Old 11-18-2013, 05:53 PM   #155
CARNZ
CHECK ENGINE
Drives: 2004 STi
I'm working on re-hosting the pictures now, since you are not the first person to mention the issue with viewing them
i don't cry about crickets
CARNZ is offline   Reply With Quote
Old 11-18-2013, 06:01 PM   #156
CARNZ
CHECK ENGINE
Drives: 2004 STi
Done, uploaded all of the pics to TinyPic and edited my post to link to those photos now, shouldn't have anymore issues.
Old 11-19-2013, 09:26 PM   #157
Philly758
Drives: GMC
Cheap
I've seen a couple of ideas bouncing around here on how to make this a little cheaper. I love the idea of this and for the most part it looks great, but some of the OEM parts listed aren't perfect.
This is what I came up with for the cheapest way to do it, not sure if you will follow, or if it would actually work because I haven't done it, but it sounds good to me.
I think you have to start with the 21311AA170 - OIL COOLER, COMPLETE at $135 and 21317AA070 - CONNECTOR, OIL COOLER at $30.
I would then run silicone heater hose from the cooler plate, down the front of the block and to the 6mm allen plug you removed in step 5. Say 2 feet of hose here at $4.12/lf is $8.24. http://www.hps-siliconehoses.com/thr..._store=default.
I'd get a 2-pack of 5/8" rubber insulated clamps to use on the front of the engine to keep everything organized, $1.68 http://t.homedepot.com/p/5-8-in-Rubb...792/100130546/.
Brass barbed fitting for $5.94 http://www.mscdirect.com/product/80258445. (I am looking for an alterative for this, has anyone found another option? This seems like the most difficult piece of the puzzle.)
Hose clamp for each end of that hose at $0.89/ea for total of $1.78 http://t.homedepot.com/p/Everbilt-3-...595/100198182/.
Now, to tie the line coming out of the cooler, back into the circulating coolant line. The bottom/front end of BRZ water pipe only has a 3/4" inlet, the FXT had a 3/8" and 3/4" inlet so you could tie into it. So, I would cut into the existing 3/4" heater hose half way between the elbow and the 3/4" inlet and install a tee, the 3/4"x3/4"x3/8" tee is $2.16 at Home Depot http://t.homedepot.com/p/SharkBite-3...i_src=17588969
Say another 2 ft of that 3/8" hose noted above to bring you down to the tee @ $8.24.
You will need 4 more of the hose clamps as noted above for the 3 connections on the tee and the cooler plate outlet at $0.89/ea, total of $3.56.
So grand total, without shipping or tax included, $196.60. That's under $200, slightly ghetto, but should work.
Back to drinking.
EDIT: Upon closer inspection this has basically been done by xxscaxx here. Doesnt look as bad as it did in my head. 1/2" heater hose is probably easier to find and is cheap. I highly recommend using a real hose clamp whenever you remove a factory one, real hose clamps are cheap and infinitely reusable, the factory only uses that style clamp for quick installation, real hose clamps will provide a better seal. I have removed and reinstalled several hoses including transmission lines, I've had leaks with real hose clamps and ended up doubling up hose clamps on the connection to crush the problem.
Originally Posted by xxscaxx View Post
I bought it at lowes, here: 3/4" x 3/4" x 1/2" Tee
Its brass. I actually found a 3/4x3/4x3/8 plastic tee, but the 3/4 side was too big. it must have been 3/4 OD. I was pretty bummed because I thought it was going to work perfect lol.
Heres a pic of it for reference (disregard the other barb fitting in the line. I had bought a 1/2-3/8 barb reducer but didn't use it):
Doesn't look pretty (and it bothers me a LOT), but no leaks so whatever. I thought i'd bought the right clamps but the ones on that stock line are bigger, but i was able to get the clamps i bought on there. was very tight but it got the job done.
I also looped my heater hose around the lower rad because using a straight fitting makes it hard to bend the line and i didn't want it to kink.
Philly758 is offline   Reply With Quote
The Following User Says Thank You to Philly758 For This Useful Post:
Superhatch (11-23-2013)
Old 11-20-2013, 12:18 AM   #158
Kostamojen
Sounds about right for the cheap option.
