Old 01-05-2014, 04:41 PM   #1
infinite012
Drives: 13 DGM BRZ Ltd
Allen key broke off inside rear strut...
So, I was changing my springs from RCE yellows back to stock a month ago and broke off my 5mm rounded allen key inside the rear strut. I have already tried tapping the strut upside down to try and get the little rounded hex bit out, but no luck. I've also tried to drill into it (the broken off bit) to try and fit an easy-out, but it seems to be harder than my drill bits (which are fresh out of the packaging).
Short of getting a new rear strut/spring assembly, what are my options? I wanted to put the RCE springs back on, but for obvious reasons cannot.
infinite012 is offline   Reply With Quote
Old 01-05-2014, 05:03 PM   #2
woode
Boosted Member
woode's Avatar
Drives: 2013 Subaru BRZ
Send a message via MSN to woode
Buy a better drill bit.
I know it sounds simple, but really thats all there is to it.. I drill out plenty of peoples fuck-ups every day at work (aircraft mechanic) and I assure you it can be done - don't give up so easily!
2013 Subaru BRZ LTD 6MT DGM
2014 Subaru XV Crosstrek Hybrid TRG PG
2011 Honda CBR1000RR
2010 Subaru Impreza WRX PRM SSM
woode is offline   Reply With Quote
The Following 2 Users Say Thank You to woode For This Useful Post:
Anthonytpt (01-07-2014), wparsons (01-05-2014)
Old 01-05-2014, 05:10 PM   #3
infinite012
Kinda figured I would need to do something simple like that. Got any suggestions as to material?
Oh, just heads up to everyone else: don't buy Kobalt (Lowes) tools. They'll break off inside your suspension and ruin your toys.
Old 01-05-2014, 05:44 PM   #4
Calum
That Guy
Drives: 2013 asphalt FRS MT
If it broke off while you were tightening, try a cobalt left handed drill bit.
Old 01-05-2014, 05:45 PM   #5
buckets
buckets's Avatar
Drives: infiniti g37x
Cobalt drill bit.
Edit: beat me to it.
buckets is offline   Reply With Quote
Old 01-07-2014, 01:38 PM   #6
Anthonytpt
Anthonytpt's Avatar
Drives: '13 Argento 6MT FR-S
Insanity wolf responds anyways.
Originally Posted by buckets View Post
Cobalt drill bit.
Anthonytpt is offline   Reply With Quote
Inside the Rear End is Shredded! DeOppressorLiber Issues | Warranty | Recalls / TSB 15 12-14-2013 10:49 AM
FS: Rear strut Bar 86design Brakes, Suspension, Chassis 9 07-27-2013 01:51 AM
FS: Rear strut bar! 86design Brakes, Suspension, Chassis 3 07-08-2013 02:57 PM
eliminate rear deck popping with rear strut bar? chenshuo Issues | Warranty | Recalls / TSB 11 07-03-2013 06:44 PM
Rear Strut Tower? swift996 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 2 11-25-2012 11:14 PM
