Old 01-11-2014, 01:47 PM   #183
mrk1
Drives: Sterling BRZ Ltd
Originally Posted by JHarperFRS View Post
Have you ever thought of mass producing this brace, for sale ?
Yes I have, it could happen
The Build Thread
GT28RS - eBoost2 - 3.91 Final Drive - Supra LSD
mrk1 is offline   Reply With Quote
Old 01-11-2014, 02:00 PM   #184
mrk1
Forgot to add another picture, The lower pipe on the intercooler is just under 2.5" so the coupler wasnt getting a good seal. So I cut it off and welding on an actual 2.5" pipe with a nice bead roll on the end.
The Build Thread
Old 01-11-2014, 02:14 PM   #185
Dustin
Twin Screw You
Dustin's Avatar
Drives: 2013 Supercharged Whiteout FR-S
I'm sure I'm preaching to the choir here but weld where you can. Anywhere you have a rubber coupler leaves room for you to have boost leak at one point or another. A friend of mine bought a "plug and play" kit for his car that used rubber couplers and almost every one of them leaked no matter how much he tightened them. It wasn't until he went and had a shop fabricate his intercooler piping into a solid piece that it resolved his problems. I'm sure his was a worst case scenario, but a coupler will always be a weak spot.
Dustin is offline   Reply With Quote
Old 01-11-2014, 03:43 PM   #186
mrk1
Yes couplers are possible leaks but that's why my pipes line up just right and are bead rolled. I've never had an issue with any IC piping I have made. I'm 100% confident I will not have boost leaks in this setup. The best option is Wiggins clamps but they are almost comically exspensive. Vibrant does make a lower cost version but they are not offered in a wide range of sizes. Also durability is a strength of the stainless piping. It wont crush under a strong over tighened clamp.
Also all the points where the piping ends it's aluminum to steel. You can't weld those two together. Boost leaks are a very simple problem to avoid with a quality fitting kit.
The Build Thread
The Following User Says Thank You to mrk1 For This Useful Post:
shaunsweeney (01-11-2014)
Old 01-11-2014, 03:49 PM   #187
JHarperFRS
JHarperFRS's Avatar
Drives: 2013 Scion FR-S "White Out"
I know I'd buy a trunk brace ASAP, if you were to mass produce...Or just build me one. What would you charge to build me one and have it shipped to Dothan, Alabama USA ?
JHarperFRS is offline   Reply With Quote
Old 01-11-2014, 04:18 PM   #188
Dustin
Twin Screw You
Dustin's Avatar
It didn't even sink in when you said "on the intercooler". I thought you were referring to just the piping. My bad. Yeah aluminum to stainless is a no go. Proceed sir, proceed.
Old 01-11-2014, 04:44 PM   #189
shaunsweeney
shaunsweeney's Avatar
Drives: 2014 FR-S MT Asphalt Grey
Guys don't ask him about pricing on stuff. He isn't a vendor and we don't want him getting scolded for no reason. If you have questions PM him.
Thanks for this thread. It is nice to see your work. If you have some free time, I would love to talk to you about building me a turbo kit down the line. It would be more along the lines of the AVO kit location and turbo size wise. I'm looking for a clean and quick spooling setup that will hit hard by 3k until just before redline.
shaunsweeney is offline   Reply With Quote
Old 01-11-2014, 05:31 PM   #190
mrk1
Thank you for pointing out the vendor issue. I will probably have a conversation with who ever to see what it takes to be a vendor. But untill then yes there at reasons I can't discuss selling anything.
The Build Thread
Old 01-11-2014, 05:45 PM   #191
charged86
charged86's Avatar
could you make me that core support? and inlet for me??
INSTAGRAM @Rcf_700 www.youtube.com/boostindub
Old 01-11-2014, 06:44 PM   #192
mrk1
The core support could certainly be duplicated. What are you looking to use the intake with? Im actually thinking the duct in the picture maybe to large. I want to make sure plenty of air goes through the radiator and not over the top.
The Build Thread
Old 01-12-2014, 10:11 AM   #193
charged86
charged86's Avatar
Yeah I see what you mean. I just need to upgrade my air inlet and my intake for my new setup. So your saying the bar design will let too much air over the radiator?
Old 01-12-2014, 10:28 AM   #194
mrk1
The inlet being so big might let to much air over. I'm going to seal off the center between the inlet and the IC pipe.
The Build Thread
Old 01-12-2014, 11:09 PM   #195
charged86
charged86's Avatar
I gotcha. I'm interested to see
Old 01-13-2014, 12:18 PM   #196
mrk1
Been a while since I have done a bumper on mock up, here its the bumper loosely on to make sure the air duct clears.
The Build Thread
AMR Performance: How to remove the factory bumper (walk-through images inside) AMR Engine, Exhaust, Transmission 9 04-10-2013 07:45 PM
86 Modelista walk around and GT Limited SoCal_86 Scion FR-S / Toyota 86 GT86 General Forum 3 04-24-2012 11:53 AM
