Old 09-24-2013, 05:02 PM   #1
redsuns03
DIY: Installing LED turn signal housing w/ DRLs
Hello everyone! Here's a quick and easy DIY on how to install your LED Turn signal housing with DRL bar.
Special thanks to: @Vicious LED for helping me out!
Product info: Vicious LED Turn Signal
Tools needed:
10mm Socket
Socket Wrench
Philips Screwdriver
Flat Head Screwdriver
Tap Wire Splice (2x)
Electrical tape
Wire cutter
Oscillator cutter (Something to cut the plastic tab)
Step 1:
Remove the tabs of the plastic cover using a flat head gently until they pop out.
Step 2:
Turn your wheel inward to help ease the access of the 4 pop in locks of the plastic panel and remove the locks using a philips screwdriver.
step 3:
Use the 10mm socket to remove the 2 nuts holding the turn signal housing on to the bumper.
Step 4:
Cut the plastic tab that's pointing on the 2 O'clock position shown in the pic below. This will enable you to plug the harness to the new LED housing.
Step 5:
Use the wire tap splice to connect the YELLOW wire from the HOUSING to the GREEN wire of the HARNESS.
Step 6:
Use the wire tap splice to connect the GREEN wire from the HOUSING to the BLACK wire of the HARNESS.
Note: Covered the RED and BLACK wires of the housing because if you have an LED relay, you wouldn't need it.
Refer to the pic below
Step 7:
Make sure everything is connected properly and TEST to see if they are running. If DRLs are running but no turn signal, reverse the connection of the housing plug and the harness as you may have plugged it in wrong.
Step 8 (optional):
Wrap the splice connectors and the wire with electrical tape to ensure nothing goes wrong.
Step 9:
Put everything back and do the same thing on the other side.
Enjoy your new LED housing with DRLs.
End result:
[ame="http://www.youtube.com/watch?v=s39AdpG4J1Q"]Turn Signal Housing for FRS - YouTube[/ame]
The Following 2 Users Say Thank You to redsuns03 For This Useful Post:
illicitstylz (05-08-2014), MmmDieselFumes (10-21-2013)
Old 10-21-2013, 01:34 PM   #2
MmmDieselFumes
MmmDieselFumes's Avatar
Drives: .
I like that a lot, great write-up! Couple questions though:
1.) Are you running LED DRL's?
2.) The Turn Signal DRL's are essentially on all the time now, correct?
Because I'm trying to figure out how to turn my existing DRLs "off" because they look dull and yellow (essentially I want them to only be High-Beams), and have these new Turn Signal DRLs be the only DRLs. If that makes sense.
MmmDieselFumes is offline   Reply With Quote
Old 10-21-2013, 01:36 PM   #3
husker741
Drives: 2013 Whiteout Scion FR-S 6MT
You can have your dealer access the lights with their program to turn the DRLs off. I did that before I drove the car off the lot.
husker741 is offline   Reply With Quote
The Following 2 Users Say Thank You to husker741 For This Useful Post:
MmmDieselFumes (10-21-2013), redsuns03 (10-21-2013)
Old 10-21-2013, 01:37 PM   #4
MmmDieselFumes
Drives: .
Oh, didn't know that! If I do that, will these new Turn Signal DRLs still function properly?
Old 10-21-2013, 01:41 PM   #5
husker741
I'm not familiar with these lights but it should have no effect on them. It's a totally separate housing and function than your stock DRL. Your yellow DRL you see during the day also acts as your high beams at night. Once you turn your parking lights or low beams on, the DRL goes off. It will stay off until you turn all those lights back off, hence "Day-time running light." You could just change it to an LED bulb like many have, but you lose your high beams.
Old 10-21-2013, 01:58 PM   #6
redsuns03
The drls on the turn signal switch is controlled through the fog light switch in your car. The drls headlight switched off by the dealer will not affect the drls in your turn signal.
Sent from the Underground Lair of Arizona 86 HQ
Old 04-18-2014, 07:44 PM   #7
Efferalgan
Drives: 2025 BRZ, ex-2012 GT86
So, no need to resistors and stuff? Why then the recommended installation instructions are so complicated? How did you avoid hyperflashing?
Efferalgan is offline   Reply With Quote
Old 05-08-2014, 12:33 AM   #8
bryan767
bryan767's Avatar
Drives: 13' AVO Whiteout
I would I also suggest these, because there is no wiring involved. And its a little bit cheaper.
[ame="https://www.youtube.com/watch?v=zMg2G8XFSBU"]White/Orange Switchback LED Turn Signals on Scion FR-S - YouTube[/ame]
http://www.vleds.com/shop-bulb-numbe...hback-led.html
bryan767 is offline   Reply With Quote
The Following User Says Thank You to bryan767 For This Useful Post:
Nofiboy (12-07-2016)
Full LED Front Bumper Triangular Parking & Turn Signal Light Housing Replacement ZetaPerformance_CS Cosmetic Modification (Interior/Exterior/Lighting) 36 03-26-2014 01:18 AM
Removing front signal housing, DIY? wparsons Cosmetic Modification (Interior/Exterior/Lighting) 3 08-10-2013 05:43 PM
WTB Stock FRS front turn signal housing Yruyur Interior Parts (Incl. Lighting) 0 07-30-2013 01:09 AM
LED Turn Signal Issue FR-S Matt Cosmetic Modification (Interior/Exterior/Lighting) 15 07-23-2013 01:47 PM
Anyone seen these turn signal/drl less? djliquidsteele Cosmetic Modification (Interior/Exterior/Lighting) 7 07-15-2012 04:32 AM
