Old 10-13-2013, 08:11 PM   #43
DrDuquette
DrDuquette's Avatar
Drives: 2013 Premium White, 2006 TL
Waiting for your pictures
Originally Posted by mike the snake View Post
I would say they're definitely an upgrade compared to stock. They're made by KW (same as the KW V1's) so you know they are quality.
Slightly stiffer spring rates, lowering ability, less body roll, and they seem valved very well for the application.
There's some stutter bumps on the road near me that had my old BMW 135i and my stockBRZ skipping slightly in the turn, and the ST's keep my BRZ rear firmly planted and smoothly eat those bumps up.
Ride is similar to stock, not much stiffer at all, I have over 2000 miles on them and no noises or knocking.
I'm super happy with these coilovers.
Pictures please.
DrDuquette is offline   Reply With Quote
Old 10-13-2013, 10:10 PM   #44
mike the snake
The Following User Says Thank You to mike the snake For This Useful Post:
DrDuquette (10-14-2013)
Old 10-14-2013, 12:44 AM   #45
hanabie
hanabie's Avatar
Drives: WRB LMTD '13
progressive or linear spring rates?
hanabie is offline   Reply With Quote
Old 10-14-2013, 10:49 AM   #46
mike the snake
Whatever the kit comes with. Linear I believe, the rates are posted here in the thread somewhere I think.
Old 10-14-2013, 01:51 PM   #47
RallySport Direct
RallySport Direct's Avatar
Drives: 2014 Widebody Cosworth FR-S
Yeah I posted it earlier in the thread, but they will be linear springs, and let me post up the rates again
Spring Rate Front : 230lbs/in
Spring Rate Rear : 285lbs/in
Spring Rate Front Metric : 4.1Kg/mm
Spring Rate Rear Metric : 5Kg/mm
And drop specs are:
Drop Height Front : .8 - 2in
Drop Height Rear : .8 - 2in
Drop Height Front Metric : 20 - 50mm
Drop Height Rear Metric : 20 - 50mm
Thanks,
Rick
RallySport Direct is offline   Reply With Quote
The Following 2 Users Say Thank You to RallySport Direct For This Useful Post:
hanabie (10-14-2013), melon (11-28-2013)
Old 10-14-2013, 02:14 PM   #48
hanabie
hanabie's Avatar
No Limit Motorsport advertised it as progressive spring rates. I guess that is wrong. Does this also apply to V1 and T0? Are they also linear?
Old 10-14-2013, 04:39 PM   #49
Circuit Motorsports
Circuit Motorsports's Avatar
Drives: 2013 Subaru BRZ
Send a message via AIM to Circuit Motorsports
Originally Posted by funbeatsfast View Post
Alright, I'm in.
My preference is to support local vendors. Anyone besides TireRack selling these things in OH/IN/PA? Don't see 'em on Stranoparts.
We sell them, just PM us
Originally Posted by Swabe View Post
people with these CO, would you say they're an upgrade compare to stock (except the lowering part)?
Yes, these will be slightly firmer and have more aggressive valving compared to the stock setup. You also have the added ability of height adjustment.
Linear all around.
The picture they posted shows linear springs.
Circuit Motorsports is offline   Reply With Quote
The Following User Says Thank You to Circuit Motorsports For This Useful Post:
Swabe (10-14-2013)
Old 11-13-2013, 10:24 PM   #50
Crooksandkevin
Crooksandkevin's Avatar
Top hats
What top hats did you use on the st coils? I just got a pair and the stock top hats don't fit
Crooksandkevin is offline   Reply With Quote
Old 11-27-2013, 04:31 AM   #51
continuecrushing
continuecrushing's Avatar
Drives: 2013 Firestorm FRS
Originally Posted by Shutter View Post
How much negative camber are you guys getting on the front end?
For those of you NOT running camber plates...
Bump! Just trying to see what the front end camber is looking like with these...
Old 11-27-2013, 07:25 AM   #52
mike the snake
Mine has about -2 degrees in front if I remember correctly. The rears cambered out more to -2.5, car is lowered about 1.5"
continuecrushing (11-27-2013)
Old 11-27-2013, 06:45 PM   #53
BRZY
BRZY's Avatar
Drives: World Rally Blue BRZ
Originally Posted by OICU812 View Post
Ok guys for you that installed the ST did you use the Subaru washer on top? Between stock top hat and coil..
so no one used these on their ST coils? all the V3 guys are stating they are using it, it seems.
BRZY is offline   Reply With Quote
Old 11-27-2013, 08:09 PM   #54
Turkish
Serial Cone Killer
Turkish's Avatar
Drives: '14 BRZ - WRB Premium 6MT
What are opinions about these vs Tein Street Basis? The pricing seems to be pretty close, Tein has stiffer springs (according to data listed by Rally Sport Direct), and ST has a better warranty.
I am a newbie when it comes to tuning, well pretty much any aspect of a car, and suspension is no different. Coming from stock suspension, what would I notice as far as expected changes in handling characteristics from stock and between the two and is there a significant product quality difference between Tein and ST (aka KW)?
Turkish is offline   Reply With Quote
Old 11-27-2013, 09:01 PM   #55
motorsports3
Drives: 2013 Fr-S
So you are getting -2 degrees of camber with how much drop? I am on the edge with these and the BC, but might choose the BC because of the camber plates
motorsports3 is offline   Reply With Quote
Old 12-01-2013, 08:12 PM   #56
BRZY
BRZY's Avatar
anyone with the ST get spanner wrenches with their kits or is it just me?
Suspension / Coilovers ~ How to Choose the Right Setup for YOU Circuit Motorsports Suspension | Chassis | Brakes -- Sponsored by 949 Racing 30 09-24-2015 01:53 PM
Suspension Review: KW v3 Coilovers DarrenDriven Suspension | Chassis | Brakes -- Sponsored by 949 Racing 53 07-09-2015 11:42 PM
Motion Control Suspension coilovers xwd Tracking / Autocross / HPDE / Drifting 27 02-21-2015 10:24 PM
GROUP BUY: TEIN SRC Coilovers / Suspension CounterSpace Garage Groupbuys 24 10-31-2013 03:56 PM
STD Standard Suspension R3 Coilovers knocking FutureFT86 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 2 05-07-2013 12:49 PM
