Old 12-18-2013, 12:03 AM   #155
Slartibartfast
Klaatu barada nikto
Slartibartfast's Avatar
Drives: Raven FR-S MT
Wow, just found this thread, and read it start to finish. I have so much respect for those with the talent and time to do their own fabrications. I have lots of ideas of how I want things, but no skill, tools, time, garage, or wisdom to do it myself. I have to rely on aftermarket manufactures to predict my wants and needs. Maybe (hopefully) when I retire I'll be able to work on things like this. In the meantime, GREAT WORK. So much respect.
Subbed to thread.
... and yeah, I want the rear brace too.
I vow to do no harm.
2013 Raven FR-S Manual "Lenore"
1985 Silver RX-7 GSL-SE (Gone and missed)
Slartibartfast is offline   Reply With Quote
The Following User Says Thank You to Slartibartfast For This Useful Post:
mrk1 (12-19-2013)
Old 12-19-2013, 06:10 PM   #156
mrk1
Drives: Sterling BRZ Ltd
Originally Posted by TheLaughingMan View Post
haha I like how most of us just completely fall in love with the rear brace and think it's amazing. probably seems easy to OP compared to the ENTIRE TURBO KIT he's building lol
Yeah its pretty straight forward to make one, doing production level runs raise different obstacles but its certainly possible.
The Build Thread
GT28RS - eBoost2 - 3.91 Final Drive - Supra LSD
mrk1 is offline   Reply With Quote
Old 12-19-2013, 06:16 PM   #157
mrk1
Pretty small update but I got the time to locate the blow off on the upper charge pipe. Also you can see the offset K&N filter on the turbo, there will be a fresh air duct as well.
The Build Thread
The Following User Says Thank You to mrk1 For This Useful Post:
Evil Jesus (12-20-2013)
Old 12-20-2013, 03:37 PM   #158
mrk1
The supervisor was at the shop today so I had to get some work done.
Just about done the catch can.
Made a super simple bracket that sandwichs under the battery to mount the can
Also welded on a IAT bung in the upper charge pipe so that decides that the car will be tuned speed density. I was going back and forth for a while on that.
The Build Thread
The Following 6 Users Say Thank You to mrk1 For This Useful Post:
Diode Dynamics (01-08-2014), Evil Jesus (12-20-2013), Gusto (12-23-2013), Manic (01-08-2014), saj (02-28-2016), shaunsweeney (01-08-2014)
Old 12-20-2013, 03:41 PM   #159
MAPerformance
Drives: Asphalt FRS
It's starting to come along!!! Cute puppy BTW
MAPerformance is offline   Reply With Quote
Old 12-20-2013, 03:58 PM   #160
mrk1
Thanks, project is kind of on a holiday hiatus, got to get the paying jobs done before my own.
The Build Thread
MAPerformance (12-20-2013)
Old 12-23-2013, 12:59 PM   #161
mrk1
Little update on the rear brace, I changed up the top section and brackets. Should be even stronger then before. I also changed up the lower bracket to be lighter without compromising strength.
The Build Thread
The Following 5 Users Say Thank You to mrk1 For This Useful Post:
CARNZ (02-08-2014), Evil Jesus (12-23-2013), Gusto (12-24-2013), Richyjc (02-11-2014), TRD_07 (12-24-2013)
Old 12-23-2013, 01:55 PM   #162
Pete156
I like to eat!
Very, very nice work. Kudos!
Pete156 is offline   Reply With Quote
Old 01-08-2014, 04:36 AM   #163
shaunsweeney
shaunsweeney's Avatar
Drives: 2014 FR-S MT Asphalt Grey
Wow simply amazing work and local to boot! I may be getting touch with you in the near future.
shaunsweeney is offline   Reply With Quote
Old 01-08-2014, 04:08 PM   #164
mrk1
Getting back to the project now, today I put together a large list of stuff and material that needs to be ordered. Also welded up the intercooler piping.
In other car news I have ordered a set of 17x9 Team Dynamics to replace the 17x7's I have now. Same color and style as I have now but I have to make room for some more rubber. Planning 255's. Team Dynamics makes wheels to order in your choice of offset, bore, and bolt circle. Pretty sweet deal, no spacers or rings here.
The Build Thread
Old 01-08-2014, 04:57 PM   #165
mad_sb
Drives: 2013 Asphalt FR-S
..To the people who like the brace, is rear seat functionality a big part of the interest. To keep the seat functional is a compromise in design. Removing the seat back completely would allow for a stronger lower bracket.
Not for me, but I would like to be able to mount some sort of noise barrier to the brace to cut down on cabin noise from the trunk area. If the total weight of the brace and barrier was the same as or less than the oem seat back that would be a big win. I think the OEM seat back is near 20 lbs??
Awesome work btw.
Old 01-08-2014, 05:12 PM   #166
mad_sb
Mocked up the intercooler piping today, I dont think I have seen anyone else do this routing.
Hey,
You know that IC core mounting has the flow going opposite the way it does on the OEM application? Not sure it will matter as i don't recall the fin layout on those cores but just thought i would mention it... Stock application the charge flows in the vertical inlet and out the horizontal...
Assuming the core is non directional, that is better routing than most kits i have seen. Is there room in the bay to clock the compressor housing about 80 degrees so that the charge pipe comes off under the filter?
Old 01-08-2014, 06:35 PM   #167
Touge Factory
Touge Factory's Avatar
Drives: ZN6
Send a message via AIM to Touge Factory
Great welds!
Touge Factory is offline   Reply With Quote
Old 01-08-2014, 08:18 PM   #168
mrk1
Originally Posted by Touge Factory View Post
Great welds!
Thanks, I've been playing with new purge welding setups
The Build Thread
AMR Performance: How to remove the factory bumper (walk-through images inside) AMR Engine, Exhaust, Transmission 9 04-10-2013 07:45 PM
86 Modelista walk around and GT Limited SoCal_86 Scion FR-S / Toyota 86 GT86 General Forum 3 04-24-2012 11:53 AM
