Old 01-07-2014, 09:22 PM   #113
FrsDuke
Fanboy
FrsDuke's Avatar
Drives: 2013 ultramarine frs
This is how open source tune development works. Early adopters deal with growing pains, but reap huge benefits down the line. By all means switch to gas for a while or try your hand at the changes that are working for others. It's all free. Enjoy it.
I'm done helping those who won't help themselves.
TL;DR:
-Duke
FrsDuke is offline   Reply With Quote
Old 01-07-2014, 10:48 PM   #114
garfull
garfull's Avatar
Drives: FRS(sold), AP2, R35, FJC, ED9
wow romraider tables are so much more descriptive than the tunerpro app.
Originally Posted by Terrapin77 View Post
So instead of admitting defeat & going back to 93, I increased the cranking tables in my map by 10 to 20 percent. I did this to the all coolant levels 32 & below. It's 20 degrees in Atlanta right now and the car started on the 1st try. It did gurgle a little bit but at least it started right up. Here is a screenshot of my cranking tables
garfull is offline   Reply With Quote
Old 01-08-2014, 12:48 AM   #115
steve99
Drives: FT86
Anyone know if G series (Australian/European BRZ) ROM allows monitoring of IAM via OFT yet ?
Old 01-08-2014, 01:02 AM   #116
Fizz
Senior Addict
Fizz's Avatar
Drives: 86 GT
Can someone explain why we need to monitor IAM after flashing? Is it necessary?
Fizz is offline   Reply With Quote
Old 01-08-2014, 01:29 AM   #117
steve99
Drives: FT86
Have a read here
http://www.romraider.com/forum/topic1840.html
Basicly if you IAM (ignition advance multiplier) drops rapidly and stays low it indicates significant knock is being detected and the ECU is managing the knock. Can indicate the tune (timing/fueling) is too aggressive and/or the fuel you are using is not of sufficient octane rating to handle the tune.
hope that helps (I am no expert, only have a basic grasp of it)
Old 01-08-2014, 01:53 AM   #118
Fizz
Senior Addict
Fizz's Avatar
Drives: 86 GT
Hmmm....my preference is "flash and forget"....coz I simply don't want to bother about monitoring the IAM or anything else ecu/tune related once it's flashed. But it appears that this exercise is part and parcel of ecu tuning?
Old 01-08-2014, 01:58 AM   #119
Shiv@Openflash
Shiv@Openflash's Avatar
Drives: 2013 FRS
99.9% of our customers flash and forget. That is perfectly fine.
Shiv@Openflash is offline   Reply With Quote
Old 01-08-2014, 01:58 AM   #120
Ondreiko
RWD addicted
Ondreiko's Avatar
Drives: BRZ 6MT OFT OFH
Hi!
If you are asking about ignition advance multiplier, then it is NOT available among G-series ROMs yet.
But we expect it in some future to be workable as Shiv promised.
Ondreiko is offline   Reply With Quote
Old 01-08-2014, 01:59 AM   #121
FrsDuke
Fanboy
FrsDuke's Avatar
This early in development it is to be expected. Down the road it is less likely, but anytime you push the envelope it is a good idea to verify. Cars are as repeatable as they've ever been but still no two are exactly alike.
TL;DR:
-Duke
Old 01-08-2014, 05:45 PM   #122
RSH
Drives: 2014 BRZ Limited
I've seen about a 3 mpg drop in average fuel mileage running this tune. Just to be sure I babied it for a tank. Anybody else seeing this?
RSH is offline   Reply With Quote
Old 01-08-2014, 06:15 PM   #123
Malt
Drives: 2015 WRX
How long has it been since you flashed? It may take a bit of time for the LTFT's to adjust to conditions and if you were running rich for a portion of the tank until the ecu adjusted for it then your mpg's may suffer.
Malt is offline   Reply With Quote
Old 01-08-2014, 06:31 PM   #124
mad_sb
Drives: 2013 Asphalt FR-S
Good work man, My tables have WAY more pulse width in them.... mainly because my local station is pumping E95.............. despite it only being around 60 in the AM's here I am about 40% - 45% more pulse width than stock to get a clean 1st key start. If I splash blend it down to E80 it takes a lot less. My old station in atlanta was pumping E70ish in the winter i think...
For those that are playing with these tables, don't be scared, just add 5ms at a time to the area you start having trouble and remember the higher the E content the more pulse width is needed.
Old 01-08-2014, 06:33 PM   #125
R2
I'm going to go out on a bit of a limb and say it is likely related to the recent colder temperatures outside. As a reference, my fuel consumption averages ~30% more in winter than summer. In the -30C stuff we've been having lately it has been close to 50% more consumption.
R2 is offline   Reply With Quote
Old 01-08-2014, 06:38 PM   #126
mad_sb
Originally Posted by Indestruct View Post
I'm on my second tank of e85 and i'm starting to get the failed starts. I had to press the starter 3 times one time, kind of embarrassing cuz i had a female in the car lol.... The sputter/slow start is normal now. I'm hoping SHIV will incorporate the changes other users are doing for cold starts or else this will be my last tank of e85...
a couple things...
1. IMO a few key turns / button presses is well worth the extra power E provides
2. Have you tested your supply of E85 to get a better idea what % they are pumping?
3. At what temp do you start having issues?
4. Download rom raider and tweak the cranking enrichment tables, add 5ms at a time in the cells at the temp you are having problems and lower.
OpenFlash Tablet Rombinhood@OpenFlash Software Tuning 1838 07-29-2023 06:35 PM
Openflash Tablet v1.31 beta maps (including Stage 2!) now available for download Shiv@Openflash Software Tuning 354 02-08-2015 05:23 PM
OpenFlash Tablet E85 (and gasoline) Maps now available Shiv@Openflash Software Tuning 401 08-13-2014 11:14 PM
OpenFlash Tablet: new v1.40b maps, new website, new sales, oh my Shiv@Openflash Software Tuning 122 12-14-2013 10:17 PM
OpenFlash Tablet Stage 1 v1.2 maps available for download Shiv@Openflash Software Tuning 31 10-31-2013 08:45 PM