Old 11-20-2013, 03:51 PM   #159
Malt
Drives: 2015 WRX
I'm really tempted to pull off the hard pipe I installed put the original one back on and do it this way. the rubbing of the hose at the top of the back pipe has me concerned.
Malt is offline   Reply With Quote
Old 11-21-2013, 12:22 PM   #160
xxscaxx
Drives: 2013 SWP BRZ
Those factory clamps might be for "easy installation" but of all my years owning a car, i've never had one of those style clamps leak on me. I will take one of those over the typical hose clamp that digs into the line any day.
If you buy the proper sized factory clamp as above, it isn't going to leak.
was 25 degrees this morning, oil temp at cruising speed around town (40-50mph) = 194.
xxscaxx is offline   Reply With Quote
Old 11-21-2013, 12:36 PM   #161
post_break
Professional Smartass
post_break's Avatar
Drives: White Out FRS
On the fitting that has the 6mm plug, what are you putting on the new barb? Teflon tape?
post_break is offline   Reply With Quote
Old 11-21-2013, 02:30 PM   #162
autobrz
Drives: Mazda 3
quick question to verify...
Is the hose on the cooler inlet (passenger side) 1/2"? So for AT, I would get a 1/2 x 1/2 x 1/2 T fitting?
On the driver side, can I T into either side of the BRZ water pipe that Carnz replaced? I'm guessing both sides have a 3/4" hose, right?
can I use oem hose clamps on the T fittings or is it better to use the snake hose clamps?
autobrz is offline   Reply With Quote
Old 11-21-2013, 02:33 PM   #163
Kostamojen
I just used some Subaru OEM Threebond on the threads. Works about the same.
The Following User Says Thank You to Kostamojen For This Useful Post:
post_break (11-21-2013)
Old 11-22-2013, 04:49 PM   #164
xxscaxx
^ I used teflon tape.
@autobrz - yes that line is 1/2. Not sure what T's you will need though since your AT. You can use any kind of clamp you want - I like the oem ones which is why I used them.
Some installed photos:
The Following 3 Users Say Thank You to xxscaxx For This Useful Post:
autobrz (11-22-2013), CxG (04-25-2016), normancw (11-22-2013)
Old 11-23-2013, 06:22 PM   #165
Philly758
Drives: GMC
I'm sure they factory clamps will work fine. I just had an issue once and am more confident with the screw type clamp.
Nice install! I Like the wire loom on the hose for a little more protection.
Old 11-24-2013, 02:39 PM   #166
xxscaxx
Different strokes for different folks
Thanks, I did it also to kind of hide the line better. Well, "blend" it better with the rest of the loom. I wish I had bought the nylon braided hose cover for it though like what came on my supercharger lines (or like whats on the fuel lines).
The Following User Says Thank You to xxscaxx For This Useful Post:
Philly758 (11-24-2013)
Old 11-25-2013, 12:49 PM   #167
autobrz
Drives: Mazda 3
are there local stores that carry nylon braided hose sleeves?
Old 11-25-2013, 12:54 PM   #168
xxscaxx
not too sure honestly. I know you can get it from here though http://www.techflex.com/
autobrz (11-27-2013)
brz, fxt, oil, oil cooler
OEM Oil cooler from the 2.0 DIT Forester Kostamojen Engine, Exhaust, Transmission 119 09-10-2019 05:28 AM
Bought a 2014 Subaru Forester EAGLE5 Other Vehicles & General Automotive Discussions 10 10-02-2013 12:54 PM
2014 Forester key fob - nicer than BRZ Turbowned Cosmetic Modification (Interior/Exterior/Lighting) 3 04-17-2013 03:35 PM
BRZ 2.0L Turbo in 2014 Forester Sleeperz BRZ First-Gen (2012+) — General Topics 37 03-21-2013 06:42 PM
Review after test driving a 2013 WRB BRZ and 2014 Forester in Okinawa, Japan… 2013GTRNate BRZ First-Gen (2012+) — General Topics 12 02-01-2013 12:29 PM
