Old 12-28-2013, 05:01 PM   #29
andrew20195
Drives: 2013 Subaru BRZ
Oh, I wish ..... but I think the days of "tapping" on things to get them to work has almost come to a close.....
Like tapping on:
* starters (stuck solenoid)
* voltage regulators (stuck points)
* carburetors (stuck float)
* electric fuel pumps
* automatic choke (butterfly stuck)
* radio
* gauges
* horn relay
* various light bulbs
I'm a professional technician, and while I haven't seen many no-starts since I started working on Subaru, when I was working on Honda/Acura I would regularly tap on starters, relays, idle control valves, etc. Those types of things can still stick, even in cars made in the last 10 years.
andrew20195 is offline   Reply With Quote
Old 12-28-2013, 05:10 PM   #30
Good to know ...... that my "tapping technique" is still useful ....
Old 12-28-2013, 05:24 PM   #31
pche
Guy on internet
Drives: Slowly
Check for voltage to the solenoid. You can use a test light, crank the key and make sure you have power. No power means it's an ignition problem. If you do have power than you probably looking at a starter.
Sounds like a solenoid problem to me since it starts with a serperate power.
pche is offline   Reply With Quote
Old 01-02-2014, 12:17 PM   #32
B_Rad
B_Rad's Avatar
Drives: 2013 Scion FR-S/Raven Black/6 sp mt
Once my new controller arrives from Airlift I will be taking the car to the dealer.
B_Rad is offline   Reply With Quote
Old 01-02-2014, 02:12 PM   #33
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
Aftermarket mods drain battery overnight, double check your wiring or go complain to the shop that did the work. The dealership will blame the mods and send you on your way.
ineedyourdiddly
Old 01-03-2014, 08:30 AM   #34
B_Rad
B_Rad's Avatar
My dealer is pretty mod friendly and I did the mods myself. I know my way around a car just not so much for the electrical side of newer cars. battery is fully charged and brand new. I've had the air ride on since labor day and it gave me no issues all the way till now.
Old 01-25-2017, 06:33 PM   #35
brzr
brzr's Avatar
Drives: 2013 frs
Resurrecting this thread to find out what the problem was in the end
I have the same thing happening
i bought my plates 7 years before i bought my car
http://www.ft86club.com/forums/album.php?albumid=1329
brzr is offline   Reply With Quote
Weird sounds and liquid dripping from car kam Issues | Warranty | Recalls / TSB 21 05-07-2014 08:01 PM
car making weird noises after 19" tires installed riironman Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 0 11-17-2013 11:28 PM
Pop-Start with Push-Button Start cmspooner BRZ First-Gen (2012+) — General Topics 5 03-22-2013 03:45 PM
Push Start Rough Engine Start Up joergasm Engine, Exhaust, Transmission 3 12-12-2012 04:44 AM
