CANADA Canada
Old 11-11-2013, 08:45 AM   #15
Demandred7
Demandred7's Avatar
Drives: 2018 Camry XSE V6
Originally Posted by AdrianG View Post
Not quite what I meant, damn, how can I un-see that.
Demandred7 is offline   Reply With Quote
Old 11-11-2013, 08:50 AM   #16
whaap
whaap's Avatar
Drives: '13 FR-S firestorm, 6 mt - '11 CR-V
Adding weights isn't going to do anything if you're driving in icy conditions. How much more a tractor-trailer rig weighs compared to your car doesn't do a thing for him if he starts sliding on ice. Learning defensive driving goes a lot further than relying on something in your trunk that only makes you 'think' you're safer.
whaap is offline   Reply With Quote
Old 11-11-2013, 08:55 AM   #17
Rayme
The Answer
Rayme's Avatar
Drives: Mazda 2
I would think added weight in the back make the car harder to correct in the event of the rear sliding around right? That being said don't bother unless you have problem with initial traction, good winter tires and the LSD will work magic, this is a light car. Drove it all last winter and couldn't ask for a better winter vehicle, unless it was AWD... lol
Rayme is offline   Reply With Quote
Old 11-11-2013, 09:01 AM   #18
Suberman
Drives: Subaru BRZ Sport Tech Satin White
People worry about traction to get going on ice. It isn't logical but there you are. Adding weight over the drive wheels does give you better traction to get going. However, your point is absolutely correct. Once you do get going the extra weight is a big disadvantage.
Steering is adversely affected by weight over the rear wheels. Braking nay or may not be improved. Generally speaking adding weight over the rear axle does shorten braking distances by getting more braking grip at the rear but not by enough to make the drawbacks acceptable.
However, going around corners is more difficult with the weight distribution moved towards the rear of the car. Rear and mid engined cars can be a real handful when cornering in winter conditions.
Suberman is offline   Reply With Quote
Old 11-11-2013, 09:05 AM   #19
Suberman
Awd has its tricky points too. Fwd is safest for winter and can be fastest in the long run.
Adding weight to the rear of the car will make cornering more difficult.
With proper tires you don't need extra grip from the rear of the car to accelerate. Braking and steering are much more important than getting going.
Just BTW, if you skid in an awd car you really need to know what you're doing to avoid a crash. If you have an awd Subaru I recommend you try this in a safe place. Subaru awd cars are extremely difficult to skid but once you do it can get pretty hairy pretty quickly.
The BRZ by comparison skids at lower speeds but is so easy to correct a kid could do it.
Old 11-11-2013, 09:06 AM   #20
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
i didn't put any weights in mine
but was thinking of trying this winter
as for braking/truning yada yada... i'll say only one thing, the RWD ice-racers around here fill the various cavities in the rear of their cars with CEMENT.
yes the rear end will tend to swing out more, but that's where your throttle comes in, you hammer down and gain traction at a vector of where you're pointing... so RWD cars don' thave problems with traction... so long as you don't actually STOP, which is a rather important consideration for street driving.
Old 11-11-2013, 09:33 AM   #21
wparsons
wparsons's Avatar
If you're going to do anything, used kitty litter. If you get stuck you can spread it around to give you grip to get un-stuck.
flickr
Old 11-11-2013, 11:44 AM   #22
KingGeo
Drives: FRS
you dont need it.
in fact i would say it makes things worse in the corners.
the car has a near 50/50 balance and likes to kick the back out normally, the added weight just makes the back end easier/quicker to kick out.
so if you are looking to drift every corner, sure add weight.
KingGeo is offline   Reply With Quote
The Following User Says Thank You to KingGeo For This Useful Post:
5th 86 (11-27-2013)
Old 11-11-2013, 12:16 PM   #23
Starscream15
Starscream15's Avatar
Drives: 2013 Subaru BRZ - DGM
Starscream15 is offline   Reply With Quote
Old 11-11-2013, 12:46 PM   #24
congee
congee's Avatar
Drives: SSM BRZ
Originally Posted by Starscream15 View Post
Is that JDM? Group buy anyone?
congee is offline   Reply With Quote
Old 11-11-2013, 01:02 PM   #25
mrdanyo
Drives: 2014 BRZ Limited (World Rally Blue)
That's not enough weight.
mrdanyo is offline   Reply With Quote
Old 11-11-2013, 01:15 PM   #26
Starscream15
This version might weigh a little more but I hear both of these JDM models work well together.....very well in fact
Old 11-11-2013, 01:51 PM   #27
drei
drei's Avatar
Drives: 2013 Scion FR-S Asphalt
Don't bother, this car handles well in the snow. Keep the traction control off and be careful around deep spots and you'll be fine. Adding weight to the back just makes it more work to recover from a slide IMO.
- AdrianG
fixed.
drei is offline   Reply With Quote
Old 11-11-2013, 04:57 PM   #28
Muaddib
Mentat
Muaddib's Avatar
Drives: 2013 Scion FRS 6MT
Crates of ammo.
Muaddib is offline   Reply With Quote
Wheel Balancing Weights Black Tire Tracking / Autocross / HPDE / Drifting 4 06-13-2013 05:51 PM
Corner weights - Toyota 86 diss7 Scion FR-S / Toyota 86 GT86 General Forum 15 04-07-2013 07:30 PM
Wheel weights BAE Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 06-09-2012 09:16 AM
Excessive wheel weights? muffinman Other Vehicles & General Automotive Discussions 6 05-25-2012 09:59 AM
does anyone know why GT86 weights so much? wu_dot_com Scion FR-S / Toyota 86 GT86 General Forum 85 03-19-2012 04:24 PM
