Old 01-05-2014, 12:29 PM   #1
FRSure
Drives: Toyota
Anyway easy way to fix this?
Little rock chip from car kicking up debris from snow. What's the easiest way for a untrained person to fix this?
FRSure is offline   Reply With Quote
Old 01-05-2014, 01:22 PM   #2
993Fan
993Fan's Avatar
Drives: 2014 DGM BRZ MT
Unless the chips penetrate to bare metal, I'd leave them alone until some day the entire panel needs to get repainted. Think of them as well-earned patina...
Plus, it'll make it much easier to identify your car in a lineup.
993Fan is offline   Reply With Quote
The Following 2 Users Say Thank You to 993Fan For This Useful Post:
Enraged21 (01-05-2014), FRSure (01-05-2014)
Old 01-05-2014, 01:28 PM   #3
Or ..... clean up the wound (with alcohol) and carefully apply (with a tooth pic) a dab of touch up paint. After a while .... you won't "see" it anymore ....
FRSure (01-05-2014)
Old 01-05-2014, 01:36 PM   #4
FRSure
Drives: Toyota
Wait a minute.. I thought the bumper is abs plastic?
And my car only have 520 miles.. And this happens.
Old 01-05-2014, 01:37 PM   #5
993Fan
993Fan's Avatar
Or ..... clean up the wound (with alcohol) and carefully apply (with a tooth pic) a dap of touch up paint. After a while .... you won't "see" it anymore ....
The first tiny chip is always the most painful but there will be many, many, more.
Whenever I've tried the paint dab approach in the past, I soon ended up with a bunch of standing-out-like-a-sore-thumb paint pimples.
Old 01-05-2014, 01:41 PM   #6
ZionsWrath
Thanks
ZionsWrath's Avatar
Close your eyes when you get close enough to see it. Shouldn't be often since you'll need to be about 2 feet away or less.
Old 01-05-2014, 01:56 PM   #7
FRSure
Drives: Toyota
Some touch up paint with a toothpick will be fine right? The bumper is abs plastic right?
Old 01-05-2014, 02:15 PM   #8
Yep, the bumper is not metal, so it won't rust.
The secret to applying touch up paint is to have someone with artistic talent make the application.
Like @993Fan says ..... most of us with "fat fingers" and a "more is better" attitude, will make it look like someone painted it with a broom ....
86-tundra (01-06-2014)
Old 01-05-2014, 02:22 PM   #9
#944_10_Series_FRS
#944_10_Series_FRS's Avatar
Drives: 2013 10 series FRS #944
I believe it is made with Polyurethane and not ABS. Although, they both plastic but the property is a little different.
#944_10_Series_FRS is offline   Reply With Quote
Old 01-05-2014, 03:52 PM   #10
FRSfan111
Sideways and smiling!
Drives: First 86 FRS 5/8/2012 (second US)
This is correct.
FRSfan111 is offline   Reply With Quote
Old 01-05-2014, 04:22 PM   #11
headlikeahole
headlikeahole's Avatar
Drives: Ultramarine toyobaru
You can apply the touch up paint generously then remove the excess with a compound like most scratch removers. The end result should be relatively smooth and nearly invisible.
If you take this approach I suggest not waiting too long to remove the paint bump. Once its completely settled it can be hard to rub down.
headlikeahole is offline   Reply With Quote
Old 01-05-2014, 05:01 PM   #12
Brndn704
Brndn704's Avatar
You should see the front of mine...
Brndn704 is offline   Reply With Quote
Old 01-05-2014, 05:04 PM   #13
StOpNG0x
StOpNG0x's Avatar
Drives: Firestorm MT FR-S
Dr. Color Chip.
StOpNG0x is offline   Reply With Quote
The Following 2 Users Say Thank You to StOpNG0x For This Useful Post:
BadMoon (01-05-2014), flashburn (01-07-2014)
Old 01-05-2014, 05:26 PM   #14
N1rve
N1rve's Avatar
Drives: 2019 BMW ///M4
Touch up paint from your dealer. Use the pen side, not the brush.
Easy Oil Change kuhlka DIY (Do-It-Yourself) Guides 12 06-16-2014 01:39 PM
Well that was easy... FRyeS Scion FR-S / Toyota 86 GT86 General Forum 17 10-15-2013 11:04 AM
Easy to Do Mods steve87j Scion FR-S / Toyota 86 GT86 General Forum 23 12-23-2012 12:11 AM
Cheap, easy brake mod! CBR600RR Cosmetic Modification (Interior/Exterior/Lighting) 4 09-19-2012 07:39 PM
easy mod $15.00 2hrs and looks good francosolracer Scion FR-S / Toyota 86 GT86 General Forum 2 07-20-2012 01:04 PM
