Old 11-01-2013, 10:36 PM   #2507
Sojhinn
Lightning McQueen Driver
Sojhinn's Avatar
Drives: Limited Red 6MT BRZ
Originally Posted by fenton View Post
Looking forward to the results. I think 15 to 20 may not be out of the question though with the proper aggressive tune.
Are you tuning on dynojet or something else?
Sent from my HTC One using Tapatalk
We are going to hit up a dyno jet that way we get more consistent results with what you guys have.
Installed Mods:
Old 11-02-2013, 04:40 AM   #2508
Fast_Freddy
Drives: Passat
Originally Posted by Gary in NJ View Post
If an alternator is turning (and the field is present) its making power, all of the time. It's the regulator (in our car the ECU) that controls the flow of power through a variable field. The field is almost never open. You will not wear out an alternator any faster whether the charging *system* is outputting 25% of the time or 70% of the time.
It's a use it or loose it system. In that regard it's free.
Also keep in mind that the 24V system for the ESC only receives a nominal trickle charge when idle. It only receives a full charge for a few seconds following engagement. As a result, the system is less taxing on the alternator then a rear window defogger which pulls current for 15 minutes.
I disagree. Our charging system is not a "use it or loose it" system and the energy needed to recharge the ESC batteries is not free. As I said before, cheap but not free. However little, the engine still sees increased load from the alternator due to the necessity of recharging the ESC batteries.
@Fast_Freddy
Its certainly not free but it is pretty close. The charge drawn from the alternator is 25a for single recharge or 50a for the double recharge. Underload this does not change as the dump batteries are isolated from the starter battery via the controller.
I believe I am essential running a tractor battery right now. The CCA is just a little lower than the stock battery.
We are going to try the blow through MAF today
Thank you. Cheap but not free. Nothing is free in this world.
Do you know what group size battery you're running? If I did want to buy a Phantom ESC I'd rather not have to source my own battery tray, hold down hardware and figure out what size starting battery will fit.
Good luck with the blow-thru MAF.
Fast_Freddy is offline   Reply With Quote
Old 11-02-2013, 08:36 AM   #2509
Gary in NJ
Gary in NJ's Avatar
Drives: WR Blue BRZ, 240Z
Obviously you did not read my post in #2499 above:
I don't like my answer in post #2492. Yes, during the vast majority of time the ESC batteries receive a trickle charge from the alternator with an insignificant load, but during the 5 to 10 second recharge period following engagement the alternator is putting our significant current.
Rob has battery trays or can recommend alternative trays if you choose to use a larger battery.
Phantom ESC, ECUtek Tune, Nameless Front Pipe & Axle Back, Enkei RS+M 17x8 et35, OEM+Ref
Gary in NJ is offline   Reply With Quote
Old 11-04-2013, 11:13 AM   #2510
Robftss
Drives: VW
Whatever the parasitic losses associated with this ESC, I doubt that they are much more than that of a small turbocharger.
It is the overall energy that is relevant.
The conversion from alt-charger-dump battery-controller-motor is less efficient than a turbine/backpressure or belt-gearbox/drive losses. However, for the same wheel output boost/flow required is ~ 1/2, therefore 1/2 the energy, than that of conventional FI due to minimal parasitic losses. It is when the parasitic energy is extracted that determines the difference in efficiency in a DD application.
Conventional FI...@ 11-12 AFR. Phantom ESC... @ 14.7 AFR
Rob.
Robftss is offline   Reply With Quote
The Following User Says Thank You to Robftss For This Useful Post:
DAEMANO (11-04-2013)
Old 11-04-2013, 12:05 PM   #2511
CajunFRS
Drives: Challenger R/T, CRX SI,
Rob.
Is 14.7 a little high? (Bad)
CajunFRS is offline   Reply With Quote
Old 11-04-2013, 12:49 PM   #2512
Robftss
Drives: VW
Bulk charge, aka parasitic, occurs during stoichiometric combustion.
Old 11-05-2013, 01:26 PM   #2513
fenton
Update:
Blow through MAF abandoned for now. We did get it working but without a tuner to rescale the MAF we were not confident in continued testing.
Lots of good information coming in from the testers. Rob is very happy with how the kits have been preforming and how little problems there has been across the 8 individuals running the kit.
Its getting pretty nippy outside in the mornings and im happy to report that cold weather performance seems VERY good.
