM   #735
TIE Pilot
TIE Pilot's Avatar
One more odd question if i may. Does OFT touchscreen uses 4-pin (1 mm) ribbon connector?
Old 01-13-2014, 12:05 PM   #736
Shiv@Openflash
Drives: 2013 FRS
This involves modifying the same template file described in my previous post. This is not user configurable at this time.
Old 01-13-2014, 12:05 PM   #737
Shiv@Openflash
Drives: 2013 FRS
Do you mean internally?
Old 01-13-2014, 12:15 PM   #738
TIE Pilot
TIE Pilot's Avatar
Yes, internally. (Odd) :-)
Old 01-13-2014, 01:33 PM   #739
sprintamx
Happy to make my first post a strong thumbs-up for OFT, their off-the-shelf tunes and Vishnu performance as a company. As a non-techi enthusiast I really appreciate the incredible user-friendliness of the OFT, matched by the availability of tunes and the continuing development of those tunes. As others have said, even Stage 1 smooths out the stock dip and power band and really perks up the car.
Thanks a bunch and keep up the great work!
Now, must . . . resist . . . the header . . .
sprintamx is offline   Reply With Quote
Old 01-13-2014, 01:42 PM   #740
Luckrider
Luckrider's Avatar
His question sounds to be in similar (if not more destructive) vain as mine. You have tempted the programmer in me to see if I can figure out your template I will probably open it up, play with it some and forget about even attempting it though. I like the new skeleton pic on the tablet.
Old 01-13-2014, 02:09 PM   #741
Shiv@Openflash
Drives: 2013 FRS
Thanks for the kind words! We are happy you are enjoying the OFT
Old 01-13-2014, 02:28 PM   #742
TIE Pilot
TIE Pilot's Avatar
OpenFlash Supercharger ...mmmmm
#lolwut, divinecomedy, dopeandcashcabinet, free shiv now, goddamitimissedit, golden cage, i missed the show, looks good, missed the fun, omgbbq, shiv 2016, thefatandthefurriest
Tablet on the dash ! TRD_86 Electronics | Audio | NAV | Infotainment 23 05-16-2015 03:48 AM
Tablet Install ThugNasty Electronics | Audio | NAV | Infotainment 4 04-13-2013 03:15 PM
Blutooth OBD II and a 9.7 tablet.. Scooby South Electronics | Audio | NAV | Infotainment 10 12-16-2012 08:11 PM
7.0 Tablet w/ Torque App Thatruth2001 Northwest 26 11-21-2012 11:53 AM
