Old 10-23-2013, 08:40 AM   #57
rx3
I think wide 15" wheels don't fit because of the tie-rod ball joint.
http://www.ft86club.com/forums/showp...1&postcount=19
http://www.ft86club.com/forums/showt...836#post495836
(I thought about running 16" wheels but the 17" wheel rim tire combination actually produced the smallest diameter in a reasonable tire size).
rx3 is offline   Reply With Quote
Old 10-23-2013, 11:31 AM   #58
celica73
I guess I should pay more attention. Thanks for the heads up.
Old 11-04-2013, 01:50 PM   #59
jprice130
AutoX Nut
Drives: 2020 Toyota Supra
Originally Posted by cjsporl View Post
I'm confused were 225's the best for autox and street racing?
What's "best" has too many variables to provide a definitive answer; even for just autocross. The ideal tire width depends on the class you're shooting for and the rules of that class. Certain classes have wheel width limitations which in-turn affect what would be the ideal tire width. This is further complicated by the performance category and brand of tire you use.
If you have more specifics about what your racing plans/goals are and the classes you're looking to run, it might be easier for us to give you advice along those lines.
jprice130 is offline   Reply With Quote
Old 11-10-2013, 10:49 AM   #60
smbstyle
smbstyle's Avatar
Drives: 2013 SWP BRZ
Running 215 Michelin PSS (stock suspension and engine) and I feel like it's not enough tire. I'll probably try running a 225 or 235 next.
Can anyone chime in running a 225 and 235 tire on the OEM wheels? Does the 235 tire fit at all?
smbstyle is offline   Reply With Quote
Old 11-10-2013, 03:14 PM   #61
jprice130
AutoX Nut
When you say it's not enough tire, is this for HPDE, AutoX, or just street driving? Also, in your consideration for a wider tire, are you wishing to stick with Michelin PSS? A 225 or 235 tire will fit on a 7" wheel fine, but whether it provides better performance will depend on the brand/model and driving application.
Old 11-10-2013, 03:57 PM   #62
smbstyle
smbstyle's Avatar
80% HPDE, 20% street. pretty much only street miles are to/from events. After driving on PSSs, RS3s, Star Specs, RA1s, R888s, AD08s, NT05s, NT01s as far as "streetable" track tires, I have actually come to like the PSS the best overall for the various track conditions we get down here in FL. I do about 10-14 HPDE events a year with the BRZ, and SCCA regional club races with a Miata.
Old 11-10-2013, 04:17 PM   #63
jprice130
AutoX Nut
PSS is certainly a great tire. I run 215/45/17 for daily driving and rainy autocrosses and love them (I like Rivals and RS3s for dry). The sidewalls of the PSS are stiff enough to handle using a 225 on stock sized wheels, but I wouldn't go wider than that.
The Following User Says Thank You to jprice130 For This Useful Post:
smbstyle (11-10-2013)
Old 11-11-2013, 11:10 AM   #64
smbstyle
smbstyle's Avatar
Just picked up a set of 17x9 et38 for a killer deal ($350 shipped brand new from discount tire direct) and will be testing out a 245 PSS in the near future with it, and will report back.
Old 11-12-2013, 06:11 PM   #65
solort
Drives: Series 10 FRS
For SCCA Street class, would you run 16x7 or 17x7 light wheels, and with what width tire?
solort is offline   Reply With Quote
Old 11-12-2013, 07:31 PM   #66
jprice130
AutoX Nut
The easy answer is just to run 17x7 wheels and 225/45/17 tires. Pretty much all the "extreme" and "max" performance tires come in this size, so you will have plenty of options to choose from.
Alternatively, you could run 16x7 wheels and 225/50/16 tires. Again, most tires in the "extreme" and "max" performance categories come in this size as well. Generally speaking 16" wheels and tires are cheaper, so that is a plus, but a 50 sidewall tire might feel a little sloppy and not transition as quickly as a 45 sidewall tire.