Car has started no problem in below freezing weather, starting sounds just as you would expect it stock.
Now the performance in below freezing..... its damn nice stuffing below freezing air into the engine. Top end is very noticeably increased and i dont notice any drop off in boost even after 30 minutes of highway driving in -10C.
All i can say is my winter tires are BEGGING for mercy, the torque in even third is enough for them to start clawing at the pavement and fight for traction.
fenton is offline   Reply With Quote
The Following User Says Thank You to fenton For This Useful Post:
DAEMANO (11-06-2013)
Old 11-05-2013, 08:17 PM   #2514
SloS14
SloS14's Avatar
Drives: 2013 FR-S whiteout
We need videos of freezing temp hoonage.
The Following User Says Thank You to SloS14 For This Useful Post:
fenton (11-05-2013)
Old 11-05-2013, 08:57 PM   #2515
fenton
Roger! I'll work on something good
SloS14 (11-06-2013)
Old 11-05-2013, 09:02 PM   #2516
Sojhinn
Sojhinn's Avatar
Update:
Sorry I haven't been talking much. Been keeping it low key since I don't have the tune. But it looks like I'm on for the 25th for the tune for both e85 and 91 octane. I will also be doing a long distance run that same day. So I'm interested in seeing how things perform then. Still waiting on parts for our schools dyno.
Installed Mods:
The Following 3 Users Say Thank You to Sojhinn For This Useful Post:
Bu-Tang (11-05-2013), DAEMANO (11-06-2013), fenton (11-05-2013)
Old 11-06-2013, 08:20 PM   #2517
silent runner
Drives: 93'Camry, 82'Corolla, 76' Celica
Rob.
I understand this. While the alternate battery system takes the big hit for power draw, the cars alternater only is loaded a little more. After a run, and maybe even while decelerating, the car can continue to supply re-charge, with little or no paracitic loss. Besides, how much power could the FRS's alternater actually draw back? I'll bet its not more than 100amp system. That means, the most is can be asked to supply is about: P=VI, or about 12v*100amps= 1200W, or 1200*1/746w/hp= 1.61hp! However, it won't even do this, because it runs off of an isolated battery system, while in operation.
Under re-charge conditions, it not likely that the supplimentary battery system will actually tag the atlternater for its full 100 amp capability, all the way through a cycle, but there you have it. The draw of the exta battery system will never really take more than 1.5 hp out of your ride.
Now I'm coming off of a 4cyl Mazda 626 Turbo, that I had boosted at 16psi. This system had to run, all the time to make the intake system operate properly. It had to draw energy to spin-up the compressor, (all the time) and push the intake air through a long tortuous route, from intake, through a bunch of pipes, to an intercooler, then finally to the engine. I never measured it, but I bet it made 6 changes of 180 degrees along the way and had to be pushed through at least 6ft of pipes and the intercooler in the process. When you called on this little monster to make power, it did it in style, but it had many paracitic losses in regular operation. It loved the cold air as well. At -20 celcius, it felt honestly, like it might actually rip it's front wheels off.
silent runner is offline   Reply With Quote
Old 11-06-2013, 11:03 PM   #2518
rusty959
Drives: DGM BRZ limited
Its a 130 amp alt. And if you are really drawing from it the most you will notice is decreased gas mileage. I notice a couple mpg drop when I'm running my stereo hard on the highway.
So what you said is reasonably correct, but the alt also puts out about 13.8v not 12v.
rusty959 is offline   Reply With Quote
Old 11-07-2013, 12:24 AM   #2519
CajunFRS
Stero decreased your gas mileage?
Old 11-07-2013, 09:39 AM   #2520
rusty959
Ever had a stereo that when the bass hit in neutral your rpm drops due to the extra load on the alt? Mine drops a few hundred rpm.
If you haven't experienced that, you haven't experienced my fabled mpg drop.
Circuit Motorsports - Vortech Supercharger FR-S Build + Full Perrin Exhaust & Extras Circuit Motorsports Member's Car Journals 4 03-21-2013 04:45 PM
Subaru BRZ : Full Throttle, powerslide, hard revving & ride ESBjiujitsu BRZ Photos, Videos, Wallpapers, Gallery Forum 20 05-30-2012 06:43 PM
86 Full Throttle Video + another. Aus86 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 2 04-02-2012 07:07 AM
