Old 12-06-2013, 09:32 AM   #15
ahaghshenas
ahaghshenas's Avatar
Drives: Subaru BRZ
Wiring harness needs to be cut/soldered, so right there I wouldn't say its a true drop in solution.
Cutting the wiring harness is not a big deal.
More worried about having to mod the fuel pump assembly
ahaghshenas is offline   Reply With Quote
Old 12-06-2013, 09:41 AM   #16
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
The modification needed to be done on all up to date FP's only needs to do a simple cut to the regulator to separate it from the OEM filter. It is easier to do and to return to stock if needed later on than soldering/cutting cable.
When pumps first started to be sold it was a bit more involved as the canister itself would not close with the bigger pumps, but those issues have already been addressed and all available FPs don't require any more modification than separating the regulator from the OEM filter.
Old 12-06-2013, 10:02 AM   #17
spdbydesign
spdbydesign's Avatar
Drives: 2010 Nissan GTR
Currently two options exist:
1.) Use the supplied Pig-Tail and splice the power/ground wires off the harness. (5 minute job with a crimp tool)
I will work on creating a simple plug-n-play harness for the community.
2.) Buy the DW FR-S/BR-Z Install Kit for $21 at Summit Racing. http://www.summitracing.com/parts/dwk-9-1010/
Their pump uses the Denso style plug, so it would be plug-n-play and cross compatible with this pump.
spdbydesign is offline   Reply With Quote
The Following User Says Thank You to spdbydesign For This Useful Post:
Sportsguy83 (12-06-2013)
Old 12-06-2013, 10:19 AM   #18
Sportsguy83
Drives: Limited BRZ
Originally Posted by spdbydesign View Post
I would hope that anyone changing out their fuel pump would be capable of cutting and splicing the power/ground (2) wires.
For the time being, the DW Install Kit for the FR-S is $21 at Summit Racing. http://www.summitracing.com/parts/dwk-9-1010/overview/
Awesome. I didn't mean to say it was hard, I agree with you soldering/splicing is way easier than actually doing the install. Good to know the DW kit is available to purchase aside from the pump itself as that does provide the plug and play connector. Great detail that you will work on providing one from SBD.
Desno quality FP is unmatched.
Old 12-06-2013, 10:20 AM   #19
nelsmar
Does anyone have any info on how this pump compares to the DW65c?
Also the pics above are a tad hard to read the exact measurements, do you have any documentation thats easier to read? I did a quick search and find lots of info on Chinese ones so I would love to know the real specifications incase the Chinese aren't exact.
My flickr - Canibeat
Local magazine scout
Old 12-06-2013, 10:27 AM   #20
spdbydesign
All of the Chinese Pumps, including the DW65c, are based off of the 38mm Denso pump design. (Denso has been making this body style for many, many years.)
Externally the Denso 38mm Casing appears identical to the DW65c, and is the same overall dimensions both width and length.
Also carries the same power plug, so it's compatible with their Plug-N-Play harness.
There are some things you can skimp on money wise, fueling is not one of those areas.
Old 12-06-2013, 10:29 AM   #21
spdbydesign
With that said, I put my faith in Toyota/Subaru in selecting Denso as their fuel pump supplier. Speaks volumes to me, just as Nissan selected them for the GTR.
You can't beat their quality and reliability track record.
They are the undisputed world leader for a reason.
Old 12-06-2013, 04:17 PM   #22
spdbydesign
DAMotorsports (12-06-2013)
Old 12-13-2013, 09:30 PM   #23
spdbydesign
If anyone is in the market for a fuel pump upgrade, shoot me a PM.
I'm eager to get some of these pumps in cars to gather additional data/feedback.
Old 01-26-2014, 08:59 PM   #24
Sportsguy83
Drives: Limited BRZ
Hi FT86Club,
This is our first post and we are definitely looking forward to settling down. I see many familiar faces and am humbled to be apart of the vendor community.
Do you still sell the 290 LPH pump?
Old 01-27-2014, 04:13 AM   #25
spdbydesign
No, we don't buy or resell any of the Chinese made fuel pumps at this point.
Sportsguy83 (01-27-2014)
Old 01-28-2014, 04:23 PM   #26
Sportsguy83
Drives: Limited BRZ
^ Welcome back
@spdbydesignchris
Old 01-28-2014, 04:35 PM   #27
spdbydesign
Ha, thanks!
Old 02-04-2014, 04:48 PM   #28
spdbydesign
SOLD OUT, expecting another shipment next week.
Thanks again for your overwhelming support
Chris
Fuel pump issues jamesm Software Tuning 17 07-10-2018 05:46 AM
FS: Visconti Fuel Pump Sportsguy83 Engine, Exhaust, Bolt-Ons 0 03-31-2013 04:45 PM
Fuel pump issue. sevi21 Issues | Warranty | Recalls / TSB 13 02-01-2013 09:57 AM
Car fuel pump on... Genomaxter Engine, Exhaust, Transmission 5 11-29-2012 10:06 AM
Dynosty FR-S/BRZ Fuel System Upgrades! Deatschwerks DW65C Fuel Pump Dustin@Dynosty Engine, Exhaust, Bolt-Ons 3 08-21-2012 04:53 PM
