Old 11-26-2013, 05:37 PM   #29
Shiv@Openflash
Shiv@Openflash's Avatar
Drives: 2013 FRS
Originally Posted by Lytheum View Post
gave e85 a shot today. anyone try it on a winter blend yet? ran the car down and put about 11.4 gallons in. drove about 2.5 miles home and then flashed the map. i put about 30 miles on it driving easy and then did one second gear pull. everytime i try to download the data log openflash manager freezes. maybe ill try to reinstall it. fuel trims were negative -10ish and seemed to be a rich afr.
You should be perfectly fine with any reasonable blend of E85 (winter or summer). The ECU will trim fuel accordingly. Same reason it is able to compensate if you only get 11.4 gallons of E85 vs a full 13 gallons.
As of yesterday morning's update, there is a bug in the user software that prevents you downloading the the log from from your OFT. We hope to have this sorted out by tomorrow morning. Sorry about that
Shiv@Openflash is offline   Reply With Quote
Old 11-27-2013, 11:02 AM   #30
RC51ed
RC51ed's Avatar
Drives: 2013 Scion FRS
So the past couple of days I noticed a couple hard cold starts. I have an auto start alarm so when the engine cranks over the car starts for a couple seconds and then dies. But when it tries to start again it stays runing. Not a biggie for me because I expected this with the e85 fuel. So I wanted to know if others had experienced this.
RC51ed is offline   Reply With Quote
Old 11-27-2013, 11:32 AM   #31
overlookedx
overlookedx's Avatar
Drives: 2015 WRB Limited
I had my first non-start this morning. Had to give it two tries before it finally started running. But like you, I expected this with E85.
Superfast Jellyfish
overlookedx is offline   Reply With Quote
Old 11-27-2013, 12:06 PM   #32
jeebus
I had it yesterday. Check your trims and see if you are running a bit lean at WOT. I was. Added a gallon of 91 and trims cleaned up, cold start was a non-issue today as well.
jeebus is offline   Reply With Quote
The Following 2 Users Say Thank You to jeebus For This Useful Post:
fstlane (11-30-2013), WRB5titch (11-27-2013)
Old 11-27-2013, 12:21 PM   #33
garfull
garfull's Avatar
Drives: FRS(sold), AP2, R35, FJC, ED9
for those that are using the torque app to monitor the ecu that if you set your fuel type for e85, the correct stoichometric afr reading for e85 is 9.7 and will display as such so not to be alarmed if it doesn't read 14.7 as i was the first time. again this is only if you have the fuel setting set to e85. otherwise if fuel type is set to reg gas it still reads 14.7 which is still fine because the o2 lamba is still 1.0. well this is how i understand it.
interesting read that explains in more detail. http://www.e85mustangs.com/tuning.html
garfull is offline   Reply With Quote
Old 11-27-2013, 12:26 PM   #34
Shiv@Openflash
Drives: 2013 FRS
Originally Posted by garfull View Post
i do want to add for those that are using the torque app to monitor the ecu that if you set your fuel type for e85, the proper afr reading for e85 is 9.7 not 14.7 as it would for reg gas.
Not sure how the Torque app calculates AFR but if it's read/interpreted by o2 sensor data like everything else I've seem, stoich will still be displayed by 14.7 on e85. Same as gasoline. From there, it will richer (lower) under load just as one would expect. While e85 does indeed requires much more fuel mass per fixed oxygen mass, it is still monitored by oxygen sensors that assume gasoline operation and equate oxygen content levels to lambda/AFR.
Just my 2c
Shiv
The Following User Says Thank You to Shiv@Openflash For This Useful Post:
garfull (11-27-2013)
Old 11-27-2013, 12:34 PM   #35
garfull
garfull's Avatar
yup that's how i understand it too. i'll most likely switch the fuel setting back just to be consistent with numbers that im familiar with.
that was fast reply. thanks for confirming.
would you be able to share to how the advanced multiplier data is captured. id like to use the app to monitor it too for day-to-day use since the display is larger but still use the oft data logging for the track.
Just my 2c
Shiv
Old 11-27-2013, 12:40 PM   #36
Shiv@Openflash
Drives: 2013 FRS
yup that's how i understand it too. that was fast reply. thanks for confirming.
I don't think you will be able to capture anything but standard obd2 data with the Torque app (or any other universal datalogging device). PIDs unique to subaru will require unique CAN commands. But that is beyond the range of my knowledge. I just ask our programmers what we need and they find a way to do it
Also more data display options will soon be coming for the OFT. Some of which will mean big easy to read numerical displays.
Cheers
Shiv
Old 11-27-2013, 12:50 PM   #37
krulux
Its only been in the low 30s for us here in Mid Ga... car starts first bump of the key... E85 tune.
I have noticed a substantial increase in power over stock tune and the speed at which the grin comes on my face since running the E85 tune. Still loving my OFT!!
Almost ready to pop on the OFHeader... just need to figure out who's gift is getting returned to fund it...
krulux is offline   Reply With Quote
Old 11-27-2013, 01:02 PM   #38
WRB5titch
Drives: WRBrz
I was also having trouble starting up yesterday morning (took two tries) and this morning was a bit rough but started up on the first try. I'll try adding a gallon of 91, thanks!!
WRB5titch is offline   Reply With Quote
Old 11-27-2013, 01:15 PM   #39
jeebus
Just my 2c
Shiv
I'm assuming they just multiply the reported AFR by .66 to get e85 AFR readings since the sensors are set for gas.
Old 11-27-2013, 01:16 PM   #40
jeebus
check the trims first. If you are still slightly rich, no reason to add 91.
Old 11-27-2013, 01:24 PM   #41
WRB5titch
Drives: WRBrz
Thanks. I'll keep an eye out for that
Old 11-28-2013, 12:50 AM   #42
WRB5titch
Drives: WRBrz
Looks like mine was running lean at WOT as well, LTFT went as high as 5.14. Added a gallon of 91 as @jeebus suggested and all is well.
AM also dropped to .98 for a bit but went back up before I added the gallon of 91...
The Following User Says Thank You to WRB5titch For This Useful Post:
jeebus (11-28-2013)
Quick Review-OpenFlash (Dyno Test) - Stock vs. Vishnu Stage 1.0 vs. Vishnu Stage 1.1 FRSTEVE Software Tuning 105 08-04-2017 04:48 AM
FBM 604Hp 472Tq -- Stock Motor Stage 2 Turbo Kit FullBlown Forced Induction 414 07-14-2014 09:52 PM
Ecutek stage 2 tune on stock brz 01s0uljah Software Tuning 15 10-15-2013 02:52 PM
Anyone choose zeta stage 1 over stage 2? BlackyRose Engine, Exhaust, Transmission 2 07-06-2013 01:32 PM
>> EcuTek << STAGE 1 / STAGE 2 / E85 - Tunes Available FT-86 SpeedFactory Engine, Exhaust, Bolt-Ons 133 05-21-2013 01:39 AM
