F Z1LLA
Drives: Lexus IS-F Series 2
Has anyone heard of these guys or had any experience with these ?
http://www.jhpusa.com/store/pc/viewP...dproduct=12464
2URGSE |
Kouki-Monster
They make AFAIK one of the best if not the best LCA's for Honda's
Rich Anderson
EMPOWER AUTO |
| The Following User Says Thank You to empower-auto For This Useful Post: | JPxM0Dz (01-10-2014) |
86-er
Drives: BRZ tS
Hell yea that's awesome. Function 7 is very reputable in the Honda/Acura scene.
2018 Subaru BRZ ts 020/500 - My Daily, work car, and track car
Drives: 2013 Raven FRS 2JZ-GTE/V160 swapped
Those look very sexy
#5 | ||
Twin Screw You
Drives: 2013 Supercharged Whiteout FR-S
F Z1LLA
Thanks for the positive input guys, I'm really digging these
2URGSE |
86-er
Drives: BRZ tS
Great price too
| The Following User Says Thank You to *KID* For This Useful Post: | JPxM0Dz (01-10-2014) |
That Guy
Drives: 2013 asphalt FRS MT
#10 |
#11 |
Drives: red frs
been on my list to order.
#12 |
Drives: WRB BRZ
I met a guy that tracks with these and he highly recommended them. I picked up a set to replace my SPC set, but have yet to install them. I am only weary of the degree of camber adjustment.
In the garage:
1988 BMW E30 M3 2003 Ducati ST4s ABS 2006 Subaru Legacy GT Spec B #444/500 (For Sale) 2013 Subaru BRZ WRB Limited - Acquired 9/15/12 |
#13 |
Drives:
it does not look like much camber adjustment and to me seems a little difficult for the alignment.
#14 |
That Guy
The camber adjuster wont work. First, unless the adjuster eccentric is adjusted so that the bolt is jammed into the end of the arm, and the eccentric is jammed against the set screw, the arm will be able to move axially. Secondly, they're using a set screw that doesn't even seem to be threaded all the way through the arm, as a bearing surface absorbing all force transmitted along the length of the arm and the friction of the arm moving about that pivot point. I'd be shocked if that arm made it five minutes down the road before the set screw was either snapped off or just pushed out of the aluminum.
| WTB: Cusco Rear Lower Control Arms | that_guy | Want-To-Buy Requests | 0 | 09-30-2013 10:10 AM |
| ISC Rear Lower Control Arms | FT-86 SpeedFactory | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 7 | 09-26-2013 09:47 AM |
| ~~CUSCO Rear Lower Control Arms!!~~ | nemesisdrift | Brakes, Suspension, Chassis | 2 | 05-20-2013 02:35 PM |
| DIY Request: Rear Lower Control Arms | Ryaquinn | DIY (Do-It-Yourself) Guides | 2 | 05-08-2013 06:25 PM |
| SPC Rear Adjustable Lower Control Arms | Bcarlos | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 11 | 04-19-2013 10:56 PM |
