Old 11-08-2013, 02:14 AM   #29
kALMIGHTY
Drives: TRD Ultramarine '13
Originally Posted by SoCal909 View Post
Is it not normal to have wind noise going like 65mph on the freeway? I have quite a bit of wind noise compared to our 2012 e350 but I was just assuming that was normal.
Wind noise is normal, but this is something else. Plus the noise showed up suddenly after owning the car for 3 months. The noise becomes clearly audible at 60 km/h (37 mph), so I don't even have to go that fast.
Old 11-08-2013, 02:15 AM   #30
kALMIGHTY
Originally Posted by gily25 View Post
Wonder if something got into the exhaust...was it parked outside on Halloween? Do you have a crazy ex...
Nope...car stays in the garage at all times when I'm home, which is exactly where I was on Halloween haha.
Old 11-08-2013, 02:55 AM   #31
SoCal909
SoCal909's Avatar
Drives: 2014 WRB BRZ 6MT
I see. I can remember one time I got my windows tinted that I heard some wind noise, if I recall correctly the seal on the bottom of the window was not properly put back. Maybe check that?
SoCal909 is offline   Reply With Quote
Old 11-08-2013, 10:16 AM   #32
.......... Do you have a crazy ex...
Aren't they all crazy .....
I don't believe wind noise in an FR-S is "normal" ..... at least I don't hear any ..... of course, according to mrs humfrz, I don't hear a lot of things ....
gily25 (11-08-2013), kALMIGHTY (11-08-2013)
Old 11-08-2013, 11:19 AM   #33
kALMIGHTY
I know people have had issues with their windows in this car, but mine seem to be fine. And I would think that if it was the window seal, the noise would be there constantly when I'm moving, but noise is only there when I'm moving AND I'm in gear. No noise if I push the clutch in while moving and even rev. The noise is only there when I'm in gear. :/
Old 11-08-2013, 03:06 PM   #34
Tim_Asphalt_FRS
Is it fast? No.
Tim_Asphalt_FRS's Avatar
Drives: 2013 Scion FR-S Manual-Asphalt
This car is very loud compared to a Benz. Even after dynamat & acoustic insulation I don't think mine is that quiet.
Sent from my iPhone
2013 (Rebadged) Toyota GT-86 {Perrin intake tube, aFe dry air filter, custom 2.5" exhaust, PLM overpipe, Kartboy crank pulley, Hotchkis springs, custom Flossy grip tape shorty, TRD shifter, Berk HFC, Whiteline Sway-bars}
[Wanted: Delicious Stg 2 tune, Bilstein struts]
Tim_Asphalt_FRS is offline   Reply With Quote
Old 11-08-2013, 03:40 PM   #35
sprintertrueno86
sprintertrueno86's Avatar
Drives: 2018 BMW M2
Sent from my iPhone
This car is very loud even compared to my Legacy.
sprintertrueno86 is offline   Reply With Quote
Old 11-08-2013, 10:41 PM   #36
Yellow13
Yellow13's Avatar
Drives: 2013 6MT Asphalt FR-S
Just a weird thought. Have you removed, or messed with, the factory sound tube? It goes through the firewall on the passenger side and if you do not plug, or cap, the hole it will be wide open. Possibly some wind is getting blown past the hole and causing the whistle? Maybe the grommet is cracked/broken?
Yellow13 is offline   Reply With Quote
Old 11-08-2013, 11:15 PM   #37
kALMIGHTY
Unlikely. I had the TRD intake and TRD exhaust installed prior to delivery so the sound tube was gone before I even got the car. And this noise is quite clearly coming from the back of the car.
Old 11-08-2013, 11:44 PM   #38
Yellow13
Yellow13's Avatar
Ah, my fault. Did not see it said REAR quarter panel. Bit out of it
Old 11-12-2013, 10:41 PM   #39
kALMIGHTY
Sooooo....took it to the dealership for the THIRD time and this time I left the car with them because there were other issues they were going to fix, like the rear deck popping noise, and the little rattles here and there, and do my first oil and filter change (all FREE )
I was supposed to get the car back at the end of the day but they couldn't figure out the source of the noise so they're going to keep it with them. Hopefully they figure this out soon because I miss my baby already.
Old 11-13-2013, 09:38 PM   #40
Lydin
Drives: Asphalt FRS
I believe what your hearing is induction noise, sounds like a high pitch whistle or air flowing through a tube sound whenever you gas it. It's normal they say.
Lydin is offline   Reply With Quote
Old 11-14-2013, 12:48 AM   #41
kALMIGHTY
Induction noise coming from the back of the car?
Also, the noise wasn't there for more than 3 months of me owning the car.
Old 11-21-2013, 06:36 PM   #42
kchkwan
Drives: Subaru BRZ
Did you get it fixed? I got my winters on yesterday and I'm experiencing the same problem o.o....
kchkwan is offline   Reply With Quote
Strange Noise from rear of car while OFF mike2100 Issues | Warranty | Recalls / TSB 23 12-17-2014 08:14 PM
Strange noise at 2500 RPM midnight23 Engine, Exhaust, Transmission 7 06-07-2013 09:01 AM
Strange Tapping noise from under car after use rhood168 Issues | Warranty | Recalls / TSB 10 02-12-2013 02:16 AM
Strange noise at 2k RPMs Cajun Issues | Warranty | Recalls / TSB 3 11-29-2012 10:30 PM
Strange noise Random_Art Other Vehicles & General Automotive Discussions 15 06-03-2011 03:31 PM
