Old 01-12-2014, 10:32 AM   #29
lexusb3
Drives: FRS
Originally Posted by ecko04 View Post
I am. Eneos Sustina 0w-20. Using it since my first oil change, nothing else has gone in it.
I've just heard bad stories with that weight!! So I went higher 10-40w lol. What boost level?
lexusb3 is offline   Reply With Quote
Old 01-12-2014, 10:51 AM   #30
ecko04
Seems Legit
ecko04's Avatar
Drives: Toyota
Here you go again taking a thread off topic. There are already countless threads on what oil for boost.
In all seriousness though, the tuner and shop I frequent, @ptuning, have stated time and time again that there's no need to change the oil weight when boosting for most people.
The motor was built with specific tolerances in mind. The choice of changing weight should be independent of boost and based on weather conditions and driving style. And of course use a good quality oil and filter. Hence the reason why I stuck with what I've been using.
UOA show that my decision has not caused any additional wear on the motor and the tune is working effectively. If anything changes I'll be sure to tell you.
No build thread. I don't want to be reminded of how much money I spent.
[insert profound quote here]
ecko04 is offline   Reply With Quote
The Following 2 Users Say Thank You to ecko04 For This Useful Post:
CSG Mike (01-12-2014), SkAsphalt (01-12-2014)
Old 01-12-2014, 10:53 AM   #31
lexusb3
Drives: FRS
I was just asking.
Old 01-12-2014, 10:55 AM   #32
mrk1
Drives: Sterling BRZ Ltd
Am I concerned about putting boost on my high comp motor, yes. Is it going to stop me, no. It's just another factor to be considered when building the setup.
The Build Thread
GT28RS - eBoost2 - 3.91 Final Drive - Supra LSD
mrk1 is offline   Reply With Quote
The Following 8 Users Say Thank You to mrk1 For This Useful Post:
CSG Mike (01-12-2014), dave77 (01-12-2014), lbroskee (01-13-2014), lexusb3 (01-12-2014), MAPerformance (01-12-2014), Pete156 (01-12-2014), SkAsphalt (01-12-2014), Sportsguy83 (01-12-2014)
Old 01-12-2014, 10:57 AM   #33
lexusb3
Drives: FRS
Very nice way to put it lol
Old 01-12-2014, 01:09 PM   #34
CSG Mike
CSG Mike's Avatar
Don't listen to your mechanic ever again if he told you 6psi max. All FI isn't the same.
6psi with an Innovate is not 6psi with a Vortech is not 6psi with Kraftwerks. 6psi with a T3/T4 60 trim is not with a 57 trim is not with a 50 trim is not with a GT3076R.
The guys pushing your stated 14-20psi are not doing so on pump gas.
This.
A Greddy T518Z 5 psi isn't the same as a Garrett GT42R 5 psi.
PSI is a pressure measurement, not a flow/volume/mass measurement.
Blow as hard as you can through a coffee stir. Difficult right? That's high PSI with little flow. Now blow through a normal straw. Much easier? That's medium psi with medium flow. Now blow as hard as you can with your mouth wide open. No resistance at all? That's low psi with big flow.
Which example moved the most air mass? Which one had the most pressure?
CSG Mike is online now   Reply With Quote
SilverSkyline210 (01-13-2014)
Old 01-12-2014, 01:10 PM   #35
CSG Mike
CSG Mike's Avatar
Old 01-12-2014, 02:32 PM   #36
dave77
Big Member
dave77's Avatar
Drives: 2014 FR-S
ok thanks for the replies. just was wondering if people were actually aware of this potential issue and what they thought about.
still, what do people think about Subaru lowering the compression on their oem fa20 turbo motor? Why not just do it high compression if it is so safe?
dave77 is offline   Reply With Quote
Old 01-12-2014, 02:36 PM   #37
mrk1
OE setups are always engineered for a larger margin of safety compared to what the aftermarket will push.
Subaru also gets to just say, "make the new motor X compression ratio". The aftermarket has to spend thousands to build the motor to there desired ratio.
The Build Thread
The Following User Says Thank You to mrk1 For This Useful Post:
Old 01-12-2014, 02:39 PM   #38
s2d4
s2d4's Avatar
because people in the US will put in gallons of piss?
The Following 4 Users Say Thank You to s2d4 For This Useful Post:
coyote (01-12-2014), diss7 (01-13-2014), JackSmiley (01-13-2014), wparsons (01-12-2014)
Old 01-12-2014, 04:05 PM   #39
WHITE
Thats pretty neat
WHITE's Avatar
Drives: LOADING......
Simple answer,
The people who arent concerned are one of two types of people.
1. Wealthy or dont care.
2. Understand how an engine works and know how far it can be theoretically pushed.
High compresssion + turbo isnt some new thing that started with the frs/brz....people have been doing it for years.
WHITE is offline   Reply With Quote
The Following 3 Users Say Thank You to WHITE For This Useful Post:
CSG Mike (01-12-2014), JackSmiley (01-13-2014), wparsons (01-12-2014)
Old 01-12-2014, 06:08 PM   #40
StormTrooper
StormTrooper's Avatar
Drives: Pavement MT GR86
From what i understand there is a lower limit for the amount of boost based on several things including compression ratio. VVT DI head flow ect.
not sure about the upcoming wrx but the forester dit has been tuned to allow for 87oct aka piss water.
GR86 MT premium
StormTrooper is offline   Reply With Quote
Old 01-12-2014, 06:52 PM   #41
RAN94A
Grand PooBah
RAN94A's Avatar
Drives: Toyota 86 GT MT
I'm not an expert at all on engines
This is why you are worried and we are not
RAN94A is offline   Reply With Quote
Old 01-12-2014, 07:06 PM   #42
RAN94A
Grand PooBah
RAN94A's Avatar
Originally Posted by OjiGeorge View Post
Don't forget WMI. It seems to be underused on this platform with FI.
This is my next planned power mod
FBM 604Hp 472Tq -- Stock Motor Stage 2 Turbo Kit FullBlown Forced Induction 414 07-14-2014 09:52 PM
Frs300 Fa20club built motor and turbo build Frs300 Member's Car Journals 32 01-18-2014 05:27 AM
Crawford Limited Turbo BRZ - built motor Mrqb22 Forced Induction 8 11-11-2013 01:34 PM
Building a motor before turbo? ikeryder13 Forced Induction 25 11-04-2013 09:04 AM
Anybody else thinking about buying crawfords rebuilt motor and turbo? Frsexxxy Forced Induction 21 05-29-2013 04:07 AM
