#71 |
Drives: Scion FR-S 2013 Raven
Ok
o= FR-S =o |
#72 | |
Drives: '13 Nissan Frontier (4.0L 6spd 2WD)
Grimmspeed bar combined with solid aluminum steering rack bushings is such a great setup that going back to stock would be a disappointment. You can just go full bore in a corner and it will be more precise and controlled than before, none of that little bit of chassis hesitation on initial turn in or slightly squirreliness nature of the chassis throughout the turn. It makes the handling sharper, the steering absolutely linear, and whole car much more toss-able at the same time. That is my experience driving my FR-S with the Grimmspeed bar and TIC steering rack bushings with the stock Michelin's on much lighter and slightly wider wheels (17lbs, 7.5" width) and the traction/stability turned off almost 100% of the time. If you keep or increase the stock unsprung weight you will not see as good results...unsprung weight is everything on ride quality of a stock suspension setup - always reduce it whenever you can.
Had a '13 FR-S Asphalt 6spd manual (bought new 5/25/12, sold 6/10/20) but needed to let her go... she will be missed.
#73 |
Holy crap, you guys are seriously a kick ass bunch of guys. I can tell you right now that all of your positive feedback keeps our team going when times get rough and we need to keep pushing forward. Thank you for the constant reminder that the time and effort are absolutely worth it!
Justin Grimm |
#74 |
What do you think of your strut bar?
Thank you for the review Vracer111.
I just placed on order an the Whiteline rack and pinion bushing
o= FR-S =o |
#75 |
Custom User Title
Drives: Asphalt FR-S MT
I got the Energy Suspension steering rack bushings for $15. And yes they get the job done.
#76 | |
The reason that I wanted to mention that is because some critiques of our bar accuse the slotted mounting holes of having the same design flaw. My response to that is in two parts. The first is that 12ftlbs, through the stock fasteners, provides more than enough clamping force to keep the car in place, no matter how long those slots are. The length of the slot is of no concern in that regard. The second part is that the slots are necessary to be able to place the bar down onto the studs. The studs on each side don't protrude from a coincident plane, so un-slotted holes would make installation nearly impossible. You can set our bar down on a flat table to see the difference in angle. Anyway, carry on, we love seeing good, informed discussion! Matt Beenen Engineering |
| The Following 2 Users Say Thank You to GrimmSpeed For This Useful Post: | Mikepage (11-12-2013), wu_dot_com (11-12-2013) |
#77 |
Drives: accord
#78 |
Edit from Matt : The first is that 12ftlbs, through the stock fasteners, provides more than enough clamping force to keep the car in place, no matter how long those slots are.
This is probably true also for all strut bar. I don't think with this ftlbs of torque any holes will enlarge correct? And this enough to keep the bar in place like you say. You seem to have created a good product Matt. I just want to know if 3 pieces strut do the job too
o= FR-S =o |
#79 | |
Drives: accord
also the slot is absolutely necessary to guarantee fitment. the car engine is not consider as a rigid body. it is free to flex and deflect depending on the loading condition. thus the true position of the two mounting bolts can differ greatly, anywhere from .25" to .5" at times. in addition, the wielding processes of the strut bar also distort the true location of those mount holes. with all those factors combine together with a slanted surface, it is necessary to create a slotted hole. The 12ftlb torque is really there to prevent fatigue damage to the bolt. It is determine based on the actual compressive stress properties of those materials of bolts, strut bars, strut towers combo. Since I never saw the actual calculations, I cannot tell you the exact tolerance that is associated with that 12ftlb. However one of two things will happen if you go over 12 ftlb. One is that the bolt will yield and stretch. The second if the strut bar / strut tower will deform. The likelihood of bolt stretch is more probable. In this case the separation of strut bar from strut tower can occur, thus the holes will elongate because bolt can slide in and out of the slot. in addition, the performance of the strut bar is null because of the additional slack that was generated which need to be taken up before the proper force transfer can take place. On the other hand, under torque will results in separation of strut bar from strut tower during operation. The same failure event will occur as an over torqueing the bolt. Last edited by wu_dot_com; 11-12-2013 at 12:24 PM. |
| The Following User Says Thank You to wu_dot_com For This Useful Post: | Mikepage (11-12-2013) |
#80 |
Drives: 2013 Raven FR-S
I think what a lot of us want to hear is how will our cars feel if we drive in large metropolitan cities (ones without elevation. curves, nice roads) with a lot of big roadways and highways. My commute to work has a few turns but nothing serious. Will I feel the difference on simple things like making a sharp fast right onto a new highway and traveling into and out of strip malls and subdivisions and what not. Its really hard for me to believe that stock tire and suspension guys would feel a difference unless they were driving in upstate georgia or north carolina, etc. I live in Florida where most of the roads are straight with some small oppurtunities to punch it on an entrance/exit ramp or into and out of some small highway curves
#81 | |||
Drives: small
I had contemplated the STI offerings since this is a DD and like the comfort/compliance idea of allowing for vertical compliance but stiffening up lateral loads. However, I want to preserve the integrity of my new chassis as much as possible and believe compliance is the job of the suspension, not the chassis. So for me, make the chassis as stiff as reasonable without going full brace whore and dial in the wheel rates for my driving conditions. In ten years, I expect to have a much more well preserved chassis and a decade's worth of sharper turn-in and more planted feel which =
#82 | |
Drives: small
Of course, if you buy a poorly designed bar, the benefits will be less apparent. People need to stop buying hinged, non triangulated stuff to stop encouraging manufacturers cashing in on bad design. |
#83 | |
It's as you wish, for me, I want to improve the driving feeling even if this car have the better feeling for a car into this range of price. Am sure you will improve your daly driving sensation, you just need to ask to all users who bought the Grimmspeed strut. It's all about details, each details are important
o= FR-S =o |
#84 | |
Look the video I posted from Cusco. Look until the end
o= FR-S =o |
| Lowering Springs|Alignment Kits|Strut bar|Sway Bars|Strut Mount +More | SOURCE,LLC | Brakes, Suspension, Chassis | 445 | 05-11-2015 05:41 PM |
| wtb trd strut bar | hunter3232792 | Want-To-Buy Requests | 10 | 10-17-2013 02:31 AM |
| FS: Rear strut Bar | 86design | Brakes, Suspension, Chassis | 9 | 07-27-2013 01:51 AM |
| Strut Bars? Which is best? | DriftEightSix | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 7 | 04-02-2013 08:48 PM |
| FR-S strut. | JohnJohn86 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 34 | 12-30-2012 09:01 PM |
