Old 08-05-2013, 08:06 PM   #29
OICU812
Just a dude
OICU812's Avatar
Drives: Scion FR-S 2013
Ok guys for you that installed the ST did you use the Subaru washer on top? Between stock top hat and coil..
Old 08-05-2013, 10:43 PM   #30
Kmurph
Kmurph's Avatar
Drives: Whiteout AT/FRS
No need for it, just use stock top hats and you are good. I have had mine on for about 500 miles and no strange noises or problem
WHITEOUT FRS/AT
Kmurph is offline   Reply With Quote
Old 08-05-2013, 11:19 PM   #31
mike the snake
Mine are quiet so far as well. I have maybe 50 miles on them, but have gone on some bumpy roads that had my Ohlins coilovers knocking loudly on my 135.
I'm really liking these ST coilovers, the spring rates are relatively soft.
Old 09-29-2013, 03:29 AM   #32
kchiang4200
Drives: Raven FR-S
Hey guys, newbie question here: When you installed these, how far were you able to screw the top nut? There's this plastic blue ring in the nut and it doesn't seem like it'll screw any further. Thanks.
kchiang4200 is offline   Reply With Quote
Old 09-29-2013, 02:57 PM   #33
hanabie
hanabie's Avatar
Drives: WRB LMTD '13
damn.. my next purchase
hanabie is offline   Reply With Quote
Old 09-29-2013, 08:21 PM   #34
mike the snake
2200 miles so far, still loving my ST coilovers.
Ride is similar to stock, improved handling, car is lowered 1.5", no noises or knocking, all is good.
Old 09-30-2013, 12:51 AM   #35
nakamur21
Drives: 2013 BRZ limited
what are the spring rates on the STs?
nakamur21 is offline   Reply With Quote
Old 09-30-2013, 05:55 PM   #36
RallySport Direct
RallySport Direct's Avatar
Drives: 2014 Widebody Cosworth FR-S
Spring Rate Front : 230lbs/in
Spring Rate Rear : 285lbs/in
Spring Rate Front Metric : 4.1Kg/mm
Spring Rate Rear Metric : 5Kg/mm
And drop specs are:
Drop Height Front : .8 - 2in
Drop Height Rear : .8 - 2in
Drop Height Front Metric : 20 - 50mm
Drop Height Rear Metric : 20 - 50mm
Hope this helps! Thinking these will be going on my personal BRZ next spring
Thanks,
Rick
RallySport Direct is offline   Reply With Quote
The Following User Says Thank You to RallySport Direct For This Useful Post:
melon (10-02-2013)
Old 10-01-2013, 11:36 AM   #37
Circuit Motorsports
Circuit Motorsports's Avatar
Drives: 2013 Subaru BRZ
Send a message via AIM to Circuit Motorsports
These are a great option for those looking to get a slight "sport" upgrade from the stock suspension and have the added feature of setting their ride height.
This is like a really good "OEM" sport option. Think Porsche GT3.
Circuit Motorsports is offline   Reply With Quote
Old 10-02-2013, 07:10 AM   #38
continuecrushing
continuecrushing's Avatar
Drives: 2013 Firestorm FRS
How much negative camber are you guys getting on the front end?
For those of you NOT running camber plates...
Old 10-02-2013, 12:12 PM   #39
funbeatsfast
funbeatsfast's Avatar
Drives: '13 FR-S
Alright, I'm in.
My preference is to support local vendors. Anyone besides TireRack selling these things in OH/IN/PA? Don't see 'em on Stranoparts.
funbeatsfast is offline   Reply With Quote
Old 10-02-2013, 12:40 PM   #40
CSG David
CSG David's Avatar
Originally Posted by funbeatsfast View Post
Alright, I'm in.
Would be great if we are local, but we aren't in Ohio. We recently added this to our line up. Hearing that it is manufactured by KW, we know the manufacturing quality of materials is top notch.
The Following User Says Thank You to CSG David For This Useful Post:
thatWESguy (10-04-2013)
Old 10-10-2013, 06:52 PM   #41
Swabe
Swabe's Avatar
Drives: Black
people with these CO, would you say they're an upgrade compare to stock (except the lowering part)?
IG: swabelife
Swabe is offline   Reply With Quote
Old 10-10-2013, 07:45 PM   #42
mike the snake
I would say they're definitely an upgrade compared to stock. They're made by KW (same as the KW V1's) so you know they are quality.
Slightly stiffer spring rates, lowering ability, less body roll, and they seem valved very well for the application.
There's some stutter bumps on the road near me that had my old BMW 135i and my stockBRZ skipping slightly in the turn, and the ST's keep my BRZ rear firmly planted and smoothly eat those bumps up.
Ride is similar to stock, not much stiffer at all, I have over 2000 miles on them and no noises or knocking.
I'm super happy with these coilovers.
The Following 5 Users Say Thank You to mike the snake For This Useful Post:
armythug (10-14-2013), Cjymiller (10-10-2013), melon (10-11-2013), ModBargains.com (10-10-2013), Swabe (10-11-2013)
Suspension / Coilovers ~ How to Choose the Right Setup for YOU Circuit Motorsports Suspension | Chassis | Brakes -- Sponsored by 949 Racing 30 09-24-2015 01:53 PM
Suspension Review: KW v3 Coilovers DarrenDriven Suspension | Chassis | Brakes -- Sponsored by 949 Racing 53 07-09-2015 11:42 PM
Motion Control Suspension coilovers xwd Tracking / Autocross / HPDE / Drifting 27 02-21-2015 10:24 PM
GROUP BUY: TEIN SRC Coilovers / Suspension CounterSpace Garage Groupbuys 24 10-31-2013 03:56 PM
STD Standard Suspension R3 Coilovers knocking FutureFT86 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 2 05-07-2013 12:49 PM
