Old 12-13-2013, 05:27 PM   #1
DeOppressorLiber
DeOppressorLiber's Avatar
Drives: FRS Full Blown Custom
Inside the Rear End is Shredded!
Change your rear diff fluid.
The Trypticon Transformation in Progress!
DeOppressorLiber is offline   Reply With Quote
Old 12-13-2013, 05:32 PM   #2
Krispeee
Do you mean the rear differential?
Krispeee is offline   Reply With Quote
The Following User Says Thank You to Krispeee For This Useful Post:
strat61caster (12-13-2013)
Old 12-13-2013, 05:36 PM   #3
N1rve
N1rve's Avatar
Drives: 2019 BMW ///M4
I was about to ask that same question.
Old 12-13-2013, 05:40 PM   #4
charged86
charged86's Avatar
pretty sure he means differential
INSTAGRAM @Rcf_700 www.youtube.com/boostindub
Old 12-13-2013, 05:50 PM   #5
Muskokan
Drives: white Sport-tech
Sooo what conditions do you drift in?
What mods?
Muskokan is offline   Reply With Quote
Old 12-13-2013, 05:53 PM   #6
humfrz
The OP is from the south and I'm guessing is over 50 years old ....
Yes, "rear end" OR "rear-end" ......
humfrz - from SOUTHERN Ohio
Old 12-14-2013, 01:51 AM   #7
Poodles
Drives: 2015 Series.Blue
Mmmmm... some wear is normal on a new car as the gears have to wear in. Pics would have been more helpful
Old 12-14-2013, 01:54 AM   #8
ZionsWrath
Thanks
ZionsWrath's Avatar
So then he should start checking his rear end about every 10 years at that age
The Following 4 Users Say Thank You to ZionsWrath For This Useful Post:
Apex-Wolf (12-14-2013), humfrz (12-14-2013), kludger (12-18-2013), SloS14 (12-14-2013)
Old 12-14-2013, 02:54 AM   #9
RFB
RFB's Avatar
Drives: FRS
MY REAR END BLEW AN O RING - OH MY GOD !
What to do !
Them torpedos work good (not the cream [no penetration]).
Preporation H is over hyped -
Oil change after break in is not.
Routine fluid replacement is healthy for all cars.
Sudden unexplained metal cancer is dubious.
I get suspicious about mods and trolls making wierd posts to generate forum activity.
Just because I'm paranoid doesn't mean there isn't a conspiracy !
Gotta change my diff oil again ! and again! and again ! and again ! -
Oh never mind think I'll have more beer instead ---------------------- hic brrrrp
RFB is offline   Reply With Quote
Old 12-14-2013, 03:01 AM   #10
kALMIGHTY
Drives: TRD Ultramarine '13
What exactly did it sound like? I might be having this issue...
Old 12-14-2013, 04:11 AM   #11
mfbmike
Drives: 2013 FRS, 2008 R32
Uh, countless threads showing people changing their diff fluid show metal shavings on the drain plug. It happens during break in.
/confused
mfbmike is offline   Reply With Quote
Old 12-14-2013, 06:08 AM   #12
Siege
1570/2500
Drives: 2013 FR-S 10 Series
It's not just the ring and pinion that are wearing during break in but also the internal gears of the Torsen differential.
The first fluid change will definitely have a large amount of material with following changes having significantly less.
Siege is offline   Reply With Quote
The Following User Says Thank You to Siege For This Useful Post:
DeOppressorLiber (12-14-2013)
Old 12-14-2013, 07:26 AM   #13
zooki
Drives: waiting on a 2021...
Changed my fluid @6K miles and it was just like you described. Changed it again @30K miles and it was a lot cleaner. Coming up on 40K miles and no problems.
2016 4Runner Tail edition
2020 Camry 2020 RAV4
2013 Chevy 3500 4x4 Duramax
1999 Ford F250 Powerstroke, the tow rig
1969 Mustang, the fast car....(:
zooki is offline   Reply With Quote
Old 12-14-2013, 09:18 AM   #14
Mikem53
Drives: FR-S 6MT
It's quite normal to have metalic paste and shavings on the mag drain plug for the diff when new. Gears, clutches breaking in, that's when most of the wear occurs..
But it seems you have an issue going on if u have noise and 30k+ miles
Mikem53 is offline   Reply With Quote
TWO 6-1/2" SPEAKERS INSIDE REAR SEATS GTR STYLE mmontes Electronics | Audio | NAV | Infotainment 19 03-06-2020 12:47 PM
Free-Rear bumper cover (entire rear facia) replaced after slight rear-end collision n7011n Exterior Parts (Aero, Lighting, Etc.) 7 03-26-2014 04:46 AM
Timing belt shredded..?! drei CANADA 5 12-06-2013 05:54 PM
Painting the inside of the FR-S DealerFR-S Cosmetic Modification (Interior/Exterior/Lighting) 21 07-10-2013 11:29 PM
I just died inside. DIG1992 BRZ Photos, Videos, Wallpapers, Gallery Forum 62 07-02-2012 08:51 PM
