| Software Tuning Discuss all software tuning topics. |
Drives: Panda FR-S
Can I map access in ECUtek without a tune file?
I got my car dynotuned at a shop and they probably lost my tune file. I haven't found any way to map access without a tune file. Is there a way around this?
Vortech SC on 9psi Pulley, Invidia Catless Front Pipe, Invidia N1 Catback Exhaust
![]() 242whp/197ft-lb on Mustang Dyno (91 octane water) 284whp/223ft-lb on Mustang Dyno (E85) Delicious Tuning |
#2 |
I Love custom Turbo kits
Drives: Limited BRZ
Throwing it out there... Who knows, but have u tried doing ECU query and see if the result is a flash file of the tune in your ECU?
| The Following User Says Thank You to Sportsguy83 For This Useful Post: | Cal3000 (10-13-2013) |
#3 |
Drives: 2013 FRS Asphalt
are you saying they never emailed you the flashed file? did they use your laptop to do the flashing in the first place? it maybe on there.
2013 Scion FR-S AT Picked up 5/30/2012
| The Following User Says Thank You to feldy For This Useful Post: | Cal3000 (10-13-2013) |
#4 |
Drives: Panda FR-S
Hmm. Haven't tried that. I do know in between dyno runs, the tuner had to upload new maps.
#5 |
Drives: Panda FR-S
They didn't want to email me the tune file for some reason. They used another laptop.
#6 |
| The Following 2 Users Say Thank You to jamesm For This Useful Post: | Cal3000 (10-13-2013), Sportsguy83 (10-13-2013) |
#7 |
fucking strange.... did they give you stock files or anything? is it one of the vendors on here? I would say they owed you a re-tune and the flashed map.
#8 | |
You do need a rom file (.bin) for map access and data logging. Let me know if your FR-S is manual or automatic, and I'll email you the stock ROM for your FR-S. At least that will give you map access and logging capability. PM me your email address. You need to insist that this tuner get you your tuned ROM file. Wow. -- Bob |
| The Following User Says Thank You to Circuit Motorsports For This Useful Post: | Cal3000 (10-13-2013) |
#9 | |
This.... totally forgot you need that bin file to do logging. You can log a little bit with the stock rom see if you are knocking ect but the more advanced features you will need that bin file. To see things like the iam value ect.
#11 |
Drives: Panda FR-S
Thanks guys. I have a stock rom file that I used. Some of the data is funky. The max manifold abs. pressure that it shows is 1.27 bar which is only like 4psi. Should be getting at least 9.1psi on the 9psi pulley. WOT ignition timing advance is reading 32 degrees. lol. I'm guessing the tune file has a lot to do with the correct readings??
#12 | |
Grip>Slip
| The Following User Says Thank You to xjohnx For This Useful Post: | Sportsguy83 (10-14-2013) |
| Help?!? Maybe..Ecutek tune | JerryMichaels7 | Software Tuning | 6 | 09-30-2013 11:47 PM |
| DI Popping noise, just installed new updated tune file. | Bg8780 | Issues | Warranty | Recalls / TSB | 21 | 06-27-2013 11:56 PM |
| WTB: Ecutek Tune Bay area | hyperpunx | Engine, Exhaust, Bolt-Ons | 0 | 04-02-2013 11:38 AM |
| Ecutek Map Access, data logging Vs. obd2 sensor | lbroskee | Scion FR-S / Toyota 86 GT86 General Forum | 3 | 01-06-2013 02:56 PM |
| FA20CLUB.COM ECUTEK TUNE | hayleybeaners | Engine, Exhaust, Transmission | 21 | 11-13-2012 09:52 AM |
