Old 12-20-2013, 08:51 AM   #15
Victor Draken
Drives: Toyota Gt86
Originally Posted by s2d4 View Post
What part of his list will not contribute to power gain/loss, however minute?
-TRD Intake box
-JDL UEL catless header
-Nameless over-pipe high flow cat front pipe
these are the parts you buy for whp/tq increase.
the remaining parts are more for faster revving, better response of the engine, lighter car, sound (exhaust) etc.
Having 200whp on a 2000lbs car or 200whp on a 1800lbs car it makes a big difference (I'm not saying he saved 200lbs I'm just saying that not all the mods directly increase whp/tq numbers.)
Victor Draken is offline   Reply With Quote
Old 12-20-2013, 08:56 AM   #16
s2d4
s2d4's Avatar
What happens when you try to remove drivetrain losses?
Old 12-20-2013, 09:05 AM   #17
Victor Draken
Drives: Toyota Gt86
the increase on a dyno is minimal.
Old 12-20-2013, 09:06 AM   #18
Deep Six
Deep Six's Avatar
Drives: 2013 FRS / 2013 427 Vert
A bolt on E85 setup is the perfect solution for anyone wanting 40 or 50 more crank horsepower. The additional power is right now every where in the rev band. It is transformational at the track, providing the ability to execute a pass and get safely back on line. In my case the E85 tune yields 17 more whp than the 93 version.
[SIGPIC][/SIGPIC]
2013 FR-S Asphalt BC Coils/Rev Works UEL header/HKS Front Pipe/Racing Brake BBK/Shorai LW Battery/ACT 6 Puck Clutch/FBM Radiator & Oil Pan/JR Oil Cooler/Jackson Racing High Boost C30/Rev Works Built Motor
2016 Audi TTS APR Tuned
Deep Six is offline   Reply With Quote
Old 12-20-2013, 09:07 AM   #19
s2d4
s2d4's Avatar
Yeah, exactly.
Old 12-20-2013, 09:12 AM   #20
Victor Draken
Drives: Toyota Gt86
Yeah, exactly.
So what?
If you want to compare all of his mods you should do different accellerations test and have the car run on the track with different setups and then you would see if it's almost 5k wasted or not.
anyways let's get back on topic.
Old 12-20-2013, 09:14 AM   #21
jamesm
nice work! 207whp na might be a record? not sure... it's close either way.
Old 12-20-2013, 09:17 AM   #22
s2d4
s2d4's Avatar
So what?
I did not say it is wasted.
It is just part of squeezing every last bit out of a stock NA engine, the cost increases exponentially for the last few HPs.
I was just gasping how much was required to get the extra 7whp over the OTS map with OFH, 3 of which was further gained by shiv in an hour.
Old 12-20-2013, 09:32 AM   #23
ShadowSeraph
Tech Master / Car Geek
ShadowSeraph's Avatar
Drives: 2013 AT Hot Lava FR-S
Don't forget that the "remaining parts" also reduce energy losses in the drive train so more makes it to the road. While not directly increasing available HP of the system, it just makes more of it available to transfer to the road.
fun.
Awesome NA setup for the owner. Now with a few other possible future mods.. I wonder how far NA can be pushed on this engine.
Perrin: Crank pulley, 3" Cat back, Nameless: 3" FP/OP
GFB: water and alternator pulleys
Borla: UEL Header
Hyper Black ROTA T2R 18x9.5, DSS CF Shaft for AT
-= OFT - Stage 2 UEL E85 - fine tuned by me. =-
ShadowSeraph is offline   Reply With Quote
Old 12-20-2013, 09:32 AM   #24
Sojhinn
Lightning McQueen Driver
Sojhinn's Avatar
Drives: Limited Red 6MT BRZ
Nicely done shiv! Btw- any chance you saw my battery terminal cover?
Installed Mods:
Old 12-20-2013, 10:13 AM   #25
bfrank1972
Drives: 2013 FR-S Argento
I think this just goes to show that, while there are incremental gains from exhaust upgrades, E85+tune is the biggest gainer here. I'd personally like to see an OFT dyno of E85+tune on an otherwise stock car - I'd predict on the dynos Shiv is using we'd see high 180's, maybe even break 190 with a custom E85 tune.
Old 12-20-2013, 11:09 AM   #26
FrsDuke
Fanboy
FrsDuke's Avatar
Drives: 2013 ultramarine frs
But this isn't the same car they did the ofh build on is it? Not all ft86 Dyno the same stock etc etc.
FrsDuke is offline   Reply With Quote
Old 12-20-2013, 03:32 PM   #27
Sargy
Long Distance Driver
Sargy's Avatar
very very good news indeed
Sargy is offline   Reply With Quote
Old 12-20-2013, 03:45 PM   #28
Dephective
Drives: '13 Whiteout FRS
We are just about at the limit with I/H/E and E85. That limit is pretty much set by the cams. Bigger cams and appropriate valvetrain (stock is mushy) and you could be making way more power, and revving higher. But you sacrifice drivability on the street with more aggressive cams, as this car doesn't have variable lift only variable timing. I'd Like to see what the limit would be on a SLIGHTLY more aggressive cam profile vs. driveablity. Something that will rev efficiently to 8200 and still have enough low end to putt around town. I hear some cam dyno plots will be coming soon.
Previous:
'01 Accord-daily
'93 Rx7-fire breathing track monster 545hp 397tq 2300lb.
'06 Mazdaspeed6 one helluva love-hate relationship
Dephective is offline   Reply With Quote
Full Stock Exhaust - Anyone content with full stock & NEVER planning for aftermarket? fooddude Engine, Exhaust, Transmission 39 12-15-2013 02:05 PM
Highest RWHP *FULL* Bolt-Ons? (Looking for 200-215) nbrigdan Engine, Exhaust, Transmission 14 10-02-2013 05:47 PM
Need help with exhaust bolt J-Money Engine, Exhaust, Transmission 1 08-12-2013 11:11 AM
I/H/E FULL Bolt Ons + Tune Dynos? ShoNUFF Engine, Exhaust, Transmission 25 03-22-2013 02:48 PM
BRZ crash bolt same as Impreza lower strut bolt? xwd Tracking / Autocross / HPDE / Drifting 0 07-05-2012 12:19 PM
