Old 12-17-2013, 06:18 PM   #29
Rayme
The Answer
Rayme's Avatar
Drives: Mazda 2
Melted fuse is a sign of wire overheating. The wires are probably too small for your amp charge. When you replace the fuse, check if the fuse/wires gets hot. It should NOT be hot at all. This is a great way to start a fire heheh
Rayme is offline   Reply With Quote
The Following User Says Thank You to Rayme For This Useful Post:
Trap63 (12-17-2013)
Old 12-17-2013, 06:32 PM   #30
636
636's Avatar
Drives: '23 CWP BRZ
Hmmmmm. I replaced it today, and did a test run for a few minutes, everything felt fine..
636 is offline   Reply With Quote
The Following User Says Thank You to 636 For This Useful Post:
Rayme (12-17-2013)
Old 12-17-2013, 06:36 PM   #31
Rayme
The Answer
Rayme's Avatar
Drives: Mazda 2
Next time you drive for a long time check it again, it shouldn't even be close to be burning hot. Maybe it was a bad fuse. You still have the H11 55 watts in the fogs right?
Old 12-17-2013, 06:38 PM   #32
636
636's Avatar
Drives: '23 CWP BRZ
Yep! Nokya H11 55w! 2500k hyper yellow.
Old 12-23-2013, 02:53 PM   #33
assbox
assbox's Avatar
Drives: Whiteout FRS
my nigel fog light kit did the same thing after one day.- i resolved the issue by finding a better ground, as well as replacing the fuse with a better quality 15 amp fuse i found at radio shack. i have not had a problem since. hope this helps
IG: ft86carbon
assbox is offline   Reply With Quote
Old 12-23-2013, 04:33 PM   #34
636
636's Avatar
Drives: '23 CWP BRZ
Where'd you reground it?
Old 01-11-2015, 06:34 AM   #35
thatfilipinoguy
thatfilipinoguy's Avatar
Drives: 87 Supra, 13 FRS, 05 FXT
What he said. Mine just did this today...sorry for the thread revival. I was pretty upset about it haha, I hate driving my car knowing something doesn't work.
thatfilipinoguy is offline   Reply With Quote
some guy rear ended me in stopped traffic ric342 Southern California 64 11-19-2013 06:42 AM
Scion 10 display stopped working. mid_life_crisis Cosmetic Modification (Interior/Exterior/Lighting) 2 11-05-2013 02:54 PM
AT BRZ - stopped rev matching... ray7792 BRZ First-Gen (2012+) — General Topics 2 10-31-2013 08:24 PM
Left fog light stopped working 2 days after LED switch, possible culprit? tracerit Cosmetic Modification (Interior/Exterior/Lighting) 5 09-18-2013 01:41 AM
weird pulsing while stopped neil125 Issues | Warranty | Recalls / TSB 2 05-15-2013 12:04 AM
