Drives: WRB BRZ
eliminate rear deck popping with rear strut bar?
My understanding is that strut bars stabilizes a car's chassis, do you guys thinking installing a rear strut bar can eliminate the rear deck popping noise?
I don't know about that but just last week my rear deck noise problem was finally corrected by my Scion dealer. They first used a new kind of lubricant on the metal cross brace under the package shelf. That didn't correct the problem. They then removed the papckage shelf and laid down adhesive foam rubber on top of the metal cross brace and that corrected the problem. Having owned my car since last September it's almost like having a new car. It is now totally problem free.
If your dealership has a problem understanding this, tell them to contact Desert Toyota of Tucson and they will explain the procedure to him. |
Drives: Over the hill WRX
My WRX has rear deck rattle and was cured with a rear strut bar. Don't know if the 2 issues are the same, but then BRZ is just another reincarnation of the Impreza.
Drives: JRSC'd Asphalt FR-S
No it doesn't, I have the Cusco rear strut bars on as well and I still get the popping noise, but I haven't had it much as of lately. You would need some lubricant to get rid of it. There was a tsb pdf on it.
#5 | |
Drives: Toyota 86 M High - Dark Grey
Sorry, when I get to Google I'm already over my head when it comes to the computer. Open the trunk, lean in and look up. You will see a metal cross member running across the car under the package shelf where the third brake ligh sets. The foam was glued to the top of that cross member, between it and the package shelf. They didn't insert it. They removed the package shelf, put the foam on top of the cross member and then put the package shelf back in.
#7 | |
Addicted
Drives: 2013 Asphalt FR-S 6MT
edit: looking at the TSB I think I'll do the procedure #1 myself and if that doesn't fix it I guess I'll bring it in as I don't want to remove my inner rear trim. I'm surprised I never noticed this issue till recently.. it's pretty annoying.
#8 | |
#9 | |
Addicted
#10 | |
p.s. It might help if Kerry knew whose car your man was calling about. I don't think he'd recognize whaap's FR-S. It's the FR-S owned by Bruce Powers that they did the fix on. Last edited by whaap; 07-03-2013 at 04:19 PM. |
| The Following User Says Thank You to whaap For This Useful Post: | l0aded (07-03-2013) |
#11 | |
When In Doubt...
Drives: Slowww
Join the Galaxy Blue Silica BRZ registry below: https://docs.google.com/spreadsheet/...2c&usp=sharing |
#12 |
| Rear Deck "popping/clicking/tapping/ticking" noise. | Sigh-on-Rice | Issues | Warranty | Recalls / TSB | 637 | 04-28-2020 04:55 AM |
| Subaru TSB 12-140-12 for Rear Deck Popping | sparks | Issues | Warranty | Recalls / TSB | 31 | 07-17-2013 11:11 AM |
| GTS rear left popping/clicking sound and fix. | sigmaoctantis | AUSTRALIA | 11 | 05-19-2013 06:58 AM |
| Rear deck popping/clicking | DriftEightSix | AUSTRALIA | 6 | 02-01-2013 01:59 AM |
| do you think the rear deck rattle... | pr086 | Issues | Warranty | Recalls / TSB | 7 | 08-03-2012 04:35 PM |
