Old 01-12-2014, 12:25 PM   #15
HD86
Drives: 2014 Raven FR-S
Originally Posted by VesperLynn View Post
Burning the clutch...?
Unfortunately, I am driving an automatic. My excuse, traffic
HD86 is offline   Reply With Quote
Old 01-12-2014, 03:54 PM   #16
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
Originally Posted by HD86 View Post
One last thing, do you guys know if fixing a coolant leak would take a long time? as in requiring my car to stay at the dealer ship overnight, since I kind of need the car to get back home.
They should give you a rental if they keep it overnight for warranty work. The biggest thing you have to fear is if they are a lazy dealership and feed you a 'don't worry about it' line. Check all your fluids, oil, brakes, transmission, if they're above the minimum mark you may have just had a fluke.
Since you're driving an Automatic it can't be that plate mentioned above, and that doesn't leak enough oil to get visible smoke though and that seems to have been sorted out well before the '14 model.
Coolant level fluctuates, if it's at half I wouldn't guess that was the issue, you need quite a bit of fluid to get visible smoke for more than a few minutes. Only you know how much wiper fluid you've used. I'm really rather baffled by this. Hope it works out.
Edit: Since you didn't check the fluids yourself to begin with I'd wager that's something you're not happy to go do, give the dealership a shot at diagnosing before you take matters into your own hands.
ineedyourdiddly
Old 01-12-2014, 05:26 PM   #17
HD86
Thanks, I have actually only used the wiper fluid once. I feel like the dealership I bought my car from didn't prep the car properly before giving it to me. One more thing, do you know if I would need to pay for the rental car or would it be covered under the warranty? I want to be semi-prepare when going to the dealership tomorrow.
Old 01-12-2014, 07:29 PM   #18
..........One last thing, do you guys know if fixing a coolant leak would take a long time? .
Well, HD86 ..... that would depend on where it is leaking. If it's a head gasket, it could take a couple of weeks.....if it's a lose hose clamp, a couple of turns with a screwdriver might fix it.
Back in the day, we used to put dry oatmeal in the radiator to "fix" minor leaks, till we could get a new hose.
Yep, the oatmeal would swell up and plug up small leaks.
OK - OK - I'll go take a nap .....
Evil Jesus (01-12-2014)
Old 01-12-2014, 09:14 PM   #19
Ganthrithor
Ganthrithor's Avatar
Drives: '13 BRZ, '06 997, Other Things(TM)
If they're a good dealer they should probably supply you with a free loaner car while they're working on yours. My area Subaru dealer offered me a loaner for the day when I brought my car in for a fluids change.
At the very least they should give you a shuttle home if you live near the dealer. The VW dealer I took my GTI to in Denver gave me a lift to and from home and that car wasn't even in warranty...
Ganthrithor is offline   Reply With Quote
Old 01-13-2014, 02:31 AM   #20
strat61caster
It should be free. You should call ahead and ask.
ineedyourdiddly
Old 01-13-2014, 06:02 PM   #21
HD86
Here is an update, I have been at the dealership for around 2 hours and they just found out it is an oil leak and now they are trying to find out where the leak is coming from. I have to say, I am a tad disappointed with my very first toyota considering I bought it brand new.
The Following 3 Users Say Thank You to HD86 For This Useful Post:
mwjcyber (01-13-2014), scionfrs2014 (01-14-2014), strat61caster (01-14-2014)
Old 01-13-2014, 08:19 PM   #22
Thanks for the update. Let's hope it can be fixed by tightening something up ....
Old 01-13-2014, 09:04 PM   #23
HD86
It actually turned out to be something (I forgot which part it was) was crushing the washer in the oil passage tube, which cause an oil leak onto the exhaust which causes the smoke and burning smell. They said that they have to order parts to fix it and it would take like 2 weeks for the parts to be here. In the mean time, they patched it up a little to decrease the amount of oil that is leaking.
Thank you everyone for your replies, it helped me a lot in knowing more about the issue my car is experiencing.
The Following 4 Users Say Thank You to HD86 For This Useful Post:
anewprelusion (02-05-2014), humfrz (01-13-2014), m.wood0213 (01-13-2014), Mr.EvoMR (01-14-2014)
Old 01-14-2014, 09:37 PM   #24
Senor 86
Drives: 2013 Subaru BRZ
What a stroke of bad luck, but if it makes you feel any better. A couple took their Toyota 86's to the track and something happen to one of them, they ended up towing one back to the dealership. A couple of weeks later i saw them at the track again so it ended well.
Senor 86 is offline   Reply With Quote
Old 01-16-2014, 01:23 AM   #25
Ganthrithor
Welp. At least it sounds like it should be easily fixed!
Old 02-05-2014, 12:27 AM   #26
nos145
Cognite
nos145's Avatar
Drives: 2013 Whiteout FRS
If you ever get bad service at one dealership, take it to another.
I drive for 1.5 hours to a dealer in another city to service mine.
nos145 is offline   Reply With Quote
Old 02-06-2014, 01:22 PM   #27
Zero90
Zero90's Avatar
Drives: "14 BRZ Limited - SWP
Originally Posted by mwjcyber View Post
Your warranty covers all problems for 3 years or 36,000 miles. You also have a 5 year or 60,000 mile power-train warranty. This problem won't cost you, get it in asap.
Is this standard on all three cars? I have a 2014 BRZ and unsure if I need the 7 year 70k extended warranty. Dealer is pushing me t get it but it's an extra 3k.
Zero90 is offline   Reply With Quote
Old 02-06-2014, 02:29 PM   #28
mwjcyber
mwjcyber's Avatar
Drives: 13' Subaru BRZ Limited SWP 6MT
BRZ warranty is the same as FRS, minus the free service.
Code:
Basic                      3 year / 36,000 miles
Free Maintenance           N/A
Drivetrain                 5 year / 60,000 miles
Roadside                   3 year / 36,000 miles
Rust                       5 year / Unlimited miles
To me the extended warranty wasn't worth the added expense, as I plan to boost my car which will void the drivetrain warranty. Also figured I'd spend that money on upgrades instead. Funny thing is at the dealership they were offering a 7/70k extended warranty for ~$1,600, which I declined, but then a couple months after ownership Subaru sent me a 7/70k extended warranty offer for ~$800, but I believe the deductible was a little higher. FYI, my May 2013 BRZ Limited has been completely problem free, except for HPFP chirping.
An extended warranty is up to you. Thread discussing if it's worth it.
http://www.ft86club.com/forums/showthread.php?t=37937
mwjcyber is offline   Reply With Quote
billowingsmoke, hood, minorproblem, smell, smoke, white
White smoke coming from the exhaust. hansthegerman Engine, Exhaust, Transmission 17 10-02-2013 04:23 PM
Looking for vis aem hood or seibon fa hood ready to ship Frs32907 Cosmetic Modification (Interior/Exterior/Lighting) 2 07-29-2013 11:25 PM
Looking for Hood Dampers meant for CF hood. Vicious LED Scion FR-S / Toyota 86 GT86 General Forum 3 12-31-2012 02:47 AM
Smoke coming from the Exhaust peachsnow Scion FR-S / Toyota 86 GT86 General Forum 18 12-09-2012 02:59 AM
