Old 11-23-2013, 10:27 PM   #15
RFB
RFB's Avatar
Drives: FRS
I have the fix
All aftermarket tails are subject to condensation due to the design flaw .
Check my posts re - the fix - ( cost - 99 cents).
(double gaskets etc. will eventually lead to leaks)
RFB is offline   Reply With Quote
Old 11-23-2013, 10:34 PM   #16
ft86me
ft86me's Avatar
Drives: 2013 FRS
Originally Posted by JollyJON View Post
I purchased mines from a vendor on this forum (fteightysix) and had issues with condensation on my first set. I contacted them and they quickly got toms to send me another set without having to send mines in first. I was still having issues with the second set and the vendor worked with me to figure out the issue. The issue i was having with the tail lights was that the gasket was not sealing properly with the body so I doubled up the gasket and haven't had any issues since. We also found out from speaking to Subaru that the nuts on the back of the lights are too small which can cause problems. They suggested adding 4 washers to the back of the taillights before screwing them in BY HAND. Hope this helps.
If your thinking about purchasing these tail lights, i highly recommend doing business with fteightysix. Great guys with amazing customer service!
how did you go about getting another gasket?
ft86me is offline   Reply With Quote
Old 11-23-2013, 10:56 PM   #17
JollyJON
JollyJON's Avatar
Drives: DGM Subaru BRZ
There's a few ways to get a second. I was shipped a second set of Toms and told to to use my old one and the new one together. There's also a DIY on this forum on how to make a thicker gasket. Use your oem gasket with the aftermarket.
JollyJON is offline   Reply With Quote
The Following User Says Thank You to JollyJON For This Useful Post:
ft86me (11-23-2013)
Old 11-23-2013, 11:27 PM   #18
ft86me
ft86me's Avatar
Drives: 2013 FRS
well i don't have the old tail lights haha. fml on that. i don't have an extra gasket and i may be getting rain soon so i used sitckey weather sealant thats double sided and went along the ouside rid of where the gasket is. i also used four spacers when tightening down. i have crystal eyes and my passenger one i noticed has a damn good amount of condensation. crossing fingers!
know where i can acquire foam?
Old 12-07-2013, 01:43 AM   #19
JollyJON
JollyJON's Avatar
I believe it is called neoprene foam although i don't know where to buy it from. hope that helps.
heres the thread for the diy gasket below:
http://www.ft86club.com/forums/showthread.php?t=26217
Old 12-07-2013, 02:38 AM   #20
Chen
Regional Moderator
Chen's Avatar
Drives: 00-AP1 20-A90 06-Z33 07-FA5 93-NA1
off topic, but with the winter season and having condensation in the tails. could it be possible for the condensation to freeze and crack the tails?
Chen is offline   Reply With Quote
Old 12-07-2013, 12:05 PM   #21
Kiske
Kiske's Avatar
Drives: RX-7 / BRZ
I park outside (apartment) and have yet to have any in the daily rain and snow, I think you may have un-evenly tightened the lights creating a spot in the gasket that hasn't sealed correctly.
Old 12-07-2013, 04:51 PM   #22
eddieEndo
Smokin on Dat Endo
eddieEndo's Avatar
all dat camber you're running in the rear puts too much stress on the tail lights
eddieEndo is offline   Reply With Quote
The Following User Says Thank You to eddieEndo For This Useful Post:
Juvenile (12-08-2013)
Old 12-08-2013, 12:15 AM   #23
Clembo
'Senior' Junior Member
Clembo's Avatar
Drives: 13 FR-S,08 Mustang Bullitt,06 MX-5
Any big quick changes in temperature or humidity? I have cars that have never been in the weather but I have noticed very light condensation in the tops of some lights (headlights and taillights) when driving from a heated garage into cold outside air. Also see it occasionally when the sun shines directly on the lights when it's very cold outside. Since most light housings aren't completely sealed from the air, warmer air inside the lights exposed to colder air outside can sometimes form a bit of condensation inside the housing.
It's always very minor, it always dissipates quickly and is never enough to pool up in the bottom.
"You'll never know if you don't try" - Shinroko Momose
Clembo is offline   Reply With Quote
Old 12-08-2013, 04:05 AM   #24
SLICVIC
SLICVIC's Avatar
Drives: 2006 STi
i doubt it. i believe water inside a glass bottle thats closed and water tight would crack because water expands when freezing. This wont be an issue because the tails arent water tight. i could be wrong
SLICVIC is offline   Reply With Quote
Old 01-06-2014, 07:10 PM   #25
RFB
RFB's Avatar
Drives: FRS
Condensation fix -All tails
Snow man snot -
Old 11-05-2014, 10:50 AM   #26
Steege
Steege's Avatar
Drives: 2013 BRZ Limited
Is there any chance of saving my current Toms, despite there already being a good deal of condensation?
I'm considering taking them off, blow drying the inside of the housings, and reattaching with the extra washers. What about new bulb gaskets?
Steege is offline   Reply With Quote
Old 11-05-2014, 11:39 AM   #27
RFB
RFB's Avatar
Drives: FRS
Remove dirt from gasket surfaces, re attach with sealant onto the housing first.
If water stain remains after a gentle blow dry, a swish of pure methyl hydrate should remove any remnant.
Remember, as stated in the owners manual - condensation is normal and evaporates.
Moisture that remains in the housing is water that has flowed under the gaskets due to bent gasket surface on the car, or because of the dirt pulling the gasket away from the housing, the dirt coming from the rear window runnoff channel leading into the gaskets (PREVENTABLE WITH SNOW MAN SNOT TECHNIQUE).
The Following 2 Users Say Thank You to RFB For This Useful Post:
chanomatik (12-16-2014), Steege (11-13-2014)
Fix for TOMS and Spyder taillights scottmcphee Exterior Parts - Lighting 16 08-29-2015 11:49 AM
Wtb TOMS Trunk lip yugiooh Want-To-Buy Requests 1 08-19-2014 11:51 PM
Aftermarket tails, condensation? CBR600RR Cosmetic Modification (Interior/Exterior/Lighting) 41 02-14-2014 10:32 AM
SoCal toms red lens SliverBrz Exterior Parts (Aero, Lighting, Etc.) 9 11-15-2013 02:19 PM
WTT: MY USDM Tails for your JDM/ADM/UKDM Tails ZC6BRZ Exterior Parts (Aero, Lighting, Etc.) 2 01-16-2013 12:24 PM
