Old 12-13-2013, 08:57 AM   #71
the.big.kahoona
the.big.kahoona's Avatar
Drives: 2013 Raven 86
Originally Posted by Trac Toy View Post
No, a good buddy that I race with has one, and yes it's fast and fancy and nice, but it still essentially drives itself. You just point it where to go.
I know no one is forcing anyone to use the technology, but really... It is a useless mod for a manual transmission car.
You're probably right. Actually i'm pretty sure you're right. It really is just me wanting to try it out. If it was a simple add-on it would be nice to have it as an option.
the.big.kahoona is offline   Reply With Quote
Old 12-13-2013, 09:04 AM   #72
vgi
Drives: frs
Originally Posted by jamesm View Post
i'd rather the time be put into a speed density implementation
that, or flex fuel kit. because all said in this thread http://www.ft86club.com/forums/showthread.php?t=53409 is correct and while there was no mentioning of OFT i still felt like it is indirectly pointed at super popular OFT and its free e85 tunes (maybe i'm just getting paranoid hearing that same song from tuners all the time - EcuTek).
vgi is offline   Reply With Quote
Old 12-13-2013, 09:05 AM   #73
vgi
Drives: frs
take a spin in a 370z at the dealership
Old 12-13-2013, 09:15 AM   #74
s2d4
s2d4's Avatar
Well that E-flex vs E85 thread didn't need to single out any tuning solution as Motec and most *stand alones could do it, creating a thread on SD when the opposite camp couldn't contribute, indicated broken forum rule whilst doing the same but only the other camp got banned.
You draw the lines between the dots man.
Old 12-13-2013, 09:48 AM   #75
jamesm
There is a lot of sensationalism currently going around for sure. Flex fuel is not a requirement to enjoy e85. It makes it easier, presuming it's calibrated correctly and all that, but it's not like checking trims and tweaking a couple scalers is rocket science or hard work. It has other advantages like ethanol content-dependent boost and timing that are great, again if set up properly. I don't debate it's a nice to have, but it's certainly not a necessity.
That pales in comparison to some of the other misinformation flowing around here though. Someone said just recently that only ecutek could control port to di ratio lol.
edit: just realized that ecutek users can't actually edit the tune to fix it. so, i guess they create their own necessity there . in any case, if you have excel and some free time you're good to go with OFT/open source.
Old 12-13-2013, 09:56 AM   #76
Malt
Drives: 2015 WRX
I think there are several ECUtek tuners that given the ability of using SD and flexfuel would gladly use OFT as their flashing medium. There are those that will not because it doesn't offer the ability to lock down their tunes, despite the fact anyone in the market for a custom tune understands that using another persons custom tune doesn't make sense. What is semi frustrating is the intentionally misleading ramblings of people who are ECUtek supporters who try to compare two completely different things. Not sure why they feel the need to drag OFT's name through the dirt because most of the posts I've seen from OFT users have had good things to say about ECUtek in some areas, just not the locking of tune files and the almost constant statements saying that OFT CAN'T do something because it doesn't support an unnecessary feature.
Regardless, I'm loving the pace of the development on the OFT side of things. I imagine it won't be terribly long before we start seeing OTS maps for turbo kits and tuners realizing the way of the market is moving to a more open source trend.
Malt is offline   Reply With Quote
Old 12-13-2013, 09:59 AM   #77
Jetscape
Jetscape's Avatar
Drives: Toyota GT 86 Red AT
I was unaware AVO had signed any deals with any F1 teams to provide turbos for next season. This is amazing news.
My apologies. I meant FI or Forced Induction not F1... Cheers..
Jetscape is offline   Reply With Quote
Old 12-13-2013, 10:12 AM   #78
FrsDuke
Fanboy
FrsDuke's Avatar
Drives: 2013 ultramarine frs
Shiv, I know you generally run stock intake plus drop in filter with a modified snorkel (one of the first things I did to my car), but I also notice you're selling perrin intake stuff. Have you compared the inlet hose to stock on a dyno with factory box and snorkel mod?
