Old 12-19-2013, 04:39 PM   #15
Shiv@Openflash
Shiv@Openflash's Avatar
Drives: 2013 FRS
Originally Posted by alexand3r View Post
Thanks for the update!
Not that it really matters, but it looks like the "Upload" section isn't pulling the correct info for FW version:
I think there is a mismatch the first time the oft updates vid OpenFlash manager. The next time you connect to it, it should match up.
Shiv@Openflash is offline   Reply With Quote
Old 12-19-2013, 04:58 PM   #16
alexand3r
Custom User Title
alexand3r's Avatar
Drives: Spaceship
No dice, same. Disconnected/Reconnected and Opened/Exited the program 3 times now. Shouldn't matter though, should it?
alexand3r is offline   Reply With Quote
Old 12-19-2013, 05:24 PM   #17
Cross
It's the Mad Cow
Cross's Avatar
Mine still says 1.14 there as well.
Old 12-19-2013, 05:30 PM   #18
Shiv@Openflash
Drives: 2013 FRS
Ah… turns out that particular section isn't getting updated. So it's basically the firmware version that you had when you first installed the OFT. Doesn't matter of course. But I'll pass that along to the programmers to fix with the next release. Thanks for the heads up
The Following 2 Users Say Thank You to Shiv@Openflash For This Useful Post:
alexand3r (12-19-2013), Cross (12-19-2013)
Old 12-19-2013, 05:49 PM   #19
zc06_kisstherain
zc06_kisstherain's Avatar
Drives: SWP BRZ
GREAT!!! thank you Shiv!!!!
Old 12-19-2013, 06:10 PM   #20
jeebus
Originally Posted by krulux View Post
Well don't I feel dumb -
I was under the impression the ECU handled all manner of electronic controls. I looked at a few different ODBII devices that can handle the TPMS and other car systems such as lights, door, trunk, alarms etc... but they cost more than I want to spend at this time.
I think you can do this with techstream. It costs thousands of dollars OR you can buy a pirated version off ebay with a cable for $30.
jeebus is offline   Reply With Quote
Old 12-19-2013, 07:13 PM   #21
Shiv@Openflash
Drives: 2013 FRS
Originally Posted by Terrapin77 View Post
@shiv. There is another minor graphic issue after running the template update.
Sent from my XT912 using Tapatalk
It doesn't look like you upgraded the Template. Still running the old one. You'll need to download the new template file from our website and upload it to the OFT by going to the "Ugrade" section on OpenFlash Manager. This is the only kind of update that isn't automatic. Make sure you are running the newest version of OpenFlash Manager. I put it up on our website for download just last night.
Old 12-19-2013, 07:16 PM   #22
Terrapin77
Terrapin77's Avatar
Drives: 2013 Argento FR-S
@shiv. Here is the correct photo
Terrapin77 is offline   Reply With Quote
Old 12-19-2013, 07:17 PM   #23
Shiv@Openflash
Drives: 2013 FRS
@shiv. Here is the correct photoAttachment 60555
oh ok. You're referring to the left side of those two bar graphs, correct? Just noticed that myself last night. Should be fixed soon
Old 12-19-2013, 07:19 PM   #24
Terrapin77
Terrapin77's Avatar
Yes. The left side of the bar graphs.
Old 12-19-2013, 10:09 PM   #25
garfull
garfull's Avatar
Drives: FRS(sold), AP2, R35, FJC, ED9
i get something similar too. also all the left radius corners are missing too.
http://www.datazap.me/u/garfull/e85-...-2-5-6-9-10-11
did a log tonight. there is a weird dip in the vvt exhaust at the beginning of the 2nd gear pull. is this normal?
also are we restricted to only 1 log at a time?
garfull is offline   Reply With Quote
Old 12-19-2013, 10:27 PM   #26
Shiv@Openflash
Drives: 2013 FRS
That log looks pretty much perfect. And yes, it's normal to see over/undershoot when it comes to VVT position. Remember that it runs a closed loop control logic so there will always be error. Especially in lower gears when it doesn't have as much time to hit (and hold) the target.
And yes, only 1 datalog file at this time. But it can be up to an hour long so there is plenty of data you can get in there.
Shiv
The Following User Says Thank You to Shiv@Openflash For This Useful Post:
garfull (12-19-2013)
Old 12-19-2013, 10:33 PM   #27
garfull
garfull's Avatar
perfect thanks. one more question.
if i stop the log and start a new one (ie for a trackday) without overwriting will it append to the end of the previous log?
Shiv
Old 12-19-2013, 10:51 PM   #28
FrsDuke
Fanboy
FrsDuke's Avatar
Drives: 2013 ultramarine frs
Fairly sure it is replace or nothing, but that's a great idea
FrsDuke is offline   Reply With Quote
OpenFlash Tablet Rombinhood@OpenFlash Software Tuning 1838 07-29-2023 06:35 PM
OpenFlash Tablet v1.42b maps now available Shiv@Openflash Software Tuning 159 09-13-2016 12:29 AM
Is Openflash tablet detectable? Boofneenee Software Tuning 25 05-02-2014 10:03 PM
FS Brand New OpenFlash Tablet Raven218 Engine, Exhaust, Bolt-Ons 9 11-30-2013 12:58 PM
WTB Openflash Tablet Vlady Want-To-Buy Requests 0 10-25-2013 12:10 AM
