Old 08-01-2013, 12:27 AM   #15
Grip Ronin
The Mechanic
Grip Ronin's Avatar
Drives: Civic Turbo,FR-S
you spaced the 2nd sensor and not the first one? i didnt know if the 2nd one can throw lean codes because its the first sensor that checks a/f. i used 2 sparkplug spacers. one drilled. no codes in weeks
IG-Joey_Soul
Progress Thread Ported billet 20G
Grip Ronin is offline   Reply With Quote
Old 08-01-2013, 12:36 AM   #16
EZWood
BAMF
EZWood's Avatar
Spaced the second(down stream) sensor. Threw a lean code, pulled spacer and got an inefficient catalyst code.
Old 08-02-2013, 11:45 AM   #17
regal
Drives: Scion FR-S/Toyota Yaris
Just get a catted front pipe with an O2 bung after the cat and move the secondary O2 sensor there.
2013 FRS Argento Silver 6MT
Mods:
Clear fender side lights
Tactrix ZA1JB01C 2014 Calib
regal is offline   Reply With Quote
Old 10-15-2013, 04:40 AM   #18
Fast_Freddy
Drives: Passat
In case you haven't already discovered this or blown your engine, never under any circumstances whatsoever install a spacer of any kind on the primary O2 (AFR) sensor. Adding a spacer to this sensor will cause your engine to run lean. Depending on the spacer effect, possibly dangerously lean. Remove it ASAP.
The secondary O2 sensor (narrowband) monitors catalyst efficiency from it's position downstream of the primary cat and is the only sensor responsible for setting the typical P0420 catalyst efficiency CEL when the primary cat is removed. The spacer goes on this sensor only and the effect is to cause the sensor to read less oxygen which it sees as a properly functioning catalyst.
Fast_Freddy is offline   Reply With Quote
Old 10-15-2013, 09:52 AM   #19
Grip Ronin
The Mechanic
Grip Ronin's Avatar
i know thats what i said, to space the secondary o2. lol On this car a p0420 can be accompanied by a lean code as well. i told him not be sure not to space the first one.. but im running o2 bypass on openflash now. the spacer dont work long
IG-Joey_Soul
Old 10-15-2013, 04:06 PM   #20
EZWood
BAMF
EZWood's Avatar
I have a tune. No issues anymore.
Old 10-16-2013, 04:34 AM   #21
Fast_Freddy
Drives: Passat
Sorry 'bout the misunderstanding. My bad.
Cool. FWIW, I'm running a Borla UEL, a mini-cat spacer on my secondary O2 and a Visconti stage 2 tune. Mostly CEL free but I just had a P2096 for post-cat too lean.
Old 10-16-2013, 04:45 PM   #22
EZWood
BAMF
EZWood's Avatar
I'd get away from a Visconti tune if I were you.
Old 10-16-2013, 11:31 PM   #23
Fast_Freddy
Drives: Passat
Why?
Old 10-18-2013, 02:23 AM   #24
EZWood
BAMF
EZWood's Avatar
Why?
I have no information from personal experience, but I've seen the power his tunes put down, and I've heard from people who have delt with him and in my opinion he is not as good of a tuner as he is made out to be. He is rude, negligent and he has been charging his flex fuel customers for an upgrade that should be included in the kit to prevent fuel from leaking. I have no Ill intentions towards him, I wish him success, but I would not do business with someone like him nor would I recommend anyone else do so either.
Old 10-18-2013, 02:27 AM   #25
EZWood
BAMF
EZWood's Avatar
Why?
http://www.ft86club.com/forums/showthread.php?t=48109
Old 10-18-2013, 04:01 AM   #26
Fast_Freddy
Drives: Passat
I've heard all the same viral BS on this forum spread by a handful of Visconti haters but have never been one to follow the mob mentality or care what or who is popular with them at the moment.
I've never met John Visconti or even spoken to him as my tune was done through a 3rd party shop. All I know is that he remotely dyno tuned my car, added 17whp and his tune has been without flaw.
I hear that Beethoven was a bit of a prick too but I still appreciate his music.
The Following User Says Thank You to Fast_Freddy For This Useful Post:
EZWood (10-18-2013)
Old 10-18-2013, 12:53 PM   #27
EZWood
BAMF
EZWood's Avatar
If you like his work, then that's all that matters for you. Cheers
RPM dip with A/C running BunnyRZed Issues | Warranty | Recalls / TSB 31 10-22-2014 09:56 PM
FA20 Fuel lean at high boost fix cf6mech Forced Induction 15 05-20-2013 03:33 PM
Running low on gas Arctek83 Scion FR-S / Toyota 86 GT86 General Forum 63 04-15-2013 07:35 PM
Slip+CEL = Bank1 running lean? Trashed675 Issues | Warranty | Recalls / TSB 11 03-28-2013 10:53 PM
Running 19's SocalBurt Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 8 09-04-2012 02:45 PM
