go_a_way1
Old 12-23-2013, 02:17 PM   #2017
Nevermore
Wayward Member
Nevermore's Avatar
Drives: Hot Lava 86
Originally Posted by Killerbee View Post
See my answer below. I "guess" coilovers would be the only solution to achive what you are looking for.
I'm not 100% sure on that, however from what I saw on the forums it should work with coilovers since the strut on coilovers is narrower than the stock ones, so there is more space available.
But I leave this question to a coilover owner to answer, since I lack the experience to answer it correctly :-)
I'll look into the coils as well, but what about a 5mm spacer? I know you said 10mm earlier, but like I said, I saw another member with 17x9 +35 and there was poke. I feel like with a 5mm they would be more flush.
Alternatively, would the less wide 17x8 +45 fit if I decided to settle on that, with 225/40 tires? (Again, only offset available.)
Nevermore is offline   Reply With Quote
Old 12-23-2013, 06:09 PM   #2018
kjdd787
Drives:
Hey guys so I'm about to order xxr 527's they come in 18x8.75 et35, et 20 or 18x9.75 et 20 would I be able to run a staggered setup on ebaich sportline drop without rub
Sent from my SCH-I545 using Tapatalk
kjdd787 is offline   Reply With Quote
Old 12-23-2013, 11:37 PM   #2019
BrunoM
Drives: GT86
Just to give my experience.
I run 18x9.5 ET38 all around
235/40/18 Pilot Sport all around
Stock coilovers
Eibach Sportline
No Rubbing issue (it's very close to the struts but no issue)
Hope it will help
BrunoM is offline   Reply With Quote
Old 12-24-2013, 11:43 AM   #2020
Killerbee
Killerbee's Avatar
Drives: GR86 / Supra MK5 MT / MR-S / Z4
Well, it may work aswell with 5mm spacers. It depends a bit on tires sizes and also tire brand, as they tend to have different tire wall wide and therefore it is really a try and error, or finding someone running your exact wish setup and check with them. 10mm spacers will work no matter what tire/brand setup, 5mm may work with the proper tires
Killerbee is offline   Reply With Quote
The Following User Says Thank You to Killerbee For This Useful Post:
Nevermore (12-24-2013)
Old 12-24-2013, 11:45 AM   #2021
Killerbee
Killerbee's Avatar
the 18x9.75 +20 will poke out about 2-3cm in the rear, unless you run some mad camber.
Old 12-24-2013, 01:04 PM   #2022
puravida
Drives: 14 brz, 97 nsx, 85 land cruiser
hi guys,
i apologize as this topic has been brought up a lot . . . but i've scoured the threads and can't get a clear sense of which way to go . . . i need help.
i'm looking at rpf1 in 17x8 and i can't decide 35 vs 45. is there any advantage from a performance/fitment standpoint ? or is it purely a cosmetic issue poke vs tuck. i'm not planning any suspension mods . . . the car is a daily driver with a track day every few months (hopefully more !!)
appreciate your help with this . . .
puravida is offline   Reply With Quote
Old 12-26-2013, 05:55 PM   #2023
Kody
Drives: 2013 Subaru BRZ
Excellent, great amount of info! I appreciate it : )
Kody is offline   Reply With Quote
Old 12-26-2013, 06:13 PM   #2024
Turkish
Serial Cone Killer
Turkish's Avatar
Drives: '14 BRZ - WRB Premium 6MT
Originally Posted by puravida View Post
hi guys,
Short answer: no noticable difference performance wise.
Long answer: there will be 2cm difference in distance between the wheels (side to side). I'm not proficient enough to tell you the exact handling differences, but I'm confident that only a tofu delivery driver would notice any difference. If you catch my "drift".
For those who hear him call...
... his name is...
C'THULHU
Turkish is offline   Reply With Quote
Old 12-27-2013, 03:39 AM   #2025
JackSmiley
JackSmiley's Avatar
Drives: A Potential Traffic Ticket
Which if these width+offset set up would need less camber (< -2.0) with 245/35 tires on - 9.5+30 or 10.0+37? The set up would be intended for the rear, and i will roll the fenders if needed.
JackSmiley is offline   Reply With Quote
Old 12-27-2013, 04:01 AM   #2026
Killerbee
Killerbee's Avatar
Short -> both about the same, only 1mm difference
Long -> 0.5" difference, 0.5" is 12.7mm. It will add 50% of it to the inside, and 50% to the outside, so each 6.3mm. +30 and +37 are 7mm difference.
So the 10.0+37 kills the 7mm offset difference by being 6.3mm wider on the outside of the wheel.
However, 245 tires will be streched on a 9.5", and will be even more streched on a 10" wheel.
Fenders are rolled from factory btw.
Old 12-27-2013, 07:52 AM   #2027
JackSmiley
JackSmiley's Avatar
So pretty much the 9.5+30 will stick out 0.65mm more than the 10.0+37? The fronts are rolled, the rears have a bump that i'll need to flatten out if i were to reduce the camber that i'd be running without rubbing. I still wanna know how much camber would be needed to run 245/35 with a 9.5+30 or a 10.0+37.
Old 12-27-2013, 11:39 AM   #2028
Killerbee
Killerbee's Avatar
yes, so its pretty much the same. No idea however about how much camber you need, I leave that to someone else to answer.
JackSmiley (12-27-2013)
Old 12-27-2013, 01:12 PM   #2029
puravida
thank you ! so from an aesthetic aspect . . . which would be a better fit ? +35 or +45 (rpf1 17x8)
Old 12-27-2013, 03:10 PM   #2030
Turkish
Serial Cone Killer
Turkish's Avatar
My calculations from looking 17x8 and 17x9 came out that +35 poked a tiny bit without camber adjustment; +45 will be tucked without spacers.
... his name is...
C'THULHU
The Following User Says Thank You to Turkish For This Useful Post:
puravida (12-28-2013)
Determining the proper width size of the tire CyberFormula Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 49 05-23-2014 10:11 AM
Correct tire width for each wheel width DarrenDriven Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 10 08-16-2012 03:03 PM
TIRE SIZE CALCULATOR White64Goat Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 08-15-2012 03:31 AM
Tire Width vs Wheel Width Synack Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 40 08-13-2012 12:21 AM
