Old 01-05-2014, 05:27 PM   #15
Snowblind
The paint on these cars is shitty and really thin. Consider yourself lucky if that's the only rock chip.
Old 01-05-2014, 05:30 PM   #16
goshem
goshem's Avatar
Drives: 16' WRX
just get some touch up paint + clearcoat and you'll be fine.
goshem is offline   Reply With Quote
Old 01-05-2014, 05:40 PM   #17
hotpanda1
hotpanda1's Avatar
Drives: 2013 scion FRS
and then 3M the entire front end of the car, if this mini chip bothers you lol
hotpanda1 is offline   Reply With Quote
Old 01-05-2014, 09:45 PM   #18
FRSure
Drives: Toyota
First chips are the most painful. What sucks is that I have less than 1000 miles and I get a big chip.
FRSure is offline   Reply With Quote
Old 01-06-2014, 11:30 AM   #19
RojerLockless
RojerLockless's Avatar
Drives: Raven Fr-s
You could always move to Texas where there's no snow
RojerLockless is offline   Reply With Quote
The Following User Says Thank You to RojerLockless For This Useful Post:
86-tundra (01-06-2014)
Old 01-06-2014, 02:29 PM   #20
gily25
Drives: Silica BRZ 6MT
Touch up paint. If you're not good at blending them in, ask a friend with an older car to practice on their car. Once you get the hang of it, they'll look less pimply. For slight pimples or roughness, you may be able to correct with a mild rubbing compound to even it out, then wax over it.
gily25 is offline   Reply With Quote
Old 01-06-2014, 09:45 PM   #21
BobRickel
Front bumper
Originally Posted by #944_10_Series_FRS View Post
I believe it is made with Polyurethane and not ABS. Although, they both plastic but the property is a little different.
Yes, I believe ABS stands for the mixture of Acrylic, Butyl, and Styrene.
BobRickel is offline   Reply With Quote
Old 01-06-2014, 09:51 PM   #22
sirsol66
Drives: 2013 FRS- Hot Lava
Apply touch up up with a tooth pick, slightly overbuild, give it a few days to cure 100%, sand VERY, VERY lightly with 2000 to smooth it out to surrounding paint and buff out the area with something like scratch X followed by Meguiar's UC. Works very well and will be generally invisible unless your right on top of the panel.
sirsol66 is offline   Reply With Quote
Old 01-06-2014, 09:54 PM   #23
#944_10_Series_FRS
#944_10_Series_FRS's Avatar
Drives: 2013 10 series FRS #944
You are correct. ABS is a rigid plastic, it will only flex so far before it cracks. On the other hand, Polyurathane is a flexible plastic, it will flex much, much more than ABS before it breaks and that the reason Polyurathane is used to make car's bumper. As for painting, since polyurethane is flexible, there is special additive added to the paint & clear coat to prevent cracking.
#944_10_Series_FRS is offline   Reply With Quote
Easy Oil Change kuhlka DIY (Do-It-Yourself) Guides 12 06-16-2014 01:39 PM
Well that was easy... FRyeS Scion FR-S / Toyota 86 GT86 General Forum 17 10-15-2013 11:04 AM
Easy to Do Mods steve87j Scion FR-S / Toyota 86 GT86 General Forum 23 12-23-2012 12:11 AM
Cheap, easy brake mod! CBR600RR Cosmetic Modification (Interior/Exterior/Lighting) 4 09-19-2012 07:39 PM
easy mod $15.00 2hrs and looks good francosolracer Scion FR-S / Toyota 86 GT86 General Forum 2 07-20-2012 01:04 PM
