View Poll Results: Which square or staggered setup should I go with?
18x9.0 +44 (square) 22 28.57%
18x8.5 +43 (F) / 18x9.0 +44 (R) (used on TWS demo car w/ recommended 245/35R18 square tires) 5 6.49%
18x8.5 +43 (F) / 18x9.5 +45 (R) 16 20.78%
18x9.5 +45 w/ 245/35R18 tires (square) 7 9.09%
18x9.5 +45 w/ 255/35R18 tires (square) 27 35.06%
Voters: 77. You may not vote on this poll
Old 12-10-2013, 05:47 PM   #43
Pokeguyjai
Pokeguyjai's Avatar
Drives: 2013 GBS BRZ (AT)
I was confused, I thought you meant you are rubbing the frame rails on the inside. I am really surprised you are still rubbing the spring perches. My advice is now to ditch those Yellows and Konis and get some Tarmac Zeros or another coilover with a smaller spring diameter.
Sorry I am a newb to the car world!
Thanks for the advice, I will look into it!
Sorry for the thread hijack, gents.
Pokeguyjai is offline   Reply With Quote
Old 12-10-2013, 10:02 PM   #44
Proof
Proof's Avatar
Drives: 2007 STI Limited / 2014 BRZ Limited
Blah I am dying to order wheels but cant figure out what square setup I can run. I know the info is everywhere. But does anyone know for a fact that 19x9.5 with 255s will clear a stock strut with say Swift Springs 1" drop?
Sorry for the newb jive.
Proof is offline   Reply With Quote
Old 12-11-2013, 09:39 AM   #45
DrDuquette
DrDuquette's Avatar
Drives: 2013 Premium White, 2006 TL
Question. I reading through and seeing square is the way to go. For many resale reasons. Do you guys run square wheels but then stagger the tires? Am I right is saying that the front is the issue when it comes to big sizes as compared to the rear. So say 18" all around, but like a 245 on the front and 255 on the rear. Yes I know you can't rotate, but resale on the wheels is still an option. And why don't I see many 9" wheels?
DrDuquette is offline   Reply With Quote
Old 12-11-2013, 09:57 AM   #46
djdnz
1337
Drives: 2013 BRZ WRB S/C
You can do whatever you like, but you cant rotate, it makes for different diameter front and back, promotes understeer and for a 10mm difference front to back its more headache than its worth.
9" wheels are around, but for whatever reason 9.5" seems to be more popular. I have 9"
djdnz is offline   Reply With Quote
Old 12-11-2013, 10:29 AM   #47
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
There are too many variables. Not all 255s are created the same and the offset of your 9.5" wheel will determine if you rub as well. If you really want to stay with the factory spring mounts, then I would recommend just stepping down to a 9" wheel which you can still run a 255 on.
Old 01-06-2014, 11:57 PM   #48
F1fletch
F1fletch's Avatar
Drives: 13 FR-S AT
I am quite intersted in the whole stagger vs square setups, this thread is great as I am exploring these wheels as well. I was leaning towards 8 & 9 but keep going back and forth..... I don't want anything sticking out and don't want rub with swifts lowered an inch.
The 245 tire is plenty for this car even with an extra dose of power. I have 245 super sports on the front of my 225is and they are plenty meaty on an 8.5 rim.
F1fletch is offline   Reply With Quote
Old 01-07-2014, 02:33 AM   #49
switchlanez
Glorious BRZ Master Race
switchlanez's Avatar
Drives: Subaru Libird
18x9.5 +45 will poke out a couple mm in front, and a hair or close to flush in rear. 18x9 +44 and 18x9.5 +45 won't clear the front if your Swift springs are on stock struts.
I would get 18x8.5 245/35 square for function>form or 8.5 245/35 | 9.5 255/35 staggered for form>function if you are keeping stock struts.
If you go with coilovers, 18x9 255/35 (or 245/35 square if you can live with a tiny bit of stretch) for conservative looks/function and no messing with alignment to get fitment right. 18x9.5 for slightly more aggressive looks and poke can be eliminated with conservative camber adjustments (either slotted holes or use of camber bolts but NOT both at the same time, camber plates optional but not necessary).
Before you select 255 or wider tires, be cognizant of their posted tread widths as some tires (such as MPSS) have wider tread width given the same tire sizing compared to, say, Hankook Ventus V12. People are known to rub on 255 tires with 9.5 +45 yet others have fit 265 or 275 (on 9.5 and around +42 and +43 ) with no rubbing and no fender mods/bumper trimming. It depends on a combination of alignment, offset, and tire selection. Also, wheels don't always measure exactly to their spec due to manufacturing variations.
Old 01-07-2014, 02:57 AM   #50
coyote
coyote's Avatar
Drives: Slowly
Originally Posted by Juvenile View Post
Dear TWS,
Where's my R&D fee?
Love,
Coyote
coyote is offline   Reply With Quote
Old 01-07-2014, 11:51 AM   #51
F1fletch
F1fletch's Avatar
Drives: 13 FR-S AT
Thanks Switch
Looks like 8.5F and 9R rear for me (I don't want any rubbing, even with midgets in back). I would push bigger than a 245 in back as 255 will def push things. In fact if I staggered the tires I would go 225/245.
PS - No offense meant to midgets or children as I love them both
WheelDude.com | Rota Torque - Staggered and Square setup - IN STOCK and ready to ship WheelDude.com Wheels and Tires 6 08-20-2013 09:34 PM
Square vs staggered setup slowbrz Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 10 05-11-2013 10:18 PM
Staggered wheels + square tyre setup? white_knight Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 10 03-18-2013 09:27 AM
Staggered vs. Square WWEVOX Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 24 01-12-2013 03:57 PM
Square or Staggered? dabocx Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 44 02-02-2012 09:40 PM
