go_a_way1
Old 11-23-2013, 01:15 AM   #1961
Fast_Freddy
Drives: Passat
Will 245-40-17 fit on 17x8 +35 rims with no rubbing or should I stick with 225-45? Stock springs and no intention of changing them. Could I do 225-45 up front and 245-40 in back or would it look weird on 8" rims? TIA
Fast_Freddy is offline   Reply With Quote
Old 11-24-2013, 07:49 AM   #1962
BrunoM
Drives: GT86
Originally Posted by BrunoM View Post
Hi Slick and thank you for your answer.
That's because I have searched for this setup and haven't found it that I ask. The only guy saying he has tried it is Slance86
http://www.ft86club.com/forums/showp...1&postcount=47
He had 18x9.5 +38 wheels, stock coilover, and Eibach Sportline on 235/40/18.
An wheeldude has the 255/35/18 setup on stock coilover and Eibach Sportline with no issue
That's why I asked if someone else has already try this setup because I will try this one in max 10 days, my Sportline springs are already in shipping process.
Without any drop, there are no issue at all with my 18x9.5 +38 Rota Grid on my 235/40/18, and I hope Slance86 is right when he says there is no rubbing issue with some drop with Eibach Sportline springs. I doubt but I hope. I got Camber bolts too to see the limit of that setup.
Has other one guys, I like the concave it make in that wheel setup. I hope it will be ok because it would be cool to get this setup
Thank you all of you for all your answers on that thread, it's very helpfull
Hi everybody.
Just got my sportline springs install yesterday. I have no coilover. I am running rota grid 18x9.5 et38 with 235/40/18 all around and there is no issue for the moment. And I love the look this setup is giving to the car.
There is only 1 or 2 mm between the struts and the tire but it's ok. What you have to do to be sure to stay align is to mark the front bolts before get them out so you can reinstall them exactly as the were.
I hope it will help
BrunoM is offline   Reply With Quote
Old 11-30-2013, 02:54 PM   #1963
anewprelusion
Will this fit?
WedsSport SA67R - 18x9.0 +36mm 5x100 (Square)
Tires = 225/40 or 245/35 (Want to keep apprx stock diameter)
Lowered on Swift Springs with front SPC Camber Bolts & Rear LCA's
Thanks!
anewprelusion is offline   Reply With Quote
Old 11-30-2013, 03:44 PM   #1964
Slick
Slick's Avatar
Drives: FR-S Firestorm 6MT
Originally Posted by anewprelusion View Post
Will this fit?
Thanks!
Yes, no issues.
I'm pretty much on the same setup but +35. Go with the 245/35R18 as it gives you the perfect diameter and better suited for that wheel.
Slick is offline   Reply With Quote
The Following User Says Thank You to Slick For This Useful Post:
anewprelusion (11-30-2013)
Old 12-04-2013, 07:28 PM   #1965
knoteasy25
Drives: r56 mcs
Will this fit well on stock suspension?
Originally Posted by JoeBoxer View Post
I would run either 8.5 or 9 all around, no real need to stagger for a half inch. You could run 8.5 with 225/40 or 235/40 or 18x9 with 245/35 or 255/35.
Edit you could run 235/40 on the 9" all around also
I am interested in these same wheels with 18 235/40 or 225 square on stock suspension. I like the concave look what offset can I get without any poke.
Square and Staggered.
Thank you
knoteasy25 is offline   Reply With Quote
Old 12-04-2013, 08:09 PM   #1966
juanam0909
Drives: scion fr-s
Originally Posted by RavSpec View Post
With just spring , won't work. Need camber arms .
Front might work, rear major poke.
It worked
Sent from my LGMS769 using Tapatalk
juanam0909 is offline   Reply With Quote
Old 12-08-2013, 12:11 AM   #1967
kkkirbyyy
kkkirbyyy's Avatar
Drives: 2015 STi and '93 Sentra Se-r
Hey guys, im getting 57 extremes 18x 9.5 +40. looking to drop around 2.3-2.5 inches on KW V3's. I wanna know if I can run 245/40's with no rub or would I have to be 245/35...I wanna get the meatier end of the deal without rubbing. thanks in advance!
kkkirbyyy is offline   Reply With Quote
Old 12-09-2013, 03:53 AM   #1968
Freshfrs86
Freshfrs86's Avatar
Drives: Scion FRS
This is a great thread. I have two different setups in mind it just depends if I want to be patient or not lol
1st - is cosmis XT-206R 18x9.5 +10 with a 15mm wheel adapter tires 245/40
2nd (me being patient) - same rim/size but +35 5x100 no adapter 3mm spacer F, 5mm spacer R
FYI this rim does have concave
Lowered possibly 1.5 not sure right now.
Freshfrs86 is offline   Reply With Quote
Old 12-09-2013, 03:56 AM   #1969
ft86me
ft86me's Avatar
Drives: 2013 FRS
Confirming that my 18x10 +44 fit with no problem on kw v3 coils w stock drop from kw factory. Camber was left the same as my 18x9.5 +38 setup. Gotta admit the setup now looks cleaner! Hope this helps.
ft86me is offline   Reply With Quote
The Following 2 Users Say Thank You to ft86me For This Useful Post:
Freshfrs86 (12-09-2013), kkkirbyyy (12-10-2013)
Old 12-09-2013, 03:57 AM   #1970
Freshfrs86
Freshfrs86's Avatar
Drives: Scion FRS
Link to pics?
Old 12-09-2013, 04:00 AM   #1971
ft86me
ft86me's Avatar
Drives: 2013 FRS
Will this fit? (width, offset and tire size Qs)
Only have two pics right now that are cell phone pics which are on my signature for my build and a little video on instagram profile @Freshfrs86
The Following User Says Thank You to ft86me For This Useful Post:
Old 12-09-2013, 04:16 AM   #1972
Freshfrs86
Freshfrs86's Avatar
Drives: Scion FRS
@ft86me how much camber did you have? About how low are you? Have you or are dialed in yet or keeping it where you had last? Are you comparing your setup to my 1st plan, 2nd plan or both?
Old 12-09-2013, 04:17 AM   #1973
ft86me
ft86me's Avatar
Drives: 2013 FRS
Oh I was just confirming that my setup fits for people that are wondering. For your setup I'm not sure what settings you will need.
Old 12-09-2013, 04:18 AM   #1974
Freshfrs86
Freshfrs86's Avatar
Drives: Scion FRS
Ok thanks! That does give me an idea though.
Determining the proper width size of the tire CyberFormula Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 49 05-23-2014 10:11 AM
Correct tire width for each wheel width DarrenDriven Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 10 08-16-2012 03:03 PM
TIRE SIZE CALCULATOR White64Goat Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 08-15-2012 03:31 AM
Tire Width vs Wheel Width Synack Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 40 08-13-2012 12:21 AM
