Old 11-30-2013, 11:59 AM   #141
Cross
It's the Mad Cow
Cross's Avatar
To give an update I did my first full tank went from 340 or s a tank to 312 this tank. 25MPG although the factory MPG Calc claims 33MPG...
Either way not bad at all on E85. I was not on it a lot but 25 MPG is fine by me.
On another note Robert and Shiv we will be placing our order on Monday looks like 3 OFT's for the Tucson Group will be added with 2 more waiting until after Christmas.
Old 11-30-2013, 12:06 PM   #142
jeebus
The factory readings are likely based on the o2 sensor data...which read based on gas stoich so they will end up WAAAAY off here.
FYI, my avg mileage was 29.7 in all mixed driving on gas and it's 22.2MPG now on e85.
jeebus is offline   Reply With Quote
Old 11-30-2013, 01:24 PM   #143
Td-d
Garden variety obsessive
Drives: 2009 Sti Hatch; 2015 Audi RSQ3
Why don't you use the Fuel Multiplier Display Offset table to correct it? I would think that similar to the single float value in other Subarus, you would just multiply the values in the table by the appropriate factor. Worth a try.
Td-d is offline   Reply With Quote
Old 12-03-2013, 11:45 AM   #144
abutterman
abutterman's Avatar
Drives: 2013 BRZ Limited - WRB, MT
I noticed what sounded like possible knocking in the mid rpm range when i go WOT. it looks like after 3krpm, i'm at afr: 14.6, stft: 1.56, ltft: 3.12, ignition adv: 50-52ish, adv multiplier .97. This is on 93 octane, drop in filter, greddy axle back. Do these numbers look ok?
abutterman is offline   Reply With Quote
Old 12-03-2013, 11:46 AM   #145
Cross
It's the Mad Cow
Cross's Avatar
That sounds like an excellent idea I will give it a try!
Old 12-04-2013, 04:07 PM   #146
Malt
Drives: 2015 WRX
So I've been struggling over the past few days to resolve my cold start issue with the E85 maps. At the suggestion of a member I modified the Cranking pulse width tables which helped a little bit. I went from 30+ cranking attempts to get started to around 1-3 if I give it a little throttle on startup.
I could live with that but this afternoon I went out to crank the car and it has me thinking that there is something that needs to be changed besides the Cranking pulse width tables. It was 65 degrees outside and exactly the same issue, took 3 attempts to get cranked.
The car is running great once I get it started, A/F ratios rock solid at 12.3 and LTFT is sitting at 2.3 at WOT.
Is this something I should expect using E85 pretty much all the time as 65 degrees seems to be a little warm to be having cold start issues? Is there anything else I can look at adjusting to correct this issue as its starting to get slightly annoying and I'd like to think its possible to have the car actually crank on the first try. Any help would be appreciated.
Malt is offline   Reply With Quote
Old 12-04-2013, 04:11 PM   #147
Td-d
@Malt - was the engine hot when you tried to crank it this afternoon?
Old 12-04-2013, 04:15 PM   #148
Malt
Drives: 2015 WRX
No, it had been sitting since last night.
Old 12-04-2013, 04:21 PM   #149
Td-d
Ok, so it's not the hot start enrichment tables. But there's a clue in what you say about the throttle. The way the logic works is that if the throttle is pressed whilst cranking, the base pulse width is cut, by an increasing percentage as throttle % angle gets greater. Might be worthwhile cutting back the additional cranking enrichment just a little, see if that helps. You can also verify this by logging AFRs at cranking.
Old 12-04-2013, 04:37 PM   #150
Malt
Drives: 2015 WRX
Code:
Cranking Injector Pulse Width
195.50
189.75
184.00
178.25
140.88
90.56
48.000
39.000
27.400
23.104
18.800
15.400
12.000
11.504
11.504
11.504
Code:
Engine Cranking Enrichment
1.148
1.148
1.148
1.148
1.102
1.000
1.000
Those values are the same for 115, 215, 315, 415, and 515 columns.
Are you saying to lower the engine cranking enrichment tables a bit or lower the pulse width down some?
Old 12-04-2013, 05:07 PM   #151
Tromatic
Jeez. Completed order on Monday, got it today (Wed). That does not suck!
The Following User Says Thank You to Tromatic For This Useful Post:
Rombinhood@OpenFlash (12-04-2013)
Old 12-05-2013, 10:48 AM   #152
Malt
Drives: 2015 WRX
I'm just going to swap back to the normal stage 2 maps until shiv has time to get the E85 maps fully functional for cold starting. As it stands right now, they are not. I can't expect him to drop everything to fix my issues and I'm obviously over my head in this whole modifying my own tune thing seeing how I can't get romraider to work and tunerpro doesn't seem to have the tables I need to adjust to fix this.
I appreciate your help but for now the fact that I can't get my car to start like normal when its 65 degrees outside is unacceptable to me. Maybe I'll try E85 again in the summer.
Old 12-05-2013, 11:01 AM   #153
Tromatic
Reading some of this (over my head, as I said) makes me glad I have no desire to experiment on my own. I'm assuming you could destroy your engine in short order with this if you are not careful, correct? If so, just how quickly could you do it, and what would be the most harmful thing you could do? I'm assuming super-lean or detonation, correct? NOTE: I have no plans to grenade my engine, which is why I'm not going to even pretend to know what I'm doing. I'll happily pay Vishnu to tweak my maps if I get to that point.
Old 12-05-2013, 11:09 AM   #154
overlookedx
overlookedx's Avatar
Drives: 2015 WRB Limited
I feel the same way. Though I didn't have as much trouble starting as you did, I would like it to reliably start up on the first try. Even if it only takes two tries to get it running, it still doesn't feel good that first time when your engine tries to start and just dies.
I switched back to regular gas this morning, mostly in anticipation of a track day, because I don't want to haul a bunch of E85 with me to the track. I was thinking that after the track day I would immediately go back to E85, but I don't want to have cold start issues again so I will hold off until this issue is at least partially resolved.
Superfast Jellyfish
overlookedx is offline   Reply With Quote
OpenFlash Tablet Rombinhood@OpenFlash Software Tuning 1838 07-29-2023 06:35 PM
Openflash Tablet v1.31 beta maps (including Stage 2!) now available for download Shiv@Openflash Software Tuning 354 02-08-2015 05:23 PM
Is Openflash tablet detectable? Boofneenee Software Tuning 25 05-02-2014 10:03 PM
OpenFlash Tablet Stage 1 v1.2 maps available for download Shiv@Openflash Software Tuning 31 10-31-2013 08:45 PM
WTB Openflash Tablet Vlady Want-To-Buy Requests 0 10-25-2013 12:10 AM