FrsDuke is offline   Reply With Quote
The Following 2 Users Say Thank You to FrsDuke For This Useful Post:
cjsporl1996 (12-13-2013), Mike86 (12-13-2013)
Old 12-13-2013, 11:23 AM   #79
Grip Ronin
The Mechanic
Grip Ronin's Avatar
Drives: Civic Turbo,FR-S
any chance of uel and el tunes for pump gas?
IG-Joey_Soul
Progress Thread Ported billet 20G
Grip Ronin is offline   Reply With Quote
Old 12-13-2013, 11:37 AM   #80
vgi
Drives: frs
"The Bullshit Epidemic: Call it when you see it."
i can recall seeing something like this, is this the one:
Just realize you have 8 injectors, not 4. There is a way to run them both with EcuTeK RaceROM, as you need the custom mapping to be able to run 8 injectors versus 4. Basically I found a way to do it.
well, i'm just thankful that floating around popular myth that anything beyond 250HP would require a bigger pump or injectors or both has been proven wrong. I remember tuners would suggest pump or injectors upgrade even for a base innovate kit.
back on topic - eagerly awaiting shiv's FI tunes to prove all the naysayers wrong
Old 12-13-2013, 12:04 PM   #81
jamesm
i 'found a way' to run all 8 injectors on my car too, it involved turning the key and pulling out of my driveway lol. yes that is the one.
of course the reality is that anything that can edit a stock rom can control port/di ratio.
as for OTS turbo kit maps, that may be a bit difficult, or you may have to rely on users to do a bit more of the setup part. turbo owners usually have all sorts of different map sensors and injector sizes, maf configuration is a much bigger deal, etc. of course being an open platform, none of this is an issue to just set up yourself.
The Following User Says Thank You to jamesm For This Useful Post:
Shiv@Openflash (12-13-2013)
Old 12-13-2013, 12:22 PM   #82
jeebus
flex tunes certainly have advantages over just a straight e85 tune. However, for my needs I'd prefer not to invest the money or introduce the added complexity to the car that would be required to do flex fuel. But I'm not making big power or going FI, just running e85 to make that extra oomph that the car really begs for. It's a minor hassle having to check trims and adjust as needed, but if I was running a flex kit I'd likely be just as cautious and do plenty of logging...plus I'd be more reliant on a 3rd party tuner, and additional sensors added to the vehicle, etc.
I'll just simplify and say that e85 isn't for everyone. It takes more effort to find, more effort to test, and you can never feel as confident with each fill that it will be the same as the last time. No matter which route you take, it's extra work and/or money.
jeebus is offline   Reply With Quote
Old 12-13-2013, 12:32 PM   #83
Boofneenee
Go-Kart Enthusiast
Boofneenee's Avatar
Drives: Toyota Scion FRS
Shiv, this new website is killing me! I see that you now offer a custom tuning service which is huge. However, each time i click the link to read about the features and cost it directs me to the wrong page! Care to discuss here this new feature?
FRS
Current mods: K&N air filter, OFT, OFH, berk high flow cat front pipe, Q300 exhaust, lighter wheels
Boofneenee is offline   Reply With Quote
Old 12-13-2013, 12:39 PM   #84
Shiv@Openflash
Shiv@Openflash's Avatar
Drives: 2013 FRS
Could you tell me which page redirects you? I can quickly fix it.
Shiv@Openflash is offline   Reply With Quote
OpenFlash Tablet Rombinhood@OpenFlash Software Tuning 1838 07-29-2023 06:35 PM
Openflash Tablet v1.31 beta maps (including Stage 2!) now available for download Shiv@Openflash Software Tuning 354 02-08-2015 05:23 PM
OpenFlash Tablet E85 (and gasoline) Maps now available Shiv@Openflash Software Tuning 401 08-13-2014 11:14 PM
OpenFlash Tablet Stage 1 v1.2 maps available for download Shiv@Openflash Software Tuning 31 10-31-2013 08:45 PM
WTB Openflash Tablet Vlady Want-To-Buy Requests 0 10-25-2013 12:10 AM
