Old 10-22-2013, 01:48 AM   #15
mswhong
Drives: FT86
Originally Posted by Pitman View Post
Mine is mounted in my side vent
Is that custom mounting?
mswhong is offline   Reply With Quote
Old 10-22-2013, 06:25 AM   #16
Pitman
Living the dream
Pitman's Avatar
Drives: Fensport AVO Turbo GT86
No,
I bought it here:
http://www.fensport.co.uk/Parts/Mode...tegory_16/4660
All I had to do was make an adapter ring, as the mount is designed for 60mm dia gauges, and the AEM gauge is 52.5mm dia.
Pitman is offline   Reply With Quote
The Following User Says Thank You to Pitman For This Useful Post:
ftc~brz (01-22-2014)
Old 10-22-2013, 08:45 AM   #17
xjohnx
Grip>Slip
xjohnx's Avatar
Originally Posted by Admired View Post
oh thats nice, what pod is that? How much?
It's made by Block8head - i bought it secondhand from @civicdrivr though, not sure where he got it.
Old 10-22-2013, 09:51 AM   #18
bgibbsunc
bgibbsunc's Avatar
Drives: Firestorm Scion FR-S
Originally Posted by xjohnx View Post
I went with a pod that replaces my defroster vent on the drivers side.
looks like this:
It can read both boost and AF a the same time. Either PSI on the OLED in the middle and AF on the outer-rings LEDs, or vice versa.
I have this gauge but a dual instead of single. Also made by blockhead
FA20 club 60 trim + flex fuel
467 whp 356 ft lbs @ 19 lbs
Owner of Sidewinders Auto LLC.
San Antonio TX
bgibbsunc is offline   Reply With Quote
Old 10-22-2013, 09:52 AM   #19
bgibbsunc
bgibbsunc's Avatar
Not sure on his normal price. I worked out a deal because I have a shop.
San Antonio TX
Old 10-22-2013, 10:23 AM   #20
Ross
Drives: 85 corolla gts
We have just been modifying the factory gauge bezel.
Ross is offline   Reply With Quote
The Following User Says Thank You to Ross For This Useful Post:
gdrider77 (10-22-2013)
Old 10-22-2013, 11:31 AM   #21
gdrider77
gdrider77's Avatar
Drives: Subaru BRZ Limited
Yeah that's basically what I did. But just a heads up, you don't even have to do any bondo work on it. There is room to simply hole saw into that side and put in a gauge. Very simple.
I might redo mine though over the winter. The advantage of the bondo that I see is that you can angle it up and out a bit more.
But really, just drill a hole and put a gauge in. Pretty easy.
I'm running the aem fail safe as well.
gdrider77 is offline   Reply With Quote
The Following User Says Thank You to gdrider77 For This Useful Post:
Sportsguy83 (10-22-2013)
Old 10-22-2013, 12:01 PM   #22
Ross
We use a piece of angle cut wood to get the angle a bit better. Then epoxy to attach the wood, and bondo to make sure it all flows well together. I felt with just putting the gauge strait in it faced a bit to far to the left, but we will give it a second look next time we have one apart.
The Following 2 Users Say Thank You to Ross For This Useful Post:
gdrider77 (10-22-2013), Sportsguy83 (10-22-2013)
Old 10-22-2013, 12:43 PM   #23
jamesm
i put my (60mm) boost gauge in the vent (no adapter thing, no need really it fits without it). for everything else i use my iphone in a holder, it can be whatever 3 gauges i want. right now it's set up for coolant temp, ltft and lc1 o2. i hate gauges in general, especially in this car there is nowhere good to put them. unless you do the molding like the guy above, but i dont' have skills like that
Old 11-03-2013, 10:44 PM   #24
Pablitomarrero
Pablitomarrero's Avatar
Drives: FR-S 10 series
looks like this:
OMG finally... I need this
Who is blockhead...cant find him...how do i get this!!!??
Pablitomarrero is offline   Reply With Quote
Old 11-04-2013, 05:53 AM   #25
pixel67
pixel67's Avatar
Drives: 13 Asphalt FRS AT
http://www.mazdas247.com/forum/showt...ed6&highlight=
Sent from my Nexus 7 using Tapatalk
pixel67 is offline   Reply With Quote
The Following User Says Thank You to pixel67 For This Useful Post:
Pablitomarrero (11-04-2013)
Old 11-04-2013, 07:41 AM   #26
Pablitomarrero
Thank you!!! Do yo know if he is still reachable at xxredline9xx@aol.com? That thread was 4 years ago!
Old 11-04-2013, 07:47 AM   #27
xjohnx
Grip>Slip
xjohnx's Avatar
It was updated 3 weeks ago. I think you're safe. If not, you can always try Facebook.
https://www.facebook.com/pages/Block...86061001612122
Old 11-04-2013, 07:48 AM   #28
Pablitomarrero
Than you guys!
AEM Wideband Failsafe Gauge Pitman Forced Induction 51 08-14-2016 11:06 AM
LC-1 wideband 02 sensor MattF Engine, Exhaust, Bolt-Ons 4 11-05-2013 09:52 PM
Innovate LC1 wideband choi0706 Engine, Exhaust, Bolt-Ons 0 08-27-2013 11:29 PM
Wideband LC-1 wiring. MattF Forced Induction 9 07-09-2013 09:33 AM
Innovate Wideband Air/Fuel Ratio LC-1 Wideband Kit **Special Price** Titanmotorsports Audio/Visual, Electronics, Infotainment, NAV 2 09-14-2012 12:42 PM
