Old 09-30-2013, 07:33 PM   #1
JerryMichaels7
Drives: Whiteout FRS
Help?!? Maybe..Ecutek tune
So I am not sure if I should be worried or not, but when i go from around 3-4500 there is a hard rattle like metal on metal. 2 things happened the day it started got tuned and 7500 oil change @ Toyota. Now my first thought was retards left something loose well I checked and everything was good took it all off and drove but it's still there. I thought "no way it could be the tune" so i flashed to stock and its gone...or at least 90 percent gone. Only mod I have is an fa20club intake. Anyone seen this before?
JerryMichaels7 is offline   Reply With Quote
Old 09-30-2013, 07:35 PM   #2
mikalem
mikalem's Avatar
Drives: 2020 DGM BRZ Limited
Who did you get a tune through? Logs taken while it's happening? Sound like something hitting the frame, or something else?
mikalem is offline   Reply With Quote
Old 09-30-2013, 07:37 PM   #3
JerryMichaels7
Sounds like something hitting the frame. Checked the intake that was my first thought took it off and checked and there were no rub marks or anything were it could hit. Gonna take the heat shield off the stock header next i think...fa20club tune and logs were sent in while it was doing that..and i should tell tony now that it goes away mostly with the stock tune
Old 09-30-2013, 07:45 PM   #4
mikalem
mikalem's Avatar
I know the first few tunes from Toni can be a little rough - definitely let him know and give him what you have so he can get back to you - since you have the stock file I'd flash back to that for the time being - I had to do the same thing with the first few revisions I got, just for safety's sake.
Just as a side note, I have had the metal on metal sound, but not with the stock header - started happening with my current setup until I adjusted - the overpipe runs very close to the cross member so if you get the car's engine to move enough they can touch, just an fyi.
Old 09-30-2013, 07:54 PM   #5
JerryMichaels7
Yeh I am gonna stay on the stock file for now. already sent the logs just waiting for the next update and I just sent an email updating tony with the problem I am having
Old 09-30-2013, 08:06 PM   #6
JerryMichaels7
I think I found...there is part of the heat shield near the overpipe and i can move it with ease(up down left right and a clamping motion). Still don't know why its more noticeble with the tune tho...
Here is a pic of the part i am talking about
Old 09-30-2013, 11:47 PM   #7
Frostyman
Drives: 2013 Raven FRS
it's more noticeable with tune due to engine harmonics being changed at that given RPM with Toni's tune. I had the same thing happen in the same RPM range. I stuck some black foam tape stuff to my aluminum underpanel, thinking that was what was rattling, and it is completely gone now. Though that could really just be from taking it off, and putting it back on, made it shift slightly so that it wouldn't touch the heat shield anymore.
Originally Posted by Don@Accelerated
For the sake of argument I went and cut my factory filter housing up.
Frostyman is offline   Reply With Quote
Does anybody know if the tune from the vortech is better than the ecutek? Frsexxxy Forced Induction 16 04-08-2013 11:53 AM
WTB: Ecutek Tune Bay area hyperpunx Engine, Exhaust, Bolt-Ons 0 04-02-2013 11:38 AM
Ecutek visconti tune ft86me Engine, Exhaust, Transmission 24 03-14-2013 10:35 AM
Ecutek Tune From Visconti tonytduc Engine, Exhaust, Transmission 3 03-13-2013 08:28 PM
FA20CLUB.COM ECUTEK TUNE hayleybeaners Engine, Exhaust, Transmission 21 11-13-2012 09:52 AM
