Old 01-10-2014, 09:11 PM   #15
Calum
That Guy
Drives: 2013 asphalt FRS MT
Originally Posted by chutrain View Post
I met a guy that tracks with these and he highly recommended them. I picked up a set to replace my SPC set, but have yet to install them. I am only weary of the degree of camber adjustment.
Am I missing something with that camber adjuster? (serious)
Old 01-10-2014, 10:12 PM   #16
chutrain
chutrain's Avatar
Drives: WRB BRZ
I'll have to pull the arms out and take a look at closer.
In the garage:
1988 BMW E30 M3
2003 Ducati ST4s ABS
2006 Subaru Legacy GT Spec B #444/500 (For Sale)
2013 Subaru BRZ WRB Limited - Acquired 9/15/12
chutrain is offline   Reply With Quote
Old 01-11-2014, 11:20 AM   #17
JPxM0Dz
F Z1LLA
JPxM0Dz's Avatar
Drives: Lexus IS-F Series 2
Please post some pics if you get a chance
Thanks
2URGSE
JPxM0Dz is offline   Reply With Quote
Old 01-11-2014, 11:55 AM   #18
Calum
That Guy
Thanks
seconded
Old 01-11-2014, 12:31 PM   #19
FrsDuke
Fanboy
FrsDuke's Avatar
Drives: 2013 ultramarine frs
Won't the static friction of the main bolt take the load upon install? That little pin is just for setting the position not taking the load. I'm assuming the bushing has a metal center that everything clamps down on a bit.
I'm done helping those who won't help themselves.
TL;DR:
-Duke
FrsDuke is offline   Reply With Quote
Old 01-12-2014, 11:27 AM   #20
Calum
That Guy
That idea works with a strut to knuckle bolt because the those two parts remain stationary with respect to each other. But the control arms oscillate up and down and that bolt is the pivot point.
Old 01-12-2014, 02:27 PM   #21
FrsDuke
Fanboy
FrsDuke's Avatar
But the bolt doesn't pivot in the swing arm the bushing pivots on the bolt.
TL;DR:
-Duke
Old 01-12-2014, 03:24 PM   #22
Calum
That Guy
So your saying there's no relative motion between the arm and the bushing when the bolt is clamped down... You very well might be right.
Old 01-12-2014, 04:57 PM   #23
chutrain
chutrain's Avatar
Drives: WRB BRZ
Here are some pics. I think these should be fine. Like it better than the SPC that I am running now.
In the garage:
1988 BMW E30 M3
Old 01-12-2014, 05:02 PM   #24
FrsDuke
Fanboy
FrsDuke's Avatar
It's just the only way I can see it would work
TL;DR:
-Duke
Old 01-12-2014, 07:00 PM   #25
Shit Luck
Drives: red frs
the metal insert in the bushing is where the motion takes place. the bolts in the arm don't rotate.
Shit Luck is offline   Reply With Quote
Old 01-12-2014, 09:00 PM   #26
FrsDuke
Fanboy
FrsDuke's Avatar
Exactly
TL;DR:
-Duke
Old 01-12-2014, 09:22 PM   #27
Travisty75
Travisty75's Avatar
Drives: 2015 Scion FR-S
Anyone know what the camber range with these arms would be?
For the price, they look like an exceptional choice.
Travisty75 is offline   Reply With Quote
Old 01-13-2014, 09:56 AM   #28
JPxM0Dz
F Z1LLA
JPxM0Dz's Avatar
That's a good question, nothing listed under description or specs in the link
2URGSE
WTB: Cusco Rear Lower Control Arms that_guy Want-To-Buy Requests 0 09-30-2013 10:10 AM
ISC Rear Lower Control Arms FT-86 SpeedFactory Suspension | Chassis | Brakes -- Sponsored by 949 Racing 7 09-26-2013 09:47 AM
~~CUSCO Rear Lower Control Arms!!~~ nemesisdrift Brakes, Suspension, Chassis 2 05-20-2013 02:35 PM
DIY Request: Rear Lower Control Arms Ryaquinn DIY (Do-It-Yourself) Guides 2 05-08-2013 06:25 PM
SPC Rear Adjustable Lower Control Arms Bcarlos Suspension | Chassis | Brakes -- Sponsored by 949 Racing 11 04-19-2013 10:56 PM
