Removing front signal housing, DIY?
Looking for any info on how easy/hard it is to remove the front signal housing. I imagine it's not much more involved than replacing the bulbs? Are they held in from the front or the back?
Drives: 2013 Whiteout FR-S
Not that difficult. I removed them when I installed the Zeta signal lamps.
Remove the inner wheel liner enough to access the signal lamp assembly. Push the tabs holding the black molding surrounding the signal lamp assembly out from inside the bumper. You will need to apply some pressure to the black molding to push it outward. If I recall correctly, there are two 10mm nuts holding the signal lamp assembly in place. Remove those and the assembly comes out. I did this without removing the wheels and just turning the wheels in. Plenty of room to work with. Hope this helps. Sorry I didn't take photos and just going off memory. |
No that's great, are the nuts on the front side (behind the bezel)?
| Full LED Front Bumper Triangular Parking & Turn Signal Light Housing Replacement | ZetaPerformance_CS | Cosmetic Modification (Interior/Exterior/Lighting) | 36 | 03-26-2014 12:18 AM |
| WTB Stock FRS front turn signal housing | Yruyur | Interior Parts (Incl. Lighting) | 0 | 07-30-2013 12:09 AM |
| removing front grille (fr-s) request | Andyx5044 | DIY (Do-It-Yourself) Guides | 6 | 01-26-2013 01:42 PM |
| Removing the 86 badge on the front of the car | Pake1 | Cosmetic Modification (Interior/Exterior/Lighting) | 1 | 06-10-2012 08:37 AM |
| *** Front Lighting Modifications HID Headlights LED Angel Halo Custom Housing *** | zAnSh1n | Cosmetic Modification (Interior/Exterior/Lighting) | 21 | 04-04-2012 04:41 PM |
