Old 11-17-2013, 03:07 AM   #141
Kostamojen
Originally Posted by xxscaxx View Post
So I installed my cooler today. If you want to tee into the hose instead of buying the heater pipe, you need a 3/4"x3/4"x3/8" tee. I actually ended up using 3/4"x3/4"x1/2" tee and was able to slip the 3/8 hose onto the 1/2 line. The 3/8" line runs to the exit of the cooler. I bought the hard line for the exit side that runs next to the injector cover and didn't end up using it because after teeing that line, the bottom of the hard line runs too close to that line and it would make for an awkward fit for hose, so I don't recommend it.
Ps I hate coolant lol.
Pics?
Old 11-17-2013, 05:15 AM   #142
s2d4
s2d4's Avatar
Originally Posted by Kostamojen View Post
Pics?
Yo, I may as well ask again, what are the part number for the 2 hoses, 4 clamps, 2 bolts and the pipe that you used but CARNZ didn't?
Old 11-17-2013, 08:21 AM   #143
s2d4
s2d4's Avatar
Originally Posted by normancw View Post
These are the additional parts (over what CARNZ listed) I can see in his picture from post #106. In his install post, I believe he found the 45 degree angled connector (2045-08-2) difficult to install.
Thanks for the help but 21317aa070 bolts the oil cooler to the engine as previously mentioned.
The other 2 numbers you have listed only covers one hose and one pipe so it doesn't cover all of what I've been asking for the last 2 weeks.
Old 11-17-2013, 04:33 PM   #144
xxscaxx
Drives: 2013 SWP BRZ
I gotcha. I don't have the lower hose though.
upper hose: 807609071
Hard pipe: 21328AA230
Clamps (4): 092315002
The bolts you don't need. They are already present on the side of the block. I didn't know that though so I ordered them (808206010).
If you are looking to buy this stuff, I purchased all of it (minus the lower hose) but didn't use it. PM me if you want em.
xxscaxx is offline   Reply With Quote
The Following User Says Thank You to xxscaxx For This Useful Post:
s2d4 (11-17-2013)
Old 11-17-2013, 04:42 PM   #145
xxscaxx
Originally Posted by PantsDants View Post
Thanks for that. Where did you get your tee connector? Also did you go with plastic or metal?
I bought it at lowes, here: 3/4" x 3/4" x 1/2" Tee
Its brass. I actually found a 3/4x3/4x3/8 plastic tee, but the 3/4 side was too big. it must have been 3/4 OD. I was pretty bummed because I thought it was going to work perfect lol.
Heres a pic of it for reference (disregard the other barb fitting in the line. I had bought a 1/2-3/8 barb reducer but didn't use it):
Pics?
Doesn't look pretty (and it bothers me a LOT), but no leaks so whatever. I thought i'd bought the right clamps but the ones on that stock line are bigger, but i was able to get the clamps i bought on there. was very tight but it got the job done.
I also looped my heater hose around the lower rad because using a straight fitting makes it hard to bend the line and i didn't want it to kink.
The Following 7 Users Say Thank You to xxscaxx For This Useful Post:
CARNZ (11-17-2013), jcw99 (04-21-2016), normancw (11-17-2013), s2d4 (11-17-2013), Synack (05-05-2014), Trap63 (11-18-2013), Turkish (11-17-2013)
Old 11-17-2013, 05:04 PM   #146
CARNZ
CHECK ENGINE
Drives: 2004 STi
Thats one of the main reasons why I didn't do a t-fitting.
I wanted it to look and fit like stock.
Props for getting it done though.
Glad to see a lot of input from others on this topic, plenty ways to put this application to reality.
i don't cry about crickets
CARNZ is offline   Reply With Quote
The Following User Says Thank You to CARNZ For This Useful Post:
Old 11-17-2013, 07:07 PM   #147
xxscaxx
Agreed, but I didn't feel like waiting until February to put this in as I wanted it for winter lol. When the hard pipe comes into stock, i'll order it (already put an order for it actually), and i'll probably swap it out.
Thanks again for the initial DIY.
One thing I hate, is the exit line. It legit sits on the damn injector cover. I was looking at the STi concept and noticed on that cooler that the exit off the cooler is further towards the front of the car.
Old 11-18-2013, 01:49 PM   #148
xxscaxx
Just a little update:
No leaks, everything is good.
Just from taking a peek at my P3 Gauge, oil temps are a few degrees cooler. I usually see a high of 206 when cruising on the highway (and this is in colder temps, it was like 55 today on the way to work), and today I saw nothing higher than 203. Normal driving around town it sits under 200, 198-199.
Coolant is also 2 degrees down, was ALWAYS on 194, now its at 192.
Nothing crazy, but its doing something. Can't wait to see how it reacts in the summer, as I saw 215-219 then. I can imagine once it gets even colder that the oil temp will not touch 200 degrees.
Old 11-18-2013, 02:02 PM   #149
post_break
Professional Smartass
post_break's Avatar
Drives: White Out FRS
I need to do this. My track temps for oil were over 250F. I plan on doing this at the same time as the mishimoto radiator.
edit: I can't read...
post_break is offline   Reply With Quote
Old 11-18-2013, 02:10 PM   #150
CARNZ
CHECK ENGINE
Drives: 2004 STi
There's a step by step diy in the first post.
Old 11-18-2013, 02:32 PM   #151
post_break
post_break's Avatar
You're exactly right. I was so excited by the post I skipped right past it...
Old 11-18-2013, 05:08 PM   #152
post_break
post_break's Avatar
Now I know what is wrong, you embedded Facebook photos on your first post. Those don't load on chrome for some reason. Either way now I can see the photos in a different browsers, helps big time!
Old 11-18-2013, 05:47 PM   #153
CARNZ
CHECK ENGINE
Drives: 2004 STi
strange, I use Chrome and everything shows up for me
Old 11-18-2013, 05:51 PM   #154
post_break
post_break's Avatar
I just figured it out! I had a rogue chrome plugin that was blocking ads attack cross posted urls from Facebook. Anyways I'm ordering these parts after work, I hope the back order isn't tremendous.
brz, fxt, oil, oil cooler
OEM Oil cooler from the 2.0 DIT Forester Kostamojen Engine, Exhaust, Transmission 119 09-10-2019 05:28 AM
Bought a 2014 Subaru Forester EAGLE5 Other Vehicles & General Automotive Discussions 10 10-02-2013 12:54 PM
2014 Forester key fob - nicer than BRZ Turbowned Cosmetic Modification (Interior/Exterior/Lighting) 3 04-17-2013 03:35 PM
BRZ 2.0L Turbo in 2014 Forester Sleeperz BRZ First-Gen (2012+) — General Topics 37 03-21-2013 06:42 PM
Review after test driving a 2013 WRB BRZ and 2014 Forester in Okinawa, Japan… 2013GTRNate BRZ First-Gen (2012+) — General Topics 12 02-01-2013 12:29 PM