There are a few other sizes you could consider depending on the tire brand/model you choose (like 225/45/16 or 235/40/17), but a 225/45/17 or 225/50/16 will give you the most options.
Old 11-17-2013, 11:01 AM   #67
Alfalasy
2013 BRZ
Alfalasy's Avatar
My wheel spec is 18x9.5 +40mm offset for all wheels. Rays Gramlights 57Xtreme. Tires 255/35-18 Pirelli P Zero.
I have done some research but didn't find a definitive answer for the best setup for track days and need some advice to choose the most suitable width for front and rear. I'm also planning to get semi-slick tires.
If I go for narrower front at 235 is it going to be more nimble and reduce roll resistance? For the rear I'm planing to keep the 255 width for more grip.
Need advice on this please.
Alfalasy is offline   Reply With Quote
Old 11-21-2013, 02:23 PM   #68
guarapo
guarapo's Avatar
Drives: 2013 Whiteout Scion FR-S
I'm trying to on a proper tire size for track use on a Vortech supercharged frs. I see many people have gone 17x9 with 245 width, but then again I see some people suggesting a narrower tire/rims for better times.
In short, i currently only have budget for a new set of rims and tires for track use but would like to get the proper size for a FI application, anyone out there that can offer some insight? Thanks!
Vortech Supercharger with Visconti Tune, Borla UEL Header, Perrin Catted Frontpipe, Perrin Overpipe, Perrin resonated Catback
guarapo is offline   Reply With Quote
Old 02-16-2014, 12:56 PM   #69
rx3
Most people are running Toyo R888 in the street tire class around here (slalom (autocross) and hillclimbs).
I was curious about potential competitors, as I need new tires in spring.
In this review the Toyo R888 was beaten by all competitors: http://trackparts.ch/images/pdf/semislicktest%2012.pdf
(It's also interesting to note that the R888 is a pretty heavy tire in comparison)
Especially in rainy conditions the Pirelli P Zero Trofeo is faster than any other semi slick tire, which was also confirmed by the last review.
The Pirell P Zero Trofeo is available in 205/45 R17 which could be one of the quickest 17" semi slick option in a wet slalom event (autocross).
(Neither the Michelin Pilot Sport Cup+ nor the Continental Force Contact are available in any 17" dimension.)
(However, the Toyo R888 has never been a good competitor in the rain: http://trackparts.ch/images/pdf/semislicktest%2005.pdf)
In dry conditions, based on the following review and based on some online forums the Dunlop Direzza 03G should be faster than the Toyo R888, however it is only available in 235/45 R17 as opposed 235/40 R17. I'm not sure, whether the tire could make up for this gearing disadvantage.
http://trackparts.ch/mediafiles//Pdf...ktest%2013.pdf
Also, there doesn't seem to be any information about the Dunlop Direzza 03G on US forums (it is probably not being sold in the US).
(All these reviews are unfortunately in German, but if one has a specific question I can translate.)
The Following User Says Thank You to rx3 For This Useful Post:
Alfalasy (02-17-2014)
Old 05-10-2014, 12:18 PM   #70
rx3
I tried the R888 in the 205/40 R17 dimension.
In the last wet event I still dealt with hydroplaning but I was significantly faster than the competitors on wider tires and was even reaching maximum lateral accelerations of 1.1 g (and lost only half as much time to the guys running on non-road-legal racing rain tires).
However, in a dry event these narrow tires became greasy relatively quickly. I lost 3 seconds compared to last year on 235/40 R17 on a 3 minute long course.
Will this fit? (width, offset and tire size Qs) DarrenDriven Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4468 04-15-2024 12:31 AM
Determining the proper width size of the tire CyberFormula Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 49 05-23-2014 09:11 AM
Track width -max- Suspension | Chassis | Brakes -- Sponsored by 949 Racing 16 08-21-2012 06:37 PM
Correct tire width for each wheel width DarrenDriven Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 10 08-16-2012 02:03 PM
Tire Width vs Wheel Width Synack Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 40 08-12-2012 11:21 PM
