Old 12-17-2013, 01:00 AM   #15
Low&Slow
Low&Slow's Avatar
Drives: 10 Series #845
Also, was it blown before or after the fog light situation? does your fog lights still turn on with the fuse blown like that?
Low&Slow is offline   Reply With Quote
Old 12-17-2013, 01:01 AM   #16
636
636's Avatar
Drives: '23 CWP BRZ
I sadly never checked before, so I don't know how it looked originally. But no, they won't turn on. I'm curious as to how I could've blown it though. The last time they worked was right before I hit a bump. I don't think a bump can blow a fuse?
636 is offline   Reply With Quote
Old 12-17-2013, 01:03 AM   #17
Low&Slow
Low&Slow's Avatar
Yeah, it's your fuse. Change that out and you should be good! i would use a 30a fuse.. hold on, let me check my car for ya! anyways, i don't know how you managed to blow a fuse! could be bad ground and a wire got short.
The Following User Says Thank You to Low&Slow For This Useful Post:
636 (12-17-2013)
Old 12-17-2013, 01:04 AM   #18
636
636's Avatar
Drives: '23 CWP BRZ
I'm running 10k spring rates with super stiff dampening, so maybe the bumps sent something loose and it blew it. Hahaha
Old 12-17-2013, 01:06 AM   #19
Low&Slow
Low&Slow's Avatar
Confirmed, 15! not 20 or 30!
636 (12-17-2013)
Old 12-17-2013, 01:26 AM   #20
m.box.design
m.box.design's Avatar
Drives: 2013 Whiteout FRS
it's better blowing a fuse than blowing out your bulbs
Old 12-17-2013, 01:31 AM   #21
Gixxersixxerman
Gixxersixxerman's Avatar
Drives: Toyota GT86, 66 beetle, 11 GSXR 750
Blue is 15 amp, and that's not "blown" that's melted down.. That's from heat causing it to melt, so it's either a fuse that didn't pop like it should, or it's to close to a heat source and melted.. And I'm surprised, I've never seen one melt.. Usually just a small brown mark inside the fuse at most lol
Gixxersixxerman is offline   Reply With Quote
Old 12-17-2013, 01:34 AM   #22
636
636's Avatar
Drives: '23 CWP BRZ
Thank you guys, you've all been a great help to me! I'm gonna head out tomorrow and pick up some new fuses.
Just confused why it melted! It's not near anything hot, but I have been driving pretty spirited lately, so maybe that's why, but who knows.
Thanks once again everyone, and I'll keep you updated.
Old 12-17-2013, 01:51 AM   #23
Gixxersixxerman
The way you drive has nothing to do with it.. I'd check over AEVERY wire and make sure there isn't a short anywhere.. Usually the wire would melt if there is a short and the fuse fails.. But a fuse shouldn't melt
The Following 2 Users Say Thank You to Gixxersixxerman For This Useful Post:
636 (12-17-2013), Trap63 (12-17-2013)
Old 12-17-2013, 02:09 AM   #24
636
636's Avatar
Drives: '23 CWP BRZ
How exactly would I go about finding a short in the wire? Like I said, brand new to electrical
Old 12-17-2013, 12:22 PM   #25
Gixxersixxerman
Just trace/ follow all the wires until you've covered everything.. You'll look for a wire that's cut/frayed/burnt anything like that.. If you replace that fuse and it pops again.. Some where you have a short, or drawing more then the 15 amps to pop that fuse.. Don't go to a higher rating.. Find the problem
The Following User Says Thank You to Gixxersixxerman For This Useful Post:
Trap63 (12-17-2013)
Old 12-17-2013, 02:10 PM   #26
636
636's Avatar
Drives: '23 CWP BRZ
is this what I need? I don't really feel like spending $20 for one fuse.
http://www.simsupply.com/Bussmann-At...FSdp7Aod4h4A1w
Old 12-17-2013, 02:34 PM   #27
Awstryker
Drives: Scion FR-S 10 Series 6MT
Same thing happened to me it didn't blow the fuse it turned to a blob like in the picture. Just replace the fuse (15a) and make sure the fuse housing isn't badly damaged, you'll be good to go after that.
Awstryker is offline   Reply With Quote
Old 12-17-2013, 02:37 PM   #28
SkullWorks
Drives: SSM LT MT BRZ
Not really, you can just go to PeP boys or any auto store and find individual packs or smaller variety packs. Get Buss fuses or something of value.
I have a feeling the issue here is either the quality of the original fuses or a bad solder job on one of the terminals connected to the fuse holder causing the assembly to get hott
some guy rear ended me in stopped traffic ric342 Southern California 64 11-19-2013 05:42 AM
Scion 10 display stopped working. mid_life_crisis Cosmetic Modification (Interior/Exterior/Lighting) 2 11-05-2013 01:54 PM
AT BRZ - stopped rev matching... ray7792 BRZ First-Gen (2012+) — General Topics 2 10-31-2013 07:24 PM
Left fog light stopped working 2 days after LED switch, possible culprit? tracerit Cosmetic Modification (Interior/Exterior/Lighting) 5 09-18-2013 12:41 AM
weird pulsing while stopped neil125 Issues | Warranty | Recalls / TSB 2 05-14-2013 11:04 PM
