Old 12-08-2013, 02:34 AM   #211
Tromatic
Originally Posted by Rombinhood@OpenFlash View Post
It's certainly not super aggressive. As I understand it, going from a well calibrated conservative map only gives up a tiny bit of power over the super aggressive map. But in backing things off slightly (to be conservative), you essentially get a tune that can be used in a variety of cars in a wide range of conditions. The guys at Vishnu have been tuning Suby engines for 15 years so I feel pretty comfortable with the drugs that they are pushing
When they get bored, I would appreciate having the option of having something between stock and Stage One. I need to figure out how to do that, I guess!
Old 12-08-2013, 03:09 AM   #212
Burn
Slack Bum
Burn's Avatar
Drives: FT86
Originally Posted by nlowell View Post
Looked at your data map - looks like you went 1/2 throttle through 1st gear then full throttle through the tail end of gear 2 and 3? You might want to do a run or two in third gear starting from ~2k RPM and going all the way to the 4th gear shift. This will give you a full gear to look at.
ok, i'll give it a try.. thanks dude
Burn is offline   Reply With Quote
Old 12-08-2013, 08:40 AM   #213
Boofneenee
Go-Kart Enthusiast
Boofneenee's Avatar
Drives: Toyota Scion FRS
Yes it made my car faster yes it have it more noticeable torque but most importantly, it improved the drive-ability of my car. Car pulls solid likea train, tq dip minimized and the engine is just so much more responsive overall.
FRS
Current mods: K&N air filter, OFT, OFH, berk high flow cat front pipe, Q300 exhaust, lighter wheels
Boofneenee is offline   Reply With Quote
Old 12-08-2013, 09:00 AM   #214
Malt
Drives: 2015 WRX
Was 35 thus morning so first real cold start attempt since I revised the pulse width tables. Car acted like it wanted to start on the first crank but after 3-4 seconds it stumbled and died. Next attempt it cranked right up. If I would have given a little gas it would of been fine on the first crank. This is livable so unless anyone has any other suggestions I'm probably going to just deal with the very slightly rough first cranking attempt.
I'd still like an answer on the Perrin 3" maf intake. Perrin supplies the MAF scale tables, is that all that is needed or will it also require fueling adjustments or will the ecu use LTFT to compensate for the increased flow?
Sent from my SCH-R970C using Tapatalk
Malt is offline   Reply With Quote
Old 12-08-2013, 12:10 PM   #215
Tiremonkey0824
Drives: 2013 Argento 6mt
Can anyone tell me if you still get the "dead pedal" feel when you switch back and forth between e85 and 93 octane maps?
Tiremonkey0824 is offline   Reply With Quote
Old 12-08-2013, 12:19 PM   #216
Malt
Drives: 2015 WRX
Yes, pretty sure that happens every single time you reflash if you don't wait a few seconds after the reflash to crank the car.
Old 12-08-2013, 12:20 PM   #217
Tiremonkey0824
So if i wait 2 or 3 minutes to crank then i wont get the dead pedal?
Old 12-08-2013, 12:29 PM   #218
Luckrider
My Other Ride's a Jeep
Luckrider's Avatar
Drives: 2013 BRZ Limited
If I am not mistaken, it is pedal calibration. The pedal needs to hit WOT several times before it will be properly calibrated which is what leads to dead pedal (the not being calibrated part). Before starting, but after flashing, put the car in the on position and step on the pedal to the floor for a second about 10 times.
Luckrider is offline   Reply With Quote
Old 12-08-2013, 12:42 PM   #219
Malt
Drives: 2015 WRX
I've done that without success and sometimes with success. I vaguely remember Shiv posting that you needed to let the car go through its initial "boot"? To prevent it from happening, or you could go to WOT a couple times then turn the car of and back on. Both work
Old 12-08-2013, 02:09 PM   #220
TruRace
TruRace's Avatar
Drives: FRS-Raven-MT
After 2 driving cycles it usually is back to normal for me. Regardless if I go WOT or not.
TruRace is offline   Reply With Quote
Old 12-08-2013, 09:38 PM   #221
Shad0ez
Shad0ez's Avatar
Drives: 2013 Raven Black
So it looks like AFR at WOT seems to be right around where it should be, but is it normal for AFR to be low to mid 14's at cruising speeds? If it helps, only mods I have are an injen intake and takeda cat back on top of the OFT's E85 map.
Shad0ez is offline   Reply With Quote
Old 12-08-2013, 09:45 PM   #222
Cross
It's the Mad Cow
Cross's Avatar
Yes cruising this is normal
The Following 2 Users Say Thank You to Cross For This Useful Post:
Robert@Openflash (12-09-2013), Shad0ez (12-09-2013)
Old 12-09-2013, 01:27 PM   #223
Cross
It's the Mad Cow
Cross's Avatar
Great to see Shiv and Robert back, I was curious as to if you guys would be making changes to the E85 tune now with people supplying logs in regards to cold starts.
I know you have a lot to deal with having just gotten back so no rush its not a huge issue but I was curious.
Thanks and again Great to have you guys back!
Old 12-09-2013, 03:37 PM   #224
Robert@Openflash
Robert@Openflash's Avatar
Drives: C6 Z06
Hey,
We will make some changes once we test out the cold start during this holiday season. We are just starting to get into the high 20's and low 30's lately in the morning so further testing will help. Right we are catching up from the past week of absence and make sure we fulfill all the order and answer more of you guy's questions. Development is not stopping as you will soon have some new updates from Shiv.
Cheers
Robert@Openflash is offline   Reply With Quote
The Following 6 Users Say Thank You to Robert@Openflash For This Useful Post:
CamryDS (12-09-2013), Cross (12-09-2013), fstlane (12-10-2013), Indestruct (12-09-2013), Shad0ez (12-09-2013), WRB5titch (12-09-2013)
OpenFlash Tablet Rombinhood@OpenFlash Software Tuning 1838 07-29-2023 07:35 PM
Openflash Tablet v1.31 beta maps (including Stage 2!) now available for download Shiv@Openflash Software Tuning 354 02-08-2015 06:23 PM
Is Openflash tablet detectable? Boofneenee Software Tuning 25 05-02-2014 11:03 PM
OpenFlash Tablet Stage 1 v1.2 maps available for download Shiv@Openflash Software Tuning 31 10-31-2013 09:45 PM
WTB Openflash Tablet Vlady Want-To-Buy Requests 0 10-25-2013 01:10 AM
