#15 |
Drives: FRS
I have the fix
All aftermarket tails are subject to condensation due to the design flaw .
Check my posts re - the fix - ( cost - 99 cents). (double gaskets etc. will eventually lead to leaks) Last edited by RFB; 11-23-2013 at 10:28 PM. Reason: Spellink |
#16 | |
Drives: 2013 FRS
#17 |
Drives: DGM Subaru BRZ
There's a few ways to get a second. I was shipped a second set of Toms and told to to use my old one and the new one together. There's also a DIY on this forum on how to make a thicker gasket. Use your oem gasket with the aftermarket.
| The Following User Says Thank You to JollyJON For This Useful Post: | ft86me (11-23-2013) |
#18 | |
Drives: 2013 FRS
know where i can acquire foam? |
#19 |
I believe it is called neoprene foam although i don't know where to buy it from. hope that helps.
heres the thread for the diy gasket below: http://www.ft86club.com/forums/showthread.php?t=26217 |
#20 |
Regional Moderator
Drives: 00-AP1 20-A90 06-Z33 07-FA5 93-NA1
off topic, but with the winter season and having condensation in the tails. could it be possible for the condensation to freeze and crack the tails?
#21 |
Drives: RX-7 / BRZ
I park outside (apartment) and have yet to have any in the daily rain and snow, I think you may have un-evenly tightened the lights creating a spot in the gasket that hasn't sealed correctly.
#22 |
Smokin on Dat Endo
all dat camber you're running in the rear puts too much stress on the tail lights
| The Following User Says Thank You to eddieEndo For This Useful Post: | Juvenile (12-08-2013) |
#23 |
'Senior' Junior Member
Drives: 13 FR-S,08 Mustang Bullitt,06 MX-5
Any big quick changes in temperature or humidity? I have cars that have never been in the weather but I have noticed very light condensation in the tops of some lights (headlights and taillights) when driving from a heated garage into cold outside air. Also see it occasionally when the sun shines directly on the lights when it's very cold outside. Since most light housings aren't completely sealed from the air, warmer air inside the lights exposed to colder air outside can sometimes form a bit of condensation inside the housing.
It's always very minor, it always dissipates quickly and is never enough to pool up in the bottom.
"You'll never know if you don't try" - Shinroko Momose |
#24 |
Drives: 2006 STi
i doubt it. i believe water inside a glass bottle thats closed and water tight would crack because water expands when freezing. This wont be an issue because the tails arent water tight. i could be wrong
#25 |
Drives: FRS
Condensation fix -All tails
#26 |
Drives: 2013 BRZ Limited
Is there any chance of saving my current Toms, despite there already being a good deal of condensation?
I'm considering taking them off, blow drying the inside of the housings, and reattaching with the extra washers. What about new bulb gaskets? |
#27 | |
Drives: FRS
If water stain remains after a gentle blow dry, a swish of pure methyl hydrate should remove any remnant. Remember, as stated in the owners manual - condensation is normal and evaporates. Moisture that remains in the housing is water that has flowed under the gaskets due to bent gasket surface on the car, or because of the dirt pulling the gasket away from the housing, the dirt coming from the rear window runnoff channel leading into the gaskets (PREVENTABLE WITH SNOW MAN SNOT TECHNIQUE). ![]()
| The Following 2 Users Say Thank You to RFB For This Useful Post: | chanomatik (12-16-2014), Steege (11-13-2014) |
| Fix for TOMS and Spyder taillights | scottmcphee | Exterior Parts - Lighting | 16 | 08-29-2015 11:49 AM |
| Wtb TOMS Trunk lip | yugiooh | Want-To-Buy Requests | 1 | 08-19-2014 11:51 PM |
| Aftermarket tails, condensation? | CBR600RR | Cosmetic Modification (Interior/Exterior/Lighting) | 41 | 02-14-2014 10:32 AM |
| SoCal toms red lens | SliverBrz | Exterior Parts (Aero, Lighting, Etc.) | 9 | 11-15-2013 02:19 PM |
| WTT: MY USDM Tails for your JDM/ADM/UKDM Tails | ZC6BRZ | Exterior Parts (Aero, Lighting, Etc.) | 2 | 01-16-2013 12:24 PM |
