Old 04-17-2013, 07:32 PM   #1
Bcarlos
Drives: Frs
SPC Rear Adjustable Lower Control Arms
Hey all. Would like to know if anyone installed SPC Rear Adjustable Lower Control Arms. If so, did you use the toe bushing that was included? How well did it work? Or went with different route and purchased a seperate adjustable toe arm instead. Thanks!
Bcarlos is offline   Reply With Quote
Old 04-17-2013, 08:39 PM   #2
Shit Luck
Drives: red frs
i have them... not really the ideal solution to camber issues, no lower arm is though. they work decent for the price though.
ideally you want an adjustable upper arm, the lowers really affect toe at the same time they adjust camber due to changing the track width. i found i didnt need the bushing to get my car where i wanted it alignment wise.
Shit Luck is offline   Reply With Quote
Old 04-17-2013, 10:11 PM   #3
ShikoBariki
Drives: 89 240sx S13 SR20DET, 13 FR-S
Im trying to do the flush slammed look...depending on what set up im doing as far as wheel fitment and rims goes do you recommend and upper arm more than an LCA?
ShikoBariki is offline   Reply With Quote
Old 04-18-2013, 09:20 AM   #4
Wepeel
Drives: '13 BRZ Ltd
How stiff is the bushing in the SPC arm? Is it close to the poly aftermarket bushings?
Wepeel is offline   Reply With Quote
Old 04-18-2013, 10:06 AM   #5
ATL BRZ
TEQSPORT Brand Manager
ATL BRZ's Avatar
Drives: '24 GR86 + '16 FR-S
I have them; tracked them; love them for the ease of adjustability.
The bushings are much stiffer and beefier than the OEM bushings.
The toe bushings are NOT required to align the car properly.
Even vendors are using them and can vouch for them:
Originally Posted by Turn in Concepts View Post
We are using SPC arms on ours and they are working fine. I like the adjustment better on the SPC arms than anything else on the market.
Old 04-18-2013, 10:32 AM   #6
JoeBoxer
JoeBoxer's Avatar
Drives: Whiteout FR-S
You might like the Stance or GTSpec arms for the slammed look.
JoeBoxer is offline   Reply With Quote
Old 04-18-2013, 10:32 AM   #7
f0rge
head of infinite swagger
Drives: 2013 FR-S 6MT
I just ordered mine on monday, dropped the car on Sportlines and I have ridiculous rear camber. Glad to hear I don't need the toe bushing.
2019 Golf R 6MT - current daily...I need another coupe
2008 Civic Si - winter beater
2000 Silverstone M5 6MT - SOLD
2013 Ultramarine FR-S 6MT - Car Journal - SOLD
2004 AlpineWhite M3 6MT - SOLD
f0rge is offline   Reply With Quote
Old 04-18-2013, 12:22 PM   #8
Im_SPEED
Drives: FRS hot lava
I must disagree with this i couldn't get the car to align right with out putting the toe bushings in. and you get what you pay for after one adjustment the tac welds the hold that bar the the centric bolt ride on snapped off. the fitment is Honorable i have to pry them apart to fit rear strut in between the control arms. plus they just look flimsy. but you get what you pay for. i have used spc parts before and they have always been great quality but i must say im disappointed in these control arms
Im_SPEED is offline   Reply With Quote
Old 04-18-2013, 12:36 PM   #9
ATL BRZ
ATL BRZ's Avatar
Sounds like install error.
[ame]http://youtu.be/pQ5fCjMIfjI[/ame]
The cam nut shouldn't require that much effort to turn when installing the arms correctly. You're supposed to tighten only the outer hub bolt before putting the wheels back on and lowering the car back onto the alignment rack, then proceeding to adjust the arms as necessary. Having a proper alignment rack is critical to minimizing the effort in adjusting the cam nuts and dialing in the alignment since they feature pads that the wheels sit on and float/move around based on adjustments being actively made.
Old 04-19-2013, 12:32 PM   #10
Shit Luck
Drives: red frs
I am waiting on a warranty arm as the tab also sheered off on one of my arms. The welds were pathetic. The was no indication of heat penetration on the parts. I would have tig welded it myself but I didn't have time to spend on it that day.
I will replacing mine with reinforced stock arms and adjustable uppers asap.
Old 04-19-2013, 02:06 PM   #11
f0rge
Where are you seeing adjustable uppers? Or do you mean the Whiteline bushings?
Old 04-19-2013, 10:56 PM   #12
Shit Luck
Drives: red frs
racer x fab
ROBISPEC Front ADJUSTABLE tubular lower control arms robispec Suspension | Chassis | Brakes -- Sponsored by 949 Racing 75 04-05-2015 09:36 AM
Adjustable rear upper control arms??? Supermassive Suspension | Chassis | Brakes -- Sponsored by 949 Racing 28 09-29-2013 09:17 AM
SPC rear lower control arms, Fix your camber! JoeBoxer Brakes, Suspension, Chassis 12 03-31-2013 07:02 PM
Delete driver01 Brakes, Suspension, Chassis 11 02-06-2013 01:56 PM
cusco rear lower control arms for FR-S BRZ driver01 Canada Classifieds 3 02-01-2013 05:28 PM
