#15 | |
Some reading for the OP: http://www.aa1car.com/library/battery_runs_down.htm Please let us know when you get er cranking again. humfrz |
#16 |
Drives: 2013 Scion FR-S/Raven Black/6 sp mt
Gonna put a different battery in it today after work. Pretty sure you are all right. It was dead and I pulled it and gave it a charge.
For the mods I am on Airlift airstruts. Which after some reading last night is known to pull a small amount of voltage when off, and they recommend putting a trickle charger if your car is going to sit for an extended periord of time. The battery doesn't have enough amps to kick the compressors on now either. Planned on upgraded the factory battery this spring anyway so I guess it will just be sooner now. |
#17 |
Nope no click, been super busy with work and have been unable to get the battery load tested. I was going to use the battery out of my xb to try and start it but some a-hole engineer decided to put a battery with the positve on the right side of the battery. Which makes it backwards to all the batteies I currently have.
#18 |
Drives: 13 BRZ
Like everyone else said put a battery charger on it or jump start it with another vehicle to verify if that's the problem. If that doesn't do it try tapping on the starter with a screwdriver while somebody tries to start it. Pretty unlikely on a new car but its possible for the starter to get stuck and tapping on it will free it up.
#19 |
Drives: FR-S 6MT
Sitting for weeks.. Well jump the thing and it will start..
#20 |
Just drive it
Drives: 13' FR-S
your youtube clip's title makes our car look bad... Did you try jump start?
#21 | |
Drives: '13 FRS - STX
You probably don't need a new/upgraded battery, you just need to take care of your car and understand what it needs when you modify it away from OEM. |
#22 | |
![]() Like tapping on: * starters (stuck solenoid) * voltage regulators (stuck points) * carburetors (stuck float) * electric fuel pumps * automatic choke (butterfly stuck) * radio * gauges * horn relay * various light bulbs ![]() humfrz |
| The Following User Says Thank You to humfrz For This Useful Post: | strat61caster (12-13-2013) |
#23 | |
Drives: 13 BRZ
#24 |
SLO NO MO
Agree with everyone else here - jumpstart the FRS from your XB. The stock battery isn't very good in my opinion. It drops below the level necessary to provide cranking way too soon, and once the battery has gotten to that point, its life degrades from there and only gets worse.
#25 | |
Drives: FR-S 6MT
#26 |
Sideways and Smiling
+1 on the battery being the likely culprit - start there, easiest fix, 95% likely your problem.
#27 |
Drives: 2015 Series.Blue
Have to deal with this stuff all the time at work.
Amps and capacity are different. You can have a very tiny battery with a crazy amount of amps, but very little capacity (Those tiny Odyssey batteries come to mind). These cars appear to have a pretty small capacity battery in them to begin with. After that, you have it sitting for quite a while, and modern cars do have power drains (alarm, clock, ECU, etc). Now add to that being cold (less amps) and simply temperature changes causing the charge to degrade, and yeah, it's not going to start. Just because the battery is low on charge, doesn't mean it's bad! Just charge it and go. Running the battery down to nothing (leaving the lights on overnight, etc) can damage the battery, but as you had over 12 volts, it sounds like it's fine. |
#28 |
Updated see first post!
| Weird sounds and liquid dripping from car | kam | Issues | Warranty | Recalls / TSB | 21 | 05-07-2014 07:01 PM |
| car making weird noises after 19" tires installed | riironman | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 0 | 11-17-2013 10:28 PM |
| Pop-Start with Push-Button Start | cmspooner | BRZ First-Gen (2012+) — General Topics | 5 | 03-22-2013 02:45 PM |
| Push Start Rough Engine Start Up | joergasm | Engine, Exhaust, Transmission | 3 | 12-12-2012 03:44 AM |
