Old 01-08-2014, 08:29 PM   #169
mrk1
Drives: Sterling BRZ Ltd
Originally Posted by mad_sb View Post
Hey,
You know that IC core mounting has the flow going opposite the way it does on the OEM application? Not sure it will matter as i don't recall the fin layout on those cores but just thought i would mention it... Stock application the charge flows in the vertical inlet and out the horizontal...
Assuming the core is non directional, that is better routing than most kits i have seen. Is there room in the bay to clock the compressor housing about 80 degrees so that the charge pipe comes off under the filter?
I've never heard of a directional core. From cleaning it out after the welding it flows the same either direction as far as I can tell. I certainly plan on replacing the intercooler with a better aftermarket core. The Evo core was only used to save some cash. IC cores are pretty expensive.
I could spin the housing around but then that would put the piping closer to the hot manifold and the external waste gate. It would also ad another bend to go up and over the frame rail.
The Build Thread
GT28RS - eBoost2 - 3.91 Final Drive - Supra LSD
mrk1 is offline   Reply With Quote
Old 01-08-2014, 08:38 PM   #170
mrk1
Not for me, but I would like to be able to mount some sort of noise barrier to the brace to cut down on cabin noise from the trunk area. If the total weight of the brace and barrier was the same as or less than the oem seat back that would be a big win. I think the OEM seat back is near 20 lbs??
Awesome work btw.
I can weight both of them tomorrow. Im certainly thinking of doing a AL version after all this stainless is killing my hole saws.
The Build Thread
Old 01-08-2014, 08:57 PM   #171
Pete156
I like to eat!
If anyone can overcome this issue, you can!
Pete156 is offline   Reply With Quote
Old 01-08-2014, 09:06 PM   #172
White64Goat
read my mind................
The Following 2 Users Say Thank You to White64Goat For This Useful Post:
Hyper4mance2k (03-22-2015), Meehow86 (01-10-2014)
Old 01-08-2014, 09:11 PM   #173
mush
mush's Avatar
that rear brace tho!
Old 01-08-2014, 09:48 PM   #174
mrk1
Originally Posted by White64Goat View Post
Attachment 62849
Haha, actually this picture was taken from the chair at my welding table. I stopped welding because I had that feeling someone was watching me. He is a ninja sometimes.
The Build Thread
The Following User Says Thank You to mrk1 For This Useful Post:
shaunsweeney (01-08-2014)
Old 01-08-2014, 09:51 PM   #175
mrk1
I've been calling every tool supply company lookng for something more durable. There are plenty of stronger saws but they won't mount on the tubing notcher I use. Everyone tells me it's time to upgrade to a mill.
The Build Thread
Old 01-10-2014, 03:55 PM   #176
mrk1
Stole a little time today for the BRZ. Since I plan to leave the filter right on the turbo I wanted to build a fresh air duct. Also ordered a bunch for parts to gets this project over the hill. Spal fans, TurboSmart clamps, eBoost2 boost controller.
The Build Thread
The Following 3 Users Say Thank You to mrk1 For This Useful Post:
hamzam (08-25-2015), Redlinedfrs86 (01-11-2014), solidONE (01-10-2014)
Old 01-10-2014, 05:10 PM   #177
solidONE
solidONE's Avatar
Drives: FR-S Whiteout
Hare you using pulsed DC TIG or non pulsed for the thin awg material?
I have made a front triangulated bar using thin walled 4130 tube myself and would like you to critique it. I will post up photos later.
Old 01-10-2014, 05:24 PM   #178
mrk1
Non pulsing, my syncrowave doesn't have it. I see the value in it but I think to many guys use it as a crutch.
Go ahead and post what your working on. I don't do much cromo work but I'll take a look.
The Build Thread
Old 01-10-2014, 11:51 PM   #179
solidONE
solidONE's Avatar
You have PM.
Old 01-11-2014, 03:21 AM   #180
NYCsubaruBRZ
Drives: 2013 Subaru BRZ & 99' Ford Explorer
get him a mask and open up the brz's mouth like me!! (last pic)! sickkk work. im tuned in to see whats next
NYCsubaruBRZ is offline   Reply With Quote
The Following User Says Thank You to NYCsubaruBRZ For This Useful Post:
M-17 (01-27-2014)
Old 01-11-2014, 08:34 AM   #181
mrk1
^^^ I definelty want to make some air flow improvements. I'm kinda jealous of the larger mouth on the FRS. However I'm not allowing myself to cut any factory parts to make this kit work. If I cut a bumper I will find a second one to alter.
The Build Thread
Old 01-11-2014, 11:24 AM   #182
JHarperFRS
JHarperFRS's Avatar
Drives: 2013 Scion FR-S "White Out"
Rear seat brace...
Have you ever thought of mass producing this brace, for sale ?
JHarperFRS is offline   Reply With Quote
AMR Performance: How to remove the factory bumper (walk-through images inside) AMR Engine, Exhaust, Transmission 9 04-10-2013 07:45 PM
86 Modelista walk around and GT Limited SoCal_86 Scion FR-S / Toyota 86 GT86 General Forum 3 04-24-2012 11:53 AM
