Old 10-20-2013, 03:15 PM   #1
husker741
What do you think of your strut bar?
Which kind do you have and was it worth it? Does it really stiffen up the front too much? I already have RCE Yellows and I'll track it rarely, but I'm interested in spending a little for a strut bar if it helps. I just don't want the ride greatly effected because I heard it does make it stiffer.
husker741 is offline   Reply With Quote
The Following User Says Thank You to husker741 For This Useful Post:
unsurety (04-19-2014)
Old 10-20-2013, 03:53 PM   #2
boredom.is.me
Custom User Title
boredom.is.me's Avatar
Drives: Asphalt FR-S MT
I have the GrimmSpeed strut tower bar and it does indeed provide a little extra predictability. It does induce a little initial understeer, but it helps the overall cornering experience tremendously.
The Following User Says Thank You to boredom.is.me For This Useful Post:
husker741 (10-20-2013)
Old 10-20-2013, 04:19 PM   #3
husker741
How much did it stiffen the ride?
Old 10-20-2013, 04:49 PM   #4
boredom.is.me
Custom User Title
I'm not sure how much, but it is easier to dog leg. So ya, it's stiffer. As far as daily driving and bumps go. I can't really tell.
Old 10-20-2013, 05:30 PM   #5
autoCAR
Drives: 5/2013 scion frs
I got a Cusco carbon strut bar n I feel a bit of a difference too. Deffinetly feels more responsive in turn in, and as for comfort, no change.
edit: id recommend it if you got an extra 200 bucks n want a more crisp ride
just don't expect night and day changes
autoCAR is offline   Reply With Quote
Old 10-20-2013, 05:42 PM   #6
fatoni
can someone please explain to me how a strut bar generates more understeer?
The Following User Says Thank You to fatoni For This Useful Post:
Captain Snooze (11-01-2013)
Old 10-20-2013, 06:17 PM   #7
boredom.is.me
Custom User Title
It doesn't allow the chassis to comply (read flex) to the road as much. Te harder you push the car into a corner, te harder the STB is working to keep the outer wheel down. The result is a little less initial traction.
I can't really explain it too well. Also correct me if I'm wrong.
Frank5364 (04-20-2014)
Old 10-20-2013, 07:25 PM   #8
DriftEightSix
Pegasus White
DriftEightSix's Avatar
Drives: 86
but that would mean it would effect the initial turn in... Which i found was improved with my strut bar (Grimmspeed)
Driving: Pegasus White Manual GTS 86.
DriftEightSix is offline   Reply With Quote
Old 10-20-2013, 08:07 PM   #9
fatoni
the chassis not flexing is exactly what you want to improve grip. in my head, thats just allowing the suspension to better do its job.
adding understeer can happen either by the car losing grip up front (which will slow a car down), or gaining grip in the rear (which i cant see a strut tower bar doing).
Old 10-20-2013, 08:13 PM   #10
frs10
Drives: tezla
so what is the point of the factory installed bars?
frs10 is offline   Reply With Quote
Old 10-20-2013, 09:26 PM   #11
u/Josh
Drives: GBS Limited 6MT
I'm just going off intuition here, but it seems to me that adding a front strut brace would effect the car in a similar way as running a slightly stiffer anti-roll bar.
u/Josh is offline   Reply With Quote
Old 10-20-2013, 09:30 PM   #12
fatoni
thats not at all what a strut tower bar does.
Old 10-20-2013, 09:43 PM   #13
u/Josh
A strut tower bar effectively stiffens the front suspension when one wheel is in bump and not the other, by not allowing the chassis to flex (as much). A sway bar also stiffens the suspension when one wheel is in bump and not the other.
Now I am not sure exactly how the strut towers usually deflect, so I'm not sure how much effect the strut brace has when both wheels are in bump at the same time. Anyway, in very general terms, a strut brace stiffens the front suspension.
Old 10-20-2013, 10:55 PM   #14
fatoni
the amount of effective stiffness gained in the suspension is next to immeasurable. the reduction in deflection would be measured by microns while suspension movements happen in inches. there is a far larger variance in springs coming off of any manufacturing line. you would notice that every single frs you ever drive had different levels of understeer before you notice any gain in understeer from a reduction in chassis deflection via strut tower bar. any stiffness outside of the suspension is going to allow the suspension to work more effectively.
Lowering Springs|Alignment Kits|Strut bar|Sway Bars|Strut Mount +More SOURCE,LLC Brakes, Suspension, Chassis 445 05-11-2015 05:41 PM
wtb trd strut bar hunter3232792 Want-To-Buy Requests 10 10-17-2013 02:31 AM
FS: Rear strut Bar 86design Brakes, Suspension, Chassis 9 07-27-2013 01:51 AM
Strut Bars? Which is best? DriftEightSix Suspension | Chassis | Brakes -- Sponsored by 949 Racing 7 04-02-2013 08:48 PM
FR-S strut. JohnJohn86 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 34 12-30-2012 09:01 PM
