Old 12-14-2013, 12:57 PM   #15
jamesm
Originally Posted by tg_1981 View Post
LOL...When did you do this?
not long ago when i was first converting my pump gas tune to e85. now i keep them in separate folders
Old 12-14-2013, 01:31 PM   #16
jeebus
This is all excellent information. One thing worth noting though, and I could be wrong, but if LTFT gets to +/- 25 don't you throw a lean/rich code? (assuming you haven't disabled it, lol)
Also, I've put a few k miles on Shiv's e85 tune and I've seen some fluctuations in the ethanol content myself. PERSONALLY, I prefer to add a bit of gas when the trims are on the lean side just because it makes me feel better. Plus, when the trims are on the lean side (high ethanol), my car hates to start on cold mornings. It still starts, but I hate trying more than once.
But admittedly, I'm a bit of a perfectionist and I like to see my LTFT as close to zero as possible.
jeebus is offline   Reply With Quote
The Following User Says Thank You to jeebus For This Useful Post:
fstlane (12-14-2013)
Old 12-14-2013, 01:57 PM   #17
FRSFirestorm
Red is Fastest
FRSFirestorm's Avatar
Drives: 13 FRS 6MT Firestorm
Having tuned before I understand the closed loop process for fueling. IE: adjustments based upon STFT's and LTFT's.
I've always understood however that AFR's while running methanol/ethanol fuels should be somewhat richer? Which tuning and commanded AFR's won't account for since tuned to run regular fuels?
FRSFirestorm is offline   Reply With Quote
Old 12-14-2013, 02:10 PM   #18
Liquid6
Liquid6's Avatar
Drives: 2014 FR-S
So let me get this right I can put E85 in my car with a tune from OFT and not have to buy a $650 flex fuel kit? I'm new to this tuning stuff and don't want to spend money on something that isn't necessary.
Thanks
Liquid6 is offline   Reply With Quote
The Following User Says Thank You to Liquid6 For This Useful Post:
Strife26 (12-05-2015)
Old 12-14-2013, 02:20 PM   #19
nlowell
nlowell's Avatar
Drives: 2013 Scion FRS
Thanks
Correct - and if you want to test the Ethanol content out of curiosity all you need is a turkey baster and a 100ml graduated cylinder - I bought mine off amazon.
nlowell is offline   Reply With Quote
Old 12-14-2013, 02:24 PM   #20
Liquid6
Liquid6's Avatar
Drives: 2014 FR-S
Ok great. Can't wait to try it out. Thanks for your help
Old 12-14-2013, 02:31 PM   #21
arghx7
Drives: car
Shiv, can you comment on flex fuel kits and quality of starting in cold weather?
Old 12-14-2013, 02:37 PM   #22
EAGLE5
Dismember
EAGLE5's Avatar
Drives: 2013 Red Scion FR-S
FYI, it was 35 this morning according to the car, and there was ice on the ground. Started great on e85. A quarter second of stutter.
Old 12-14-2013, 03:06 PM   #23
Liquid6
Liquid6's Avatar
Drives: 2014 FR-S
Do you know if there is a digital plug in ethanol content tester or is that just part of the whole flex fuel kit . I know its not needed but would like to get content while I'm in car.instead of going the turkey baster route.
thanks again
Old 12-14-2013, 03:08 PM   #24
jamesm
thanks again
you can get the gauge and sensor in a variety of configurations from zeitronix directly. runs about $350-370 for the whole setup iirc.
Old 12-14-2013, 03:24 PM   #25
danthedirt
Hadouken
danthedirt's Avatar
Drives: Whiteout FR-S
Can you elaborate how this works? Does the ethanol separate?
Sent from my SGH-T999 using Tapatalk
Whiteout MT
Car Blog: downrightfrs.blogspot.com/
danthedirt is offline   Reply With Quote
Old 12-14-2013, 04:27 PM   #26
SkullWorks
Drives: SSM LT MT BRZ
Ethanol is Hydroscopic meaning it likes to absorb water, if you mix the E85 with Water and shake it to mix it, the gas will now float on top of your Alcohol water mixture...if you did your maths correctly, you can look at the level in the graduated cylinder where the GAS and Alcohol/water separate and deduce your % of alcohol
The Following User Says Thank You to SkullWorks For This Useful Post:
WRB5titch (12-14-2013)
Old 12-14-2013, 04:38 PM   #27
nlowell
nlowell's Avatar
FlexFuel and Facts
You fill the cylinder up with 25ml of water and 75ml fuel. Cover and shake. After it settles, the ethanol will join with the water and what you have on top will be the pure gasoline. You can equate the percentage of ethanol content by taking the the new separation line (call it x), which is should be in the 80's, and plugging it into this equation:
(x-25)/75
Basically you are figuring out how much ethanol was added to the water (x-25) then what percentage of the original fuel (75) that is.
If the separation line is now at 88 (x=88) then the equation would be
88-25=63
63/75=.84 (or 84% ethanol)
At least that is how I understand it
The Following 8 Users Say Thank You to nlowell For This Useful Post:
DAEMANO (12-14-2013), danthedirt (12-14-2013), jliongh (09-03-2016), Malt (12-14-2013), nofferman (08-10-2014), Simplicity (03-21-2015), SkullWorks (12-16-2013), WRB5titch (12-14-2013)
Old 12-14-2013, 07:24 PM   #28
Sojhinn
Lightning McQueen Driver
Sojhinn's Avatar
Drives: Limited Red 6MT BRZ
Count me in as one of those people who have noticed the car automagically (word use intended) handles variations in the fuel. I've been running a mixture of either e85 or 92 for the past 3.5 weeks. The car handled everything I threw at it, and between the cars computer and shiv's awesome tune on my esc everything is incredible.
Installed Mods:
The Following 3 Users Say Thank You to Sojhinn For This Useful Post:
DAEMANO (12-14-2013), Robert@Openflash (12-16-2013), WRB5titch (12-14-2013)
e85 flexfuel, shiv 2016
The facts behind Flex Fuel kits available for the 86 Yruyur Engine, Exhaust, Transmission 56 01-23-2015 01:06 PM
FlexFuel over Straight E85 on EcuTeK, why is it better? DeliciousTuning Software Tuning 37 12-17-2013 10:21 PM
questing on going with a flexfuel tune yetiFR-S Engine, Exhaust, Transmission 3 11-22-2013 08:17 AM
Facts you may or may not know about your GT86/BRZ/FR-s FiRStsc10n Scion FR-S / Toyota 86 GT86 General Forum 41 07-09-2013 03:05 PM
Flexfuel Allch Chcar Scion FR-S / Toyota 86 GT86 General Forum 50 11-04-2011 12:39 AM
